Question about InFocus IN36 Projector
Turn projector on and the bulb turns off. The
Turn projector on and the bulb turns off. The only way to shut the projector off is to pull the plug
  • 2,237 Answers
Ballast/power supply issue. needs replacing.
Posted on Oct 16, 2009
3 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: projector shut down after replacing the bulb and wont turn on now
are any of the leds on the top of the projector lit? if so, which ones? red or green?
Posted on Aug 06, 2009
  • 74 Answers
SOURCE: infocus IN36 projector will not turn off
Try a firmware upgrade.
Posted on Apr 15, 2010
My HD80 has about 700 hours, original bulb assembly, was working fine until I got curious and "activated" the auto off function while going through the menu. Now it will power up, lamp does not go to
Ensure a video source is connected to the projector (VGA, DVD, etc)
Unplug the projector to make sure it has completely shut down (not just went into sleep mode)
Plug in power and power on the projector (make sure video source is on first)
The projector should turn on and switch to the video source (manually select if not)
Once you can see the video source, push menu and turn off auto-off.
Auto-off should only work when the projector detect a video source is no longer present on the selected input. So if you are turning on the projector with no video source connected, it will usually turn off shortly after being turned on.
Nov 30, 2014 | Optoma HD80 Projector
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
It quits projecting, the green light goes off and the red light of the bulb goes on. I've disconnected everything and reconnected, turn it on and it works for about two minutes and shuts off projector,...
Have you tried cleaning the fliters on the back of the unit? It's easy to do. Pull them out, and blow them clean. Also, is the projector well ventilated - mine overheats sometimes and shuts off. Otherwise, sounds like he bulb to me.
Oct 25, 2010 | InFocus Office Equipment & Supplies
How do you install a new bulb in the Optoma HD70 projector. Got a new bulb but no instructions
unscrew the screw on the lamp door, unscrew the lamp screws, pull the lamp out, replace with new lamp (making sure it's securely plugged in), screw it in, replace the door, plug the projector in, turn it on, enjoy!
Nov 07, 2009 | Optoma HD70 DLP Projector
Projector turns on the power light flashing and lamp light solid
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Jun 12, 2009 | HP Digital Projector Vp6120 Multimedia...
Projector shut down after replacing the bulb and wont turn on now
Apr 09, 2009 | Sharp Notevision PG-B10S Multimedia...
Sharp XR-10X projector, but missing the projector bulb.
if you plug it in and turn it on, you should at least hear fans running, then it'll shut down because there is no lamp. that's about it.
Apr 01, 2009 | Sharp XR-10X Multimedia Projector
Power problem
we were unable to pull the projector menu & it also took about 2 hours for the bulb to turn on.......the fan works, have changed the bulb, closed the bulb door & tried to reset the projector.......help!
Feb 24, 2008 | InFocus X1A Multimedia Projector
Infocus LP725 projector
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
May 25, 2007 | InFocus LP725 and LP735 Replacement...
InFocus IN36 Projector Logo
396 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
