Question about Native Remedies Health & Beauty
Monitor stops and starts again, goes up to a very high pressure and invariably gives a high reading, is this a fault
    Problem Solver:
  • 10 Answers
Dear Arthur: Try different placement on your arm. Try the other arm. Try it on someone else. You may have either a broken machine or very high systolic pressure. In which case SEE YOUR DR!. Dr Ron Grassi,DC.,MS. Jupiter,Florida. USA. www.drgrassi.com monitor stops and starts again, goes up to a very - 6ec8f87.jpg
Posted on Oct 13, 2009
I have a 2003 S-type jaguar that goes into a limp mode and stops running then the engine system fault shows ,the parkbrake fault and DSC not available also shows. Diagnostic showed codes PO121,P1582??
code p 0121 is associated with the throttle position sensor and accelerator position sensor
causes are from cable adjustment --throttle position and accelerator position sensors
code p0533 refers to ac refrigerant pressure sensor--high input== causes --ac pressure too high (cooling fault -condenser fan not running at radiator-- too much gas --pressure sensor
p 0105 refers to map sensor / barometric pressure sensor --circuit malfunction===causes wiring--- map sensor --baro sensor ECM
code p0566 refers to cruise control master switch== causes --control switch , ---ECM
code p1582 refers to electronic throttle monitor data available which will be associated with the p 0121 code and faults
Jan 08, 2017 | Jaguar Cars & Trucks
I have 2008 a4 Audi, message center reads tpms I know it's tire pressure but dont know how to reset, pressure in all 4 tires is exactly the same
Tyre pressure monitoring system could work in a few different ways and invariably needs special dedicated diagnostic equipment to locate faults and to reset. Handheld units are available fairly cheaply but not yet quite as cheaply as some of the diy code readers.
Problem could be a defective sensor or radio sender valve. System will need resetting every time the tyres are changed around the car or when a tyre is changed with some systems.
Apr 01, 2016 | Cars & Trucks
I'm 66 yrs of age my blood pressure is 155 over 98, is that too high?
Hellfire, yes. You need to visit a doctor and get checked out. You need medication to control it, and then you either stay on the medication or modify your lifestyle a bit, a bit of exercise, watching salt intake and coffee intake. Stress is also not good!
My blood pressure was similar to yours and I have been on meds for 20 years. I am 63 in a few weeks. One thing if you are using a blood pressure monitor, you should do three readings. The first is always high. relax, breath deeply and slowly, and take it again.
There is a chart here. Get it sorted out sooner rather than later, like Monday!
Blood Pressure Blood pressure chart
Jan 16, 2016 | Omron Health & Beauty
2006 VW GOLF TURBO DIESEL 1.9 STARTS UP GOES 5 TO 9 MILES STALLS WAIT 5 MINUTES GO AGAIN AND STALLS
Hi. It would be useful to get a code read and some live data from a decent diagnostic tool. There are quite a few possible causes including, pressure in tank - if the fuel tank can't vent pressure then a vacuum will eventually form stopping fuel getting to the engine, this will cause it to loose power and stall. Then after a few mins the pressure will drop and the process start again, easy test is when the car stalls remove filler cap - if that's the fault there will be an audible hiss and the car will start up again.
part blocked exhaust will have same problems but will more generally cause a lack of power and acceleration.
are there other symptoms? i.e only when conering or only when pulling off or stopping, engine light on/off. Jon
Dec 18, 2014 | Cars & Trucks
How to calibrate my Jobar blood pressure cuff?
Was yous at heart height when you took readings? Too low will give high readings. Nibp can differentiate by as much as 10-15% remember.
Sep 05, 2014 | Health & Beauty
My low pressure fuel pump on my e270cdi cut out under high load conditions.no pressure from the rear.all fault codes tell me the rail pressure is to low
Fuel pump relay is in cavity A in the rear SAM ( Signal Acquisition Module.) on the left hand side of the trunk behind a door.
When did you check the voltage..... you must read it while cranking or you will get a zero voltage reading.. The low pressure tank pump builds pressure to the high pressure pump and then shuts down until a pressure drop is sensed in the low pressure line and it then starts up again.
If rail pressure is too low, it often is the high pressure pump in the engine or the relief valve in the fuel rail. The tank pump is low pressure just to stop the tandem pump from cavitating by sucking too hard.
Mercedes can check the rail pressure and do an injector pressure drop to rule out a leaking injector.
If the tank pump is bad it will require replacement.
Oct 20, 2013 | Mercedes-Benz Cars & Trucks
Opel corsa 1.2 easytronic 2007 car starts roaring at a full stop
Hello
The Engine and Automatic Transmission (not applicable to manual transmissions) in this vehicles drive train are fully electronically controlled by a computer called the PCM and TCM (Power Train Control Module, Transmission Control Module). When a problem like this or other drive-ability related problems occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM. Also always check fuel pressure for correct spec for your make and engine type.
Sep 10, 2012 | Opel Corsa Cars & Trucks
The systolic pressure reads high in comparison to other monitors and physicians readings.
After working in the healthcare field for a while, I never trust automatic blood pressure cuffs or machines. They usually always give a high reading, I usually check with a manual reading after getting a high reading from a automatic reading.
Dec 30, 2010 | Health & Beauty
I have a 2000 Pontiac Bonneville 3.8 non supercharged. It is throwing the codes P0446, P0452, P0453. Yes it is throwing all of them and that is what is confusing me. Just reset the codes, did a...
they are all emission faults
P0453 OBD-II Trouble Code: Evaporative Emission Control Pressure Sensor High Input. P0453 code means that a reading from the engine's evaporative pressure sensor is higher than normal due to fuel tank vapor leaks into the system.
saturated carbon canister
sensor faulty
rubber evap hoses at the tank perished
idea
check the tank fuel cap seal is working
replace the cap is one possible cause
check the fuel pump pressure or for injector rail leak
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction. The code P0446 is set when the engine computer recognizes a fault or restriction at the vent control part of the Evaporative emission control system (EVAP).
The Code P0452 indicates that the Evaporative Pressure Sensor is indicating pressure change values that are below specification, during the EVAP Monitor test and/or the operation of the vehicle.
Apr 28, 2017 | 2000 Pontiac Bonneville
I have OMRON HEM-650, but it does not give accurate results. Can you give me suggestion on which one is accurate and easy to take with? the brand, the model...
None of the finger or wrist cuffs are accurate. The slightest movement of your finger or hand will give a false reading. There are a few nice cuffs for your are and they are all pretty good. Relax for a few minutes before you take your pressure and ake it in the same position each time. Hold still and don't take a deep breath while it's testing. It is normal to have 20-40 points difference from one reading to the next. If it looks too high, sit still for 2 or 3 minutes and try again.
Oct 06, 2009 | Omron HEM 650 Wrist Blood Pressure Monitor
Health & Beauty Logo
167 people viewed this question
Top Native Remedies Health & Beauty Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Barrissimo
Level 1 Expert
Daisy Ellis
Daisy Ellis
Are you a Native Remedies Health and Beauty Expert? Answer questions, earn points and help others
