Question about Epson Stylus Photo R320 InkJet Printer
Dark red prints with lines throught the picture
We recently changed the print cartridges and now my pictures are coming out very dark and red with lines through them. Help?
  • Epson Master
  • 1,879 Answers
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
Posted on Jan 03, 2008
Printing with horizontal dark lines
Did the dark lines start after the change? If so, maybe the drum on one of the cartridges is damaged. (Since you mentioned dark, I'd suspect the black cartridge.) Try replacing cartridges.
If that doesn't fix it, you can send it in for repair if it's under warranty. If it's outside warranty, I'd probably just replace it, unless you want to learn a lot about the innards of a laser printer.
Apr 21, 2015 | Dell 3110cn Laser Printer
Printer gives warning that toner life is gone. I replace the toner twice . Each time it prints one page and then gives error message. Page that did print out has dark horizonal lines.
Check the toner cartridge, side gears, you can see a reset lever (that lever is very important) show in the next picture.(cartridge new)
Jun 28, 2011 | Brother MFC 7840W Printer
The printer is printing dark vertical line on the
90% or more of the time on this printer dark lines are coming from your toner/drum cartridge. You can verify this by changing cartridges if you have a spare. If you don't then remove the cartridge and look at the colored cylinder in the cartridge and see if the same "lines" are on the cylinder that are on your prints. This will tell you for sure that the cartridge is bad.
Dec 13, 2009 | Samsung ML2250 Laser Printer
Printed pages come out with dark lines under each line of print
Find your printer's "Maintenance" menu, in its "Toolbox" or from the Start Menu.
Preform a cartridge or head cleaning, that should solve your issue. If not, try replacing the cartridges with new ones.
Hope I helped,
Jun 21, 2009 | HP Photosmart C5280 Printer
Photos too red
Reset your printer to factory settings and try again
Nov 05, 2008 | Canon PIXMA iP1600 Printer
Horizontal lines in pictures
If you are using original cartridges then there should not be a problem. The horizontal lines come from the cartridge. Can you pinpoint if it is a color or black line that is missing? My guess is that during the alignment procedure, you are asked to choose a number or letter that corresponds to picture of a the lines that show the best alignment. If you did this correctly, may I ask how many pictures you printed before seeing that line. Is it on the first print or 10th printing? Cuz if it is on the 5th or more full color picture, then the problem is that you you really have the wrong printer. The F380 capacity for printing full color pictures is miniscule. 1 ml per color. So usually after the 3rd color picture, the ink starts to run out. Let me know if this helps.
Apr 23, 2008 | HP DeskJet F380 All-In-One Printer
Prints have a dark shade
Test page printed properly. Don't know what to look for in the test page or the applications. the cartridge was changed recently
Feb 24, 2008 | Brother MFC 9700 All-In-One Laser Printer
Epson r300 photos print very dark
I had a problem with my colour. I discovered that I had left the tab covering one of the holes on at the top of the of one of the cartridges. Suggest that you check all the cartridges again. Hope that this helps
Nov 22, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R320 InkJet Printer Logo
101 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
