Question about Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder
Cannot get any digital channels since local digital switch over
I receive signals from winter hill. received message on my DMR asking me to retune. I retuned with no problem several days ago. Today, 5th October, I lost some channels and when I re-tuned it I now get no channels. The EPG shows my channels and what's on! but the channels states "no signal". Any views?
    Brigadier General:
  • 3,006 Answers
The official line on this is that you should try and retune again, but there are some Panasonic models with similar model numbers to yours which have been specifically identified as having incompatibility problems with the Freeview retune.
However, your model is definitely not one which appears on the problem list, so it's worth checking that your aerial wasn't misaligned or damaged during the gales last weekend. In addition the Winter Hill transmitter is currently undergoing work until December which will significantly boost the digital signal and give it HDTV capability, so your box may have have been knocked out of kilter if the current digital service was temporarily operating at restricted capacity. Digital signals are by their nature much weaker than analogue tv and if you have a marginal aerial system which has been up for many years and which feeds a number of televisions in the house then it's definitely a good idea to see about upgrading your aerial system.
The difference in actual parts costs between a top spec aerial system and a poor one are surprisingly low, it's also easily possible with careful design and installation to get a better performance with poor parts than you can get with a poorly designed and installed system using top quality parts. One thing does hold true though: a well designed and installed system using poor parts will only last a few years before needing serious attention but a proper job can last up to thirty years.
If you're sure about your aerial system and retuning does not help, then you'll need to contact Panasonic directly. The first web address below will give you their contact number along with a list of Freeview boxes with known retune issues. A second web address which I've given takes you to an excellent Sheffield based tv aerial company which has an incredibly informative website.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
http://www.aerialsandtv.com/index.html#ATVinfo
I hope that you've found my answer to be helpful and ask only that you return the favour by rating my answer.
Posted on Oct 05, 2009
  • fraseratpu Jun 27, 2011
    I phoned up Pana and apparently no amount of resetting or retuning the box will get it to work after the Digital Switch-over, so you need a software update disc for the machine which they will send you if you phone them up.
    This was on the DMR-EX75.
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
Can the Panasonic DMR-EH55 be made to receive digital channels? e.g. via a digital capable TV or a set top box? If not, I suspect it will be obsolete when analogue channels cease this year (in Australia)
If you receive your channels through your local cable company, nothing will change. The DMR-EH55 will continue to work normally.
If you receive your channels with your rooftop antenna you'll need a Digital to Analog TV Converter Box. The unit itself will not receive digital signals directly.
Jan 16, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
Hi retuned my humax pvr9300t and it has retuned but bbc1 and 2 have come up as wales when should of retuned to winter hill as i'm in the granada area my postcode is pr253ss please advise what to do
sounds like you are now picking up 2 transmitters, 1 Winter Hill, 1 welsh- Moel y parc. Due to the increased strength of the new Moel y parc signal
see http://www.digitaluk.co.uk/postcodechecker/main/trade/pr25+3ss/1/0
You can see its the channel 46 in orange thats your problem
Do the same retune but unplug the aerial until it gets past 46 so that it only finds the channels 56 and above that are from Winter Hill.
Bad news is that for you it gets worse when the extra channels come on next month. Looking at the aerial and maybe playing with attenuators might filter out the Welsh one
Nov 06, 2009 | Humax DRT800 TiVo Video Recorder
Since retuning I have lost BBC 1,2,3,4 & Ceebeebees. I receive my transmission from Winter Hill, and have a Digifusion FRT 101 set top box connected to an Alba CTV3485SIL TV. I also use a Humax...
sounds like you need to rescan for channels, Should be in settings menu then maybe channels, Normally autoscan or channel update, Also make sure your airiel is good.
Nov 05, 2009 | Televison & Video
My PVR has retuned (DSO)to the wrong transmitter. I receive signals from the Winter Hill transmitter and live in SW Cumbria. My Humax 9200T has retuned ok but my older 8000T has retuned to a transmitter in...
Not a complete solution but after much fruitless fiddling through the menu I eventually found that the programmes were actually there but under different channel numbers.
I searched a long way down the LIST of channels (on remote) The BBC1 channel I want is now 800 BBC. Selecting 1 on the remote still brings up BBC Wales.
This applies to my Humax 8000T PVR - I can't comment on other makes of Freeview box.
PVR9200T very slow to react to remote control
I have 5 customers machines doing the same. rang Humax today. They are working on the fix..and hope to have an OTA update at the end of the month....keep you fingers crossed eh?
Oct 11, 2009 | Humax Televison & Video
Can not get any digital progams now that I have retuned my panasonic dmr-ex75eb dvd recorder. Am not receiving any digital signals
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Sep 30, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I cant receive freeveiw channels
I don't know what make of TV you have but some manufacturers have two tuners at the rear of the TV. One for terrestrial signal & one for digital signal. If this is the case put the aerial into the digital input & try retuning. If this does not work then if you could provide the details of you TV eg. make & model, then I will try to help you further.
Jun 29, 2009 | Televison & Video
Picture freeze lockup and no sound
It Was Solved by removeing the unit from its present site and retuned unit to winter hill in a good signal area, when unit was returned to original site it was retuned again. and operated ok. as to what was the course i have not a clue, can only think that due to thie site being a fringe signal area may be the transmitter was on reduced power or something?
Apr 10, 2009 | Humax DRT800
Sanyo model HT27547 installed to Dishnetwork satellite.
the model you listed will receive digital rf signals without the need for a converter box. the link below is a link to the owners manual for your set, in it you will see what to do to get your local station once the television signals switch to all digital broadcasts.
http://www.sanyotv.com/HT27547%20(E)%200255A-.pdf
Please take the time to rate this solution.
Dec 26, 2008 | Sanyo HT27546 TV
Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder Logo
723 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
