Question about Whirlpool Dishwashers
Upper arm is not rotating in my dishwasher - any ideas why not?
Upper arm is not rotating - any ideas why not? It is a built in whirlpool dishwasher that is about 4 years old and I inherited when I bought the house about 3 weeks ago. As the upper arm doesn't rotate dishes are not clean so currently not using it. Lower arm is rotating. Even when did empty load upper arm didn't move, so not a case of badly loading it.
catriver
  • 878 Answers
SOURCE: Water not getting to the upper level, dishes not cleaned.
Penrod, sounds like a circulation problem. Two things to check first. make sure the upper spray arm is not clogged with debris or split. Second is to twist and remove the filter and clear out any debris where the water enters the circulation pump impeller. If something has jammed the impeller, you would have to remove the dishwasher, remove the tank, remove the circulation motor and clean out the impeller...Catriver...post back.
Posted on Sep 03, 2006
SOURCE: figidare dishwasher
Read on another site that if the dishwasher is not near being perfectly level, this can happen.  The check ball moves back and forth allowing water to get to the upper arm sometimes and the lower arm at other times.  The upper arm does not usually start until later in the cycle.  Level is checked by when the door is open and the door is level.
Did'nt find a solution to my problem but I hope this helps others.
Albuquerque Mark
Posted on Feb 12, 2008
Kgt1962
  • 59 Answers
SOURCE: Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Posted on Mar 11, 2009
  • 81 Answers
SOURCE: removed lower spray arm:ge gld5500 dishwasher. Can reinstall.
Yes!
Posted on Apr 24, 2009
  • 423 Answers
SOURCE: LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
Posted on May 14, 2009
The upper arm is not rotating
Take it apart and clean it, water pressure should spin it around, there are bits of food/rice plugging it and stoping it from rotating.
Apr 22, 2010 | Siemens SE24A230 ExtraKlasse Built-In...
We have Model DU1145XTPQ6 built in Quiet Partner II and for the past several weeks it is leaving a white, gritty deposit inside all glasses and coffee mugs that are in the top rack. Rotating blade seems...
To solve white, gritty deposits on the upper rack, take the upper arm out. You cannot pry it open but using whatever skinny object you have to poke in the holes, banging the arm gently, lots of chunky white deposits can be shaken out. Rinse arm, replace and we're back in business. For us, this will probably be repeated every three years, but it beats replacing the arm which costs $45--another option to solve this problem.
Jan 02, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
I don't think the upper arm is rotating and I was wonder what the problem could be. Thank you, Les
The upper arm is driven by water pressure so if its not rotating it's generally because
a) the arm isn't locating properly in the upper rack
b) the arm is fouling something in the lower rack
c) blocked feed pipe to the upper arm
Dec 04, 2009 | Amana 24 in. DWA33A Built-in Dishwasher
Upper rinse arm fell off. How does it reattach?
usually it will clip to the basket that holds cups and the like, and engages with the water outlet when the basket is slid into position. Some spray arms have a locking ring that, when the spray bar is held in place, rotates clockwise (if viewed from underneath) and locks the spraybar in place.
Nov 06, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Spray Arms won't rotate
good day,
hope this link below will solve your problem.
kitchen appliances
Jul 16, 2009 | KitchenAid Architect? II U SERIES KUDS03ST...
Whirlpool GU3200XTP dishwasher - No spray on upper rack
Sounds like the hose assembly that attaches to the rear of the upper rack has come undone. just pull out the upper rack and reconnect it.
please rate my answer as a fixya! thanks.
Feb 14, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Dishwasher problem
hi make sure the top draw is pushed all the way back s there is a little rubber o ring that the shelf has to push in to
Dec 11, 2007 | Whirlpool 24 in. DU940QWD Built-in...
Figidare dishwasher
Maytag MDB4000AWW dishwasher:
Neither bottom or top arms seem to be rotating during wash cycle and dishs do not come out clean!
Wayne Wheeler
Jan 24, 2007 | Frigidaire 24 in. FDB435RFR Built-in...
Dishwashers Logo
52 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
