Your Gateway MSI MS-7399 has the following chipset GeForce 7100/nForce 630i
This chipset supports the following FSB 800/1066/1333. So you can use the E8400 processor, provided you have the correct socket..
Please leave me comment, if you need further assistance
RNJ VINODKUMAR
Posted on Oct 10, 2009
Yes and Yes. Here's a bit more detail:
CPU
Supports Intel Core 2 Series (Extreme/Quad/Duo)
Supports Intel Pentium Dual Core Series
Supports Intel Pentium D Series
Supports Intel Pentium 4 5xx/6xx Series
Supports Intel Celeron D 3xx/4xx Series
Supports Intel 45nm Series CPU
Chipset
NVIDIA GeForce 7100
NVIDIA GeForce N73 GMCP
Hyper Transport Interconnect
System Memory
2 DDR2 SDRAM 240pin DIMM Sockets
[u]Supports DDR2-533/667/800MHz[/u]
64bit Single Channel
Supports up to 4GB Total Memory (2x 2GB)
Bus Frequency
100/133/200/266/333MHz Internal
400/533/800/1066/1333MHz External
P4 Bus Architecture
Expansion Slots
1 PCI Express x16
1 PCI Express x1
2 PCI
Connectivity
1 Parallel ATA port supporting 2 IDE Drives
4 Serial ATA ports
1 Gigabit Ethernet Port
Expansion Ports
1 PS2 Keyboard Port
1 PS2 Mouse Port
10 USB 2.0 Ports (4 rear accessible, 6 via expansion bracket)
6 Stereo Audio Ports
1 RCA SPDIF Port
2 Firewire ports (1 rear accessible, 1 via expansion bracket)
1 RGB D-SUB VGA Port
1 HDMI Video/Audio port
Posted on Oct 06, 2009
THE RATED FSB FOR THIS BOARD IS 800MHZ
Posted on Oct 05, 2009
Unfortunately you can get it to do what you wantas the mobo simply wont go that far. It will basically carash out at around 3GHz. If you get hold of a P31 then you can go to 4.25Ghz or thereabouts!
Jun 17, 2012 | Foxconn 45CMX socket LGA775 motherboard...
May 06, 2012 | Foxconn P9657AA-8EKRS2H (6938279104065)...
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
Sep 02, 2011 | Computers & Internet
Mar 02, 2011 | Biostar G31D-M7 Motherboard
Oct 19, 2010 | Intel Desktop Board D845EPIL Motherboard
Oct 10, 2009 | Computers & Internet
Sep 06, 2008 | Computers & Internet
Jul 06, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Apr 24, 2008 | PC Chips P23G Motherboard
117 people viewed this question
I have a gateway msi ms-7399 motherboard. I want to know how far I can go with the fsb. I already upgraded to an E6300 2.8 ghz w/FSB at1066. I wanted to know if I could install an E8400 at 3.0 ghz w/ FSB 1333?
I understand that that the rarted fsb is 800 but I already up it by installing an E6300 with a fsb at 1066 and the motherboard reconizes it and works fine. My question is can I go higher to an E8400 with a FSB at 1333? I started out with an E5200 at 800 fsb. please help Marc
Ted so if I go out and buy the E8400 my motherboard will accept the 1333 FSB without any problems
TED,
I appreiciate your help. I can't overclock my computer so I wanted to get the max out of it by replacing the processor. First I was gona go with the E7500 because I wasn't sure if my motherboards FSB went as high as 1333. I know it accepts the 1066 because, I put an E6300 in at 1066 and it runs fine. So you are sure that my motherboard will accept the E8400 at 1333 FSB. I just don't want to buy it and then it doesn't work or worse.
The E8400 runs at 3.0 GHZ with a FSB at 1333.
The E7500 runs at 2.93 GHZ with a FSB at 1066. I'm sorry to bother you like this I just want to be sure I can use the E8400.
I had gotten one responce from another techie saying that my mother board can't go over 3.0 GHZ, Then I got your responce and I was releaved when you said I could use the E8400. So if you could double check for me I waould greatly apreaciate it thanks so much for your time. Marcmd3
I have a gateway DX4720-03, I want to know if I can drop an E8400 in it. I started with an E5200 at 800 FSB, Then I put an E6300 at 1066 FSB. I saw better performance. Now I want to know if I can go futher to an E8400 at 1333 FSB. ITS the motherboards FSB Max I'm worried about. (MSI ms-7399)
Thanks for your time. I greatly aprieate it. I had a couple of replys from some guys that didn't really look into it, and they gave me beat info. Thanks I'm happy I don't haver to buy a motherboard now. All I wanted to do was up the ram speed and the processor and now I know I can. Thanks, Marc
