Question about Philips Televison & Video
Not a good picture and has dark line about 4to6" wide on right side
  • 336 Answers
Hi,it souinds like an issue with the DMD board if its a Dlp if a Lcd rear projection it has to do with the light engine.
Posted on Oct 05, 2009
Line on right side of copy from epson nx415
It sounds to me that there is an actual leak from the printer when in use. You need to have it serviced.
Mar 07, 2014 | Epson Stylus Nx415 Color Inkjet Printer...
I have a dark line on the right side of the screen
If there is a dark line with two sources such as a dvd player, and a game system, or a cable box, then the tv will need to be repaired. If not from two sources then the issue is with the only source causing the black line.
May 05, 2010 | RCA Scenium D40W20 40" Rear Projection...
A dark but transparent horizontal line has appeared about 20% down from the top. Any suggestions? Originally there was a dark horizontal line almost in the center of the screen. I would go away after of...
Mine had the horizontal lines you are talking about. 1st check a test picture. Click on Menu, then Settings, then go to Product Support. From there click System Diagnosis and go to bottom and click on sample picture. If you see the same problem there, then you may want to research the possibility of installing a t-con board. You may want to try calling Sony 1st and have them walk you through the basic service repair items. I was very lucky and installed a new t-con board I purchased with all the other boards on Ebay. Good luck with solving your problem! Ron
Nov 26, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Black line about 1 1/2 inches wide down side of faxes or copies
if your RECEIVED faxes look good, then leroyal is dead on. you will need a new CIS which stands for contact image sensor. if you have an authorized brother service center nearby, they may be able to do it for 100 to 150.00, depending on their pricing of course. if rec'd faxes are bad also, pull drum out and make sure the blue tab on top of drum is all the way to the right side, although that usually only leaves about a 1/2" black band.
hth,
razors
Jan 27, 2009 | Brother IntelliFAX 4100 Laser Fax
Dark lines on the sscreen
This indicates that there are bad connections in the cabling going to the display panel. Usually there are tiny connections along the top of the panel that rely upon pressure to hold the contact material to the panel contact and if the assembly is not right, gaps form in the picture like you describe. Sometimes just sqeezing on the units cabinet in the area of the gaps is enough to affect the problem. May need to go inside and work on the contact assembly.
Dec 30, 2007 | Protron PLTV-32 Television
HP 2600N dark gray line down the left side
Maybe your transfer belt is damaged. If u have an spare belt replace it for a test. Answer me if it dont work. Maybe i can get an support manual for u. I work in a HP partner company.
Good luck
Dec 15, 2007 | HP Color LaserJet 2600n Printer
Line in center of screen
if the line is about one inch wide you may have a chance that the address board has failed, if it is only 1 pixel wide then there is a really good possibility that the plasma panel itself if bad, this set had a 2 year warranty from samsung, you might want to give them a call,,they are very customer satisfaction oriented
Nov 28, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Bowing in the middle like an hour glass
OUCH!!!! Don't kick me...would be my response if I were your TV
Convergence amps problem.
If it works after a kick I'd say poor solder joints on the convergence amp leads
Dec 17, 2006 | Zenith IQB50M90W 50" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
