Question about Tatung V27DMBX 27 in. LCD Television
LCD Tatung V27DMTT-ZE1
It will not start up because of pressing power button or "Fernbedinung" cordless power transfer sorry i find not the similar word for because i am from austria english not perfect thanks
thanks for answer
5 Suggested Answers
SOURCE: tatung LCD television
The power outage simply precipitates a pre-existing flaw in the power supply unit of this TV. You will need to either order a new power supply and put it in yourself, or send it to Tatung to fix. I had the same problem. Contact this person:
Vila Khamkathok
Customer services supervisor
Tel: 800-827-2850 x161
Posted on Nov 08, 2007
SOURCE: Tatung V30DMTT 29.6 in. LCD... Problem: Faulty Power Board
Hi -I had the same problem with my tatung LDC tv. PIECE OF !@$#$#@#!!. Not knowing a whole lot about electronics, I decided well, I couldn't break it anymore, and I thought it was probably the power supply as the tv did NOTHING!!! it wouldn't light up make noise or anything. it was totally dead. I called around MANY, MANY local tv repair shops and NO ONE would work on this as they didn't have the repair parts for it. Thats what I get for going cheap. Anyway, well, I popped the back off, carefully making sure I knew where each screw went if I ever had to put it back together. Well, I located the power supply - it's pretty obvious, I removed it with a few screws and then found a company in california that repaired power supply's - I sent it off not knowing if it would solve the problem, but they quoted me $75 dollars and I figured if it didn't work $75 wasn't too much of a loss - and they said I could return it and get some of my $75 bucks back. So, I shipped it off to them. A couple weeks later, I got it back and installed it and to my amazement it worked!!! It has been working GREAT ever since. There is a few places online that sell the power supplies and offer a refund minus restocking fee if that doesn't work. Check out http://www.shopjimmy.com Good luck and hope this helps scott
Posted on Jan 31, 2008
  • 6 Answers
SOURCE: Tatung wont turn on
I have v30dmtt 29 inch tatung and had the same problem. I took the power supply out and took it to repair man. He told me it couldnt be fixed. I contacted the manufacturer and had a new one sent. The phone # is 915-771-7554 but you need to call 1-888-482-8864 to get a case #. It costs 70.00 for a new power supply unit.The part # I needed was 6693006610. I hope this helps.
Posted on Oct 21, 2008
  • 11800 Answers
SOURCE: Al 5 jaar probeer cik
Sorry, je kunt niet dat de afstandsbediening te gebruiken met die tv, is het niet steunen. Je zult naar een ander te kopen.
Posted on Oct 16, 2010
Shows picture for a second when i press button than goes dark
Issues with back light:
Please do not attempt to diagnose if no competent.
Do at your own risk.
Check for 24 Volts power to the inverter board
No Power---Check Power Supply
Power Present---
Verify status voltage 3v to 5v on inverter board harness (plug)
Replace Inverter Board
Feb 11, 2010 | Tatung V30DMTT 29.6 in. LCD Television
Tatung monitor Power light shows yellow light.
It sounds like your resolution or refresh rate is out of reach for your screen.
Restart your computer (even if it will be manually unplugging the power cable)
If you have no display while your computer starts up; you might have a hardware failure. Swapping your screen out, or plugging it into another computer (that works) will confirm if this is the issue.
If you can see the computer starting up you can press F8 (on your keyboard) continuously just before Windows can start.
Select "Safe mode" so that you will have the basics of screen settings.
Now you can go to control panel, display and click on the Settings Tab at the top. Change your settings to a rather default "1024x768" resolution and change your referesh rate to nothing more than 75hz under the advanced icon.
Hope this helps!?
Jul 07, 2009 | Tatung L17AMTN 17" Flat Panel LCD Monitor
Emprex HD-3201 will not turn on. I push power button and nothing happens.
Common problem w/Tatung-go to local computer guy and have him re-build power supply,faulty diodes
Feb 27, 2009 | Tatung V30DMTT 29.6 in. LCD Television
Tatung V30DMTT 29.6 in. LCD Television won't power on
bad power supply,common problem w/tatung,re-build power supply
Jan 04, 2009 | Tatung V30DMTT 29.6 in. LCD Television
How do i transfer calls from handset to another line or to base
  1. Press the [Int] key located in the far lower right of the handset. The LCD will display "Transfer to:."
  2. Dial the number of the handset to which you are transferring the call. The LCD will show "Calling handset B." Handset B will ring, and the LCD will show "Handset A is calling."
  3. Press the "Talk" button or any of the numeric keys to answer.
  4. View the LCD. It should display "Intercom."
  5. Press "Off/Clear" on the first handset to transfer the call.
Nov 11, 2008 | Uniden Cordless Phone
Tatung V27DMTT LCD TV (Evesham badged - UK) will not power up.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 15, 2017 | Tatung V27DMBX 27 in. LCD Television
Tatung wont turn on
Sep 08, 2008 | Tatung V23CLTT 22.92 in. LCD Television
Tatung LCD television
Vila Khamkathok
Aug 06, 2007 | Tatung V30DMTT 29.6 in. LCD Television
Elio doesnt connect
i have similar problem, i think i know why mine doesn't work. My son connected the usb port to power supply, since then the elio manager does not recognise that the player is connected.... something must have blown in the usb circuitry
Jan 29, 2007 | Tatung Elio Photo JukeBox MP3 Player
Wont recongnise music
i would rebuild the music database using this little extra program that comes with the media manager. i believe its the "ChkService.exe" in the tatung installation directory. if you start it, it goes into your windows taskbar. make a rightclick and then click on something that says "run jukebox program". you'll get a popup, that offer some options. one of them should be called "rebuild database" or something like (sorry, my version is in german). click on it. it could help.
Oct 09, 2006 | Tatung Elio Photo JukeBox MP3 Player
Tatung V27DMBX 27 in. LCD Television Logo
151 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
CoppellTVRepair.com
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
