Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer set that I really like.  Except, recently the dryer will stop tumbling every time it changes direction (it has a 2-way tumble action).  I am wondering if this is a simple matter of tightening a belt or if the machine needs to be replaced.
Thanks for any solutions you can offer.
  • Anonymous Jul 02, 2008
    does not tumble at initial fill
  • phinch Dec 09, 2008
    Same thing. everytime it need to change diection, it stops. Please HELP!
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Posted on Dec 26, 2007
Kenmore 417.80042990 (10 year old) dryer makes a squeak as it tumbles the clothes dry. Seems to be worse as the clothes get dryer. FYI-the felt was replaced about 4 years ago, not sure it's that. But...
this is a frigidaire made dryer with kenmores name on it. The drum bearing needs more grease. You really need to know what your doing before you take that job on yourself. Its easy for me...but I have been doing it for 20 years and thats the way I role
Nov 11, 2009 | Kenmore 98702 Stacked Washer/Dryer
The dryer heats but will not tumble. I am
if the belt was broken, the safety switch would shut off the machine. the belt is probably slipping, stretched from age. replace belt
Jul 09, 2009 | Frigidaire FGX831C Top Load Stacked Washer...
Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
Dec 29, 2007 | Frigidaire FEQ332E Electric Dryer
Directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Nov 12, 2007 | Frigidaire GLTF2940ES Front Load Washer
Squeaking noise from Dryer when tumbling
IT IS USUALLY THE "BELT TENSION ADJUSTABLE PULLEY". MOST ARE CHEAPLY MADE ... TRY A BIT OF AXLE GREESE ON IT ... IT IS SEALED FROM THE INNER DRUM AND IS MOUNTED USUALLY ON THE BOTTOM FRAME RAILING.
Jun 25, 2007 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
1,580 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
