Question about Whirlpool LER4634J Electric Dryer
My dryer stopped heating last night, is there an internal breaker for the heating element?
  • 6,784 Answers
Yes. Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Posted on Oct 05, 2009
Frigidaire - Professional Series - Gas/Electric Range - Replaced bake element but now Broiler and Bake elements don't work
Go outside to the breaker panel on your house and reset the oven breaker a couple of times. It will be 2 breakers side by side with the switch handles bound together. What happens is if one trips but not both, 240 volts is not present but 120 is. that's why motors and lights still work. If the breaker has some age on it just get the number off it and replace it.
May 24, 2015 | Kitchen Ranges
Cu ft maytag performa
make this tests and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating Element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. The proper ohm reading can be found in the service manual or sometimes on the tech sheet located somewhere on your dryer (9- 13 ohms is a common reading). Electric heating elements aren't repairable. The heating element replace it.
Thermal fuse / Thermal Cut Out / Thermistor
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel or behind the front cover . The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing They are also round and made of metal and plastic. The thermistor is located on the blower housing usually. If any of the fuses do not have continuity replace it. Check for continuity if none replace, But before replacing check for obstructions. The fuses are very inexpensive and replace it
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. Check all connections, make sure they are tight. Loose connections can lead to a fire. You may need to replace power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 02, 2013 | Dryers
Electric dryer runs , turns but no heat.
You most likely have a bad heating element. When they break, the ends tend to touch the side of the element housing. This causes a short, tripping the breaker. Remove the back panel and replace heating element.
Please rate this solution.
Sep 02, 2009 | Kenmore 73952 Gas Dryer
Heating element has stopped working just 2 days
use a multimeter to check the continuity of the heating elements. if there is an open, replacing it will solve the problem.
Aug 04, 2009 | Dryers
Whirlpool electric dryer ran all night and won't heat
Yes it will heat. The two are normally not dependent on the other. The element could be bad. Check the breaker first, then the connections in the back, then the element. The timer could be bad itself allowing it to run all night. This could be a blessing in disguise as the clothes would have been damanged possibly from all the excess heat.
Dec 26, 2008 | Whirlpool LER4634J Electric Dryer
Dryer is not heating and will not stop running
if you were running it on timed cycle and it was still running with no heat then you have a bad timer and if you were running it on auto cycle and it was still running and its electric dryer then you have a bad element ,,, if its gas you may have a bad ignitor / larry
Dec 04, 2008 | Dryers
Dryer not heating
hi thanks for the question. disconnect the dryer. remove the front 2 screws remove front. element is on the right in a cylinder check and replace. thanks the appliance doc
Oct 16, 2008 | Dryers
Dryer quits running but heating element stays one
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Mar 15, 2008 | GE Profile DPSR473EW Dryer
Whirlpool LER4634J Electric Dryer Logo
131 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
