Question about Samsung PCN5425R 54" Rear Projection Television
Tv turns on and off by itself when plugged in
    Novelist:
  • 157 Answers
It sounds like the power supply is bad. It is also possible that the main board is defective. The TV is most likely doing the following:
1. Trying to turn itself on
2. Unable to sustain the correct voltages
3. Puts itself in protection to avoid damaging the components by turning itself off
4. Repeat step 1
You can do a visual inspection for any bad capacitors that look bubbly first but would need the service manual and a voltmeter before finding out which part is needed. It is most likely the power supply not giving the correct voltages but the main board that is putting the TV into protect. The voltages need to be checked in order to see which one needs to be fixed.
Posted on Oct 06, 2009
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
-Plugged into wall -Red LED on -Remote and side POWER ON/OFF will not turn TV on. -unplugged and waited over night then plugged in and it worked fine until later that day. TV turned itself off. Now...
Did you ever got the solution for this problem?
I have the same, I did notice that when I lift my tv from the bottom, attached to the wall support the tv turn on by itself, weird no?
Jun 22, 2011 | Samsung LN52B530 LCD TV
I have 20MC4306. Recently when you turn it off it turns itself back on. Also when you turn it on shuts off after 2 seconds. Tried putting in a video vhs then press play and wait few seconds and hit...
Sometimes when the TV recives a brodcast signal for a new update to the mainframes firmware, it will have to turn itself on to install/recive the update and aslong as it is connected to a power source it can do this. hope this helped answer your question. Have a good day :)
Jan 03, 2011 | Philips Magnavox 20MC4306 20" TV/VCR/DVD
We were watching TV and the TV just turned itself off. We try turning it back on and we have a black screen for 10 seconds and then the TV turns itself off again. Called Sanyo and they said to unplug it...
Yes,unplug,replug the tv an hour later.The tv should reset itself back to factory setting and work.Not,than the tv power supply board have problems.That the board,where the power a/c coard plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 07, 2010 | Sanyo 42 in. LCD TV
Panasonic pt56wxf95a turns itself off
Did you replace the bulb? clean dust out of fans?
Apr 17, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
TV says lost signal and turns itself off
Unplug the TV from Wall, wait a bit and plug back in. Should be reset.
Feb 09, 2010 | Vizio L42HDTV 42 in. LCD Television
My 27F522T tv turns itself on and changes channels bu itself.
hi
and first of all if u dont want ur tv to turn on by itself when you dont want it to just un plug the cord and when your going to use it just plug it back on.
Sep 16, 2009 | RCA TruFlat 27F520T 27" TV
TV turns itself off.
Check for a loose wall outlet. try plugging it somwhere else. that happens to me many times. it is not your tv.
Aug 04, 2009 | Televison & Video
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Mar 24, 2017 | Sony KP-65WS500 65" Rear Projection...
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
123 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
