Question about HP DeskJet F4280 All In One Printer InkJet
Why my printer does not print well when i replaaced the ink
When i placed the ink inside the machine ,a green light flashes nest the balck ink and the letter E lightened ,wut to do
  • 74 Answers
Try to clean and aligned your toner cartridge coz i think when you installed new toner/catridge you did not do that.
Posted on Oct 05, 2009
Canon ip100 portable printer ink cradle stuck on right hand side
I had this same problem. Count the number of blinks in sequence of the error light. it will flash green and yellow, and then just straight yellow for a number of flashes, then it will flash green again and the same number of yellow flashes again. Here is the diagnostic guide.
Two flashes: Printer is out of paper. Paper does not feed
Three flashes: Paper jam
Four Flashes: The Print Head Lock Lever is not locked properly / Ink tank is not installed properly. / Ink may have run out
Five flashes: Print Head is not installed./ Print Head is defective
Eight flashes: Ink absorber is almost full
Nine flashes:No response from connected digital camera or video camcorder/Connected digital camera or video camcorder is not compatible with this printer./PictBridge compliant devices are attached to both Direct Print Port and Bluetooth Unit Connector
Eleven flashes: Automatic Print Head Alignment failed
Twelve Flashes: Low battery level
Fifteen Flashes: Ink tank cannot be recognized
Seventeen Flashes: Ink has run out
Eighteen Flashes: Printer detected ink out condition
Nineteen Flashes: A USB hub is connected
Mine had 10 Flashes and the Print Carriage, was bad. Cost almost as much as another printer so thats what I did. I did take it apart and got it unstuck, but still didn't work.
Mar 10, 2014 | Canon iP100 Portable Printer
EPSON SX445W PAPER JAMS
A friend had a similar problem, but I've now diagnosed and fixed it.
In this case the print head was not returning to its little 'nest' on the right. It turned out that the white plastic bits in tht nest were lifted up; when I pushed them down the print head could return home and it stopped saying paper-jam. By this time, I had the printer apart and I found a spring floating around loose, and a bit of black plastic that looked like a spring connection point that had broken off. It turned out to be one of the springs holding the 'nest' plastics in place. The bit of black plastic had broken off the base of the printer.
I melted a hole through from the inside with a fine soldering iron, then fitted a small bolt and nut of about the right length to stick up inside and hold the spring. I fitted the spring over the bolt and put a pair of nuts locked together on the end of the bolt and lock-nut to keep the spring in place.
It now works!
Apr 07, 2013 | Epson Stylus Photo R320 InkJet Printer
Please tell me how do I change the ink cartridge in my Epson TX650?
1) Looking at the front of the printer/scanner there is an indent on the left hand.
2) Lifting up on this portion should reveal the inside of the printer.
DO NOT touch the flat cable inside the printer, DO NOT force the lid, it should open easily.
3) The ink cartridge is underneath the plastic cover in the back right-hand side of the printer. Gently pull up on the cover until it swings open.
4) pinch the clips holding the ink cartridge in the printer and pull up.
5) Unpack the new ink cartridge.
6) Remove the tape that is on the ink cartridge.
(If you forget this step the printer won't print. If that happens, remove the new cartridge, remove the tape and then reinsert the cartridge)
7) Insert the ink cartridge and push gently until it clicks into place.
8) Close the cover over the ink cartridges, and then close the printer cover.
9) Follow any direction on the front display (hit OK)
May 07, 2011 | Computers & Internet
I installed a new black ink cartridge. The printer won't print. The red ink light is on permanently. I have pressed it for 6 seconds, but it and the green light just flashes continously. I have waited for...
try to clean whit alcohol the contats of the ink cartridge and the place where the cartridge joins the printer, probably there is dry ink on the printer.
Feb 09, 2011 | Office Equipment & Supplies
Won't print. Green Light Flashes.
Waste ink absorberfullor platen waste ink
absorber full Pressing the OK button
will clean the error, and
enable to print.
In repair,
<Replacement of Ink
absorber kit
<Replacement of Platen
waste ink absorber
Waste ink absorber full
warning (service call
error) may appear.
Oct 08, 2009 | Canon PIXMA iP1600 Printer
Flashing amber light on printer
As you give print command check what is the error msg flashes on ur PC.
Next check whether any paper piece is jammed inside the printer, dust it with Airblower so that cleans out.
Third check the ink levels in both color and black cartdriges.
Regards
Oct 03, 2009 | Office Equipment & Supplies
Epson stylus 1280 printer
Based on the lights you are already out of one or more ink cartridge or an ink cartridge is not being recognized/expended.
-You cannot print if any ink cartridge is expended.
-Leave the empty cartridge installed in the printer until you have obtained a replacement.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
1. Open the printer cover and press the INK REPLACEMENT button, located under the printer's cover. The print head moves to the center and the lights flash.
2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
6. Press down firmly on the ink cartridge clamp until it snaps in place.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8.
8. Press the INK REPLACEMENT button and close the printer cover. The printer begins charging the ink delivery system.
9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
Jun 17, 2008 | Epson Stylus Photo 1280 InkJet Printer
D1360 black ink didn't print and green light keep flashing
just unplug the power cable and usb cable from the back side of the printer and let it be for an hour it will help
Apr 15, 2008 | HP Deskjet D2360 InkJet Printer
Epson C45(Red and Green light flashing alternately)
The waste ink collector pads are getting full and this is a protection indicator.
Either get the machine serviced or it may be cheaper to replace it-[depending where you live]
There are tricks to keep the machine going- but eventually the you will get ink leaking all over the place.
Take a look at www.fixyourownprinter.com
Dec 21, 2007 | Epson Stylus C46 InkJet Printer
Problem with printing
Sorry the manual doesn't help much either... this is what it says, "POWER lamp flashes alternate green and orange Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on. If the problem remains, contact a Canon service representative."
You could try the following reset code which works when reseting after emptying the waste ink tank:
Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Hope it helps
Oct 03, 2006 | Canon i80 InkJet Printer
HP DeskJet F4280 All In One Printer InkJet Logo
100 people viewed this question
Seeker5211
Seeker5211
