Question about Polaroid i735 Digital Camera
When tryin to cut on just beeps 3x and cuts off.
When I try to cut the Polaroid i735 on the red light flashes 3x and it beeps 3x then cuts off.I have tried changing out the batteries, wiping the inside out, and changing batteries again. I've also tried different brands of batteries and it still will not cut on. The focus/lens part of the camera is out like its cut on and will not go back in when trying to cut camera on.
MarkDay
  • 111 Answers
SOURCE: New POLAROID i735--CARD ERROR
Fresh SD cards must be formatted before being used. Use the camera's menu options to format the card.
Posted on May 21, 2008
SOURCE: polaroid i735 digital camera troubleshooting
the same thing happens to my camera. did u ever end up fixing it
Posted on Jun 14, 2008
SOURCE: Polaroid i735 Camera won't turn on. Lens stuck.
try ENERGIZER BATTERIES!!!!!!
Posted on Oct 29, 2008
  • 102366 Answers
SOURCE: Polaroid Digital Camera 3x optical zoom lens 8.0 Megapixal
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Posted on Mar 09, 2010
  • 11967 Answers
SOURCE: my polaroid i830 won't come on - the lens is stuck
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 28, 2010
My ps3 cut out and wont turn back on
my ps3 cut out whilst playing it now won't switch on
Mar 15, 2010 | Sony Playstation 3 (PS3) Console
My playstation3 just cut off in middle of game, red
Thats the red light of death.
Visit this website if you want information on how to fix it.
Feb 26, 2010 | Sony Playstation 3 (PS3) Console
My polaroid i735 camera keep cutting off after replacing the batteries
You have to get rechargables... I had the same problem.
Jan 09, 2009 | Cameras
Polaroid i735 camera
you have to get rechargable batteries, they work great in it.
Jan 09, 2009 | Polaroid i735 Digital Camera
Camera Trouble
Check your batteries. If it is not the batteries then it is the power board of the camera
Dec 31, 2008 | Polaroid i735 Digital Camera
We would like to know how to use the timer
My Sony digital camera 8.5 mf not taking the picture. When open the flash door. it shows blank screen. While trying to take photo it flashing light is working fine but no photo absorbed image.
Any know how to resolve this issue.
Dec 17, 2008 | Polaroid i735 Digital Camera
My camarea wont turn on!
There are two types of batteries that are suitable for your camera: Alkaline and NiMH
make sure that your batteries are made for a digital camera these seem to fit a bit differently into the digital camera then standard AA batteries.
but what you are saying is ushally the cause of the batteries and nothing to do with the camera, when the unit does power up make sure in the menu the right battery is selected for the camera as well.
Nov 28, 2008 | Polaroid i735 Digital Camera
I had the same problem, and fixed it by wiggling the lens a little, when turning it on.
After a few tries, it finally wiggled free, and the lens retracted.
Jul 05, 2008 | Polaroid I533P Digital Camera
Polaroid i735 Digital Camera Logo
18 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
