Question about Kodak EasyShare LS443 Digital Camera
I dropped my camera while it was on. It will not
I dropped my camera while it was on, and I think I jammed the mechanism. It will not extend or retract or take pictures, although it still clicks and hums when I turn it on.
SOURCE: lens jammed
The lens needs to be removed.  The camera case can be taken apart by using a small philips screw driver and a small flat head. Take the batteries out. Have a nice flat space to lay the screws out.  Pry out the little chrome piece with the UL sticker on it. (Carefully use the flat head). Start somewhere you will remember and begin to remove the screws going clockwise around the camera.  There is a screw under the rubber flap of the "3X" chrome cover.  The top of that must be pryed out and lifted up to remove. Take the back cover off. Lift out the top of the LCD screen and remove the 4 screws that hold it in. Start a new row of removed screws. The LCD ribbon can be removed by popping the white plastic clasp up. Next remove the menu pad ribbon from the board by lightly tugging on it. You should be able to remove the front cover by lifting it up to unhook it from the top power button strip. There are 2 screws that hold the top power strip in place. There is also a plastic hook on the front side. There are 6 screws holdong the board to the frame. A different size screw is located underneath the power strip ribbon. Loosen the 2 screws holding the flash.  THe white ribbon will be the flash ribbon and the gold one next to it will be the lens ribbon. NOTICE the lens ribbon must pass under the flash.  The side with the lens will have a small board that pushes into the main board.  To seperate it, gently pry it apart with a small flathead. There is a hidden screw for the board at the top where the end of the battery compartment. It needs to be removed before the board will come out. Once the board is out, there are three screws holding the lens in the case (they are black screws, not the chrome ones)  Once they are removed, the lense will fall out. There are 3 black screws holding the largest motor on the lens.  They are above the text "Sony Lens" remove those and the gears of the lense will be able to move freely. Twist the base to get the lense unstuck.
Posted on Feb 04, 2009
  • 11967 Answers
SOURCE: turn camera on, lens goes in and out then camera shuts off
Is it possible that at one time, the camera automatically powered off to save the battery. In this state, the press of any button starts it back up again. If while in this state, you put the camera in a case and the lens tried to open, the force may have caused your problem.
Posted on Aug 28, 2009
  • 11967 Answers
SOURCE: dropped camera (c5060 WZ), lens jammed wont
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 01, 2010
  • 11967 Answers
SOURCE: Clicking noise when PowerShot S3 lens extends and retracts
Save this for the future if and when a "lens error" appears: Fixing a Lens Error on a Digital Camera
Posted on Jul 10, 2010
duane_wong
  • 6826 Answers
SOURCE: M863 lens extends and then immediately retracts
Kodak Easyshare cameras use Li ion batteries, as recommended by the manufacturer, which have higher voltages but not necessarily higher amp hours per battery pack.
When I first bought my 14.1 megapixel camera from Kodak, I tried various batteries, including Alkaline, Ni MH, and they didn't work very long before needing replacement or recharging.
This is because the voltage isn't enough on other batteries.
I do not understand why they make it this way, because it fooled me a lot. I thought that since it had a AA format that it would be alright to use AA batteries of any type in the camera. But, this is not so, in my experience.
Good luck getting your camera to work with new Li Ion Batteries.
Note: if the Li Ion batteries do not work, then there is something wrong internally with your camera.
Contact kodak.com to see if it is economically repairable.
Thanks for asking a question on Fixya.com.
Posted on Jul 24, 2010
Lens jammed will not extend
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Sep 27, 2011 | Nikon COOLPIX 5100 Digital Camera
Jammed lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 31, 2010 | Sony Cyber-Shot DSC-L1 Digital Camera
Lens error lens is jammed i let camera fall could You please give me a contact so that i can use from Northern Ireland
Oct 14, 2010 | Cameras
I have dropped my friends camera (while it was on). It hit telescope first and got jammed is there anything I can do? It is an olympus stylus 760 7.1 All-Weather. It was purchased on ebay about 6 months...
Don't want to get your hopes up too high, but here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 15, 2009 | Olympus Stylus 760 Digital Camera
The lens does not fully retract when turning the camera off, i think the kids have dropped the camera on the front when the lens was out
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 16, 2009 | Canon PowerShot A75 Digital Camera
We drop the camera head first meaning all three lens were open and it jammed in and the lens wont come out and everytime we turn it on it says reset lens what do we do?
Oct 11, 2009 | Canon PowerShot A630 Digital Camera
Jammed lerns
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 17, 2009 | Kodak EasyShare C743 Digital Camera
Lens is jammed for Canon Powershot SD200
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Jan 05, 2009 | Canon PowerShot A470 Digital Camera
Photosmart m627 camera
It sound like a problem with the zooming mechanism, does your camera was dropped down ? In case it dosen't, since your camera is still under warranty, best thing will be sending it to the appropriate factory service center for repair the problem. Good luck!
Aug 13, 2007 | HP PhotoSmart M627 Digital Camera
Camera problem
hi first of all change the battries it sounds like a card problem try finding another 1 before buying 1 and see if it helps good luck
Apr 17, 2006 | Sony Cyber-Shot DSC-W5 Digital Camera
Kodak EasyShare LS443 Digital Camera Logo
23 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
