Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
My camera doesn't recognize that the memory card is inserted (error message "no memory card!" displays), and when i tried a different card it read "memory card error". whats going on?!
JMuskovitz
  • 135 Answers
SOURCE: memory card not reading in canon a75
So as not to spoil your vacation, go buy yourself a new compact flash card locally. They should sell them anywhere electronics are sold, including WalMart, etc. See if you can get this new card to work in your camera. If so, then you can work on trying to get your current CF to work, by trying to format it in the camera. If you can't get a new CF to work in the camera, then you likely damaged either the pins in the CF socket in the camera, or some switch that is pushed when the card is inserted (to tell the camera there is a card in it). It is unlikely you will be able to have this fixed during your vacation, unfortunately.
Posted on Mar 05, 2007
  • 5 Answers
SOURCE: sd card error on canon powershot s3
I have had a similar error which turned out to be a corrupted memory card. It was replaced under warranty with no questions asked. Causes may be static electricity discharge or a high humidity/temperature combination. Either way get a new card.
Posted on Jul 31, 2008
SOURCE: "No Memory Card" error.
PLEASE can anyone help. I have the same problem too and I'm about to go on vacation. I need this camera to work. Please help.
Posted on Aug 21, 2008
fotobean
  • 103 Answers
SOURCE: getting memory card error
Some cameras require a new Firmware update of it's internal brain so it can recognize larger capacity memory cards. Check out your cameras website, look up the FAQ column or support and see which memory card sizes are compatible.... Good luck
Posted on Jan 05, 2009
t00nz
  • 4738 Answers
SOURCE: my Canon powershot s400 camera won't read memory card
First, remove the card, and look in the slot for any bent flash card pins. If you see any, don't fret, it's possible that you can fix this yourself. See this article on how to unbend flash card pins.
But if no pent pins are seen, then the camera's clock battery has worn out, and is likely causing this problem. Unfortunately this battery is internal to the camera. But Canon will fix this for you (for the S400 only) for free, with free shipping. Please see the Canon advisory for your camera here.
Posted on Sep 12, 2009
After inserting an approved memory card the following message shows up 'Memory card error' - what to do?
Try another new memory card, if it continues to give you an error go to the main menu and look for FORMAT, some times you need to format the card so the camera can recognize the new card.
May 24, 2014 | Canon PowerShot SX20 IS Digital Camera
When i insert the memory card into my canon sd780 and it reads no pictures, when i know there are picture in the memory card, also when i insert the memory card in the computer it wont recognize it, what...
Sounds like the card has become corrupted. Try the recovery software, along with the corrupted card procedures at this link. Of the software listed, try MiniTool first, and if that doesn't work, next try PhotoRec.
Sep 29, 2011 | Canon PowerShot SD780 IS / IXUS 100 IS...
The camera beeps when we put the card in.
The images you take with your PDC 640 camera are stored on a removable 3.3V SSFDC or SmartMedia 2 MB memory card (also available in 4 MB and 8 MB). Note: You must insert the memory card before you can turn on the camera.
If camera beeps is enabled, the camera beeps if the card is not installed and displays the [ ] message on the Status panel.
To insert the memory card:
1. Make sure the lens cover is closed (the power is off).
2. Open the memory compartment on the side of the camera.
3. Insert the memory card into the slot (gold side of the card facing the front of the camera).
Make sure the card is pushed firmly into the slot. Note: The camera prompts you to format the memory card if it is not formatted. The camera displays the format menu on the LCD viewfinder. Press the button next to Format.
4. Close the memory compartment cover.
If you can, try using a different memory card. Else, your memory card contact terminals inside the camera may have become worn, causing the camera to not recognize the card once it is inserted.
Mar 13, 2011 | Polaroid PhotoMax PDC 640 Digital Camera
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
Memory card error
Having gone over a month with no response, I assume it was just a matter of SD versus SDHC cards.
Jul 17, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Sd card error on canon powershot s3
I get a memory card error everytime I insert a memory card. They are not locked and I have tried 4 different memory cards and nothing works. How can this problem be fixed?
Jul 28, 2008 | Canon PowerShot S3 IS Digital Camera
Canon power shot SD200
You can take out the memory card from camera and then download a memory card recovery software to recover photos from memory card, you can refer to this tutorial that helped me before
http://www.asoftech.com/articles/how-to-recover-lost-photos-from-memory-card.html
If needed, you may do a quick format of the memory card and then use asoftech data recovery to recover your files.
Dec 30, 2007 | Canon PowerShot SD200 / IXUS 30 Digital...
"Memory card is locked"
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
"Read only card, change to internal memory to capture"
This error message indicates that the memory card in the camera is write-protected. To take a picture, turn off the camera and insert a new card, or change the storage location to internal memory.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
