Question about Dell Latitude D800 Notebook
I just need to know how to remove the little cables
I just need to know how to remove the little mini coax cables from the wireless lan cards???
  • 555 Answers
Just pry carefully each connector. Try not to use a metal screwdriver. You can use a plastic part. If no plastic screwdriver is available, use a wooden stick or something that will not damage the pcb. Pry and pull straight the connector. To connect it back to the board, push it gently straight until it locks.
Posted on Oct 05, 2009
Why wireless mini lan card driver not working?
Inform your device details.
You can do: Uninstall the Wireless Mini Lan Card Driver software and reinstall it.
Feb 16, 2013 | Dell Vostro 1520 Laptop/notebook For Parts...
Need isatap driver for vista
im assuming its a laptop computer
Turn the laptop over and remove the battery.
Remove the screws that are used to secure the memory/wireless LAN minicard cover with a Phillips-head screwdriver. Lift the edge of the cover to remove it.
Disconnect the antenna cables from the wireless LAN minicard with the needle-nosed pliers.
Locate the screws that are used to secure the wireless LAN minicard to the motherboard and remove them with the Phillips-head screwdriver.
Pull the wireless LAN minicard out by grabbing the card by the edges.
Reinsert the wireless LAN minicard and push down on the card to set it in place.
Tighten the screws to secure the card to the motherboard.
Replace the antenna cables with the needle-nosed pliers.
Replace the memory/wireless LAN minicard cover and secure it with the screws.
Replace the battery and then turn on the laptop. Windows Vista will load and reinstall the drivers for the ISATAP adapter.
hope this helps
Sep 22, 2012 | Asrock K8Upgrade-VM800 Motherboard
How do i replace the wireless card in my lenovo 3000
Access for the wireless card is under the access door for the hard drive. The guide below is for both wireless "B" and "G" cards which have two wires. It also has the reattachment guide for wireless "N" cards that have three wires. The attachment guide is below for proper lead placement. a link below wil take you to the service manual for this laptop, the numbers for illustrations match the repair manual.
1040 PCI Express Mini Card for 802.11 a/b/g wireless LAN
For access, remove these FRUs in order:
v “1010 Battery pack” on page 46
v “1020 Hard disk drive slot cover” on page 47
In step 2, unplug the jacks by using the removal tool antenna RF connector
(P/N: 08K7159) or pick the connectors with your fingers and gently unplug them
in direction of the arrow.
When installing: Plug the white cable into the jack labeled MAIN on the card,
and the black cable into the jack labeled AUX.
When installing: Plug the black cable (MAIN) into the jack labeled 1 on the card,
the white cable (AUX) into the jack labeled 2, and the gray cable
(MIMO) into the jack labeled 3 on the card.
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/42x3553_03.pdf
Nov 29, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Driver needed
www.bioticaindia.com/bcm94306mp.html This is driver location for vista
May 12, 2009 | Broadcom BCM94306MP - IEEE 802.11b/g...
Wireless lan networking for toshiba satellite 1900
Not enough info per problem description. Not all 1900 series laptops have wireless cards installed, and not all 1900 series laptops are ready to handle wireless cards, either. Need to know what model your computer is, what wireless card you're using, ... C'mon. Let's have it...
Mar 19, 2009 | Intel Toshiba Satellite Mini-PCI Laptop...
Wireless adapter
check the ettings on the router have not been altered. the chance of 2 wireless cards failing in the same time, on different pcs is very small, more likely the settings that allow connection in the router, the item common to both, have been changed, reinstalling the router has no effect on user settings,
WEP, encryption, MAC controls are all possible suspects, if there has been any change
lock down the router,
many wireless networks are unsecured at the router so that any person driving past can access your router and alter it, default security settings should be changed the day you turn it on
Jun 28, 2008 | Computers & Internet
Wireless internet problem
Hi
I think your Operating System (OS) software installed after formatting does not have drivers for the wireless network card.
You did not provide any clues about the OS and the Network (Model/Brand) installed.
Dell Inspiron 6000 did ship with Windows XP as the Default OS and Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card or Intel PRO Wireless 2200BG, 2915ABG Wireless LAN Mini Cards as options
First, check the Original System Configuration to find out the built specification of the Inspiron 6000.
Enter you system tag. Click on the Original System Configuration Tab. Check the factory built specification and note the Wireless Card installed from the factory. If you have not changed or upgraded the Wireless Card, download and install the drivers from the list below.
Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card Drivers
Intel PRO/Wireless 2200BG / 2915ABG Wireless LAN Mini Card Drivers
I am almost sure you will need drivers for the Chipset, onboard network and video.
Intel Mobile Chipset
Broadcom 440x 10/100 Integrated Controller Driver v.4.25
Video (as above check the factory spec if you ordered the ATI MobilityRadeon X300)
Intel Graphics Video (onboard) Driver v.6.14.10.4609
ATI MobilityRadeon X300 Driver v.8.162-050803a2-025823C
Let me know how you get on.
Mike
May 29, 2008 | Dell Inspiron 6000 Notebook
My laptop cannot connect to my local network (LAN)
Assuming you initially set up the router using the wired lan adapter and lead, enabled DHCP in the settings. First stand right next to your router; Dells wireless is a little tempremental, go to control panel and in there should be Dell wireless monitor, open this up refresh it and see if it finds any wireless networks, if so try to connect. Dissable your wired network lan adapter. Go to the properties of your wireless card and on the TCP/IP line click properties again and ensure that obtain an ip address automatically is selected, press ok and restart the pc.
Sep 20, 2007 | Dell 1470 (W9284) 802.11a/g/b Wireless...
Dell Latitude D800 Notebook Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
