Question about HP Photosmart 3210 Printer
Cartucce scadute non ho usato la stampante ma le cartucce sono piene,posso fare qualcosa per recuperarle?
3 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: problema di bloccaggio HP C5180, errore inchiostro 0xc18a0107
Hi no harm in trying I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
puertobori
  • 7733 Answers
SOURCE: ho una stampante hp photosmart
ve HP Support & Drivers
Posted on Oct 28, 2010
Buon giorno, la mia macchina Saeco Magic de Luxe e' appena stata in assistenza ed hanno dovuto cambiare la scheda. ora non riesco piuu' a far girare acqua nel circuito. accendo la macchina ma mi...
Anch'io ho lo stesso identico problema, l'ho smontata, ho dato un'occhiata e credo di aver capito che il problema sia la turbina (rotta) ma non ne sono sicuro..!! Ho dato un'occhiata in rete e una turbina costa circa 12 euro... credo convenga fare questo tentativo..!! Ciao Adriano
May 10, 2011 | Saeco Magic De Luxe Espresso Machine
SmartBase MP360 appena avviata per qualche secondo fa rumore di pettine contro acciaio e non funziona
Questo rumore clunking / rettifica di solito ? un ingranaggio inceppato o una barra di controllo provocando qualcosa da cedere il passo (di solito l'elastico con i denti su di essa dietro la testa). Ho risolto i problemi simili su HP e Epson e ogni volta che ha bisogno di una striscia gi? e un attento esame delle lavorazioni. con Epsons di solito era un ingranaggio che aveva saltato un dente e poi la tempistica era fuori causando un inceppamento. Con polipi iperplastici, di solito un frammento di carta nelle opere o inchiostro schizzato su uno dei tanti sensori ottici, facendo accadere le cose nell'ordine sbagliato. Il mio MP360 inceppata con i capi in sosta (ma senza clunking). Ci? ? stato causato da inchiostro secco mescolato con polvere di rendere il meccanismo di pulizia pigro e (in qualche modo) jamming la testa. Ho preso le coperte per spegnere la stampante (un lavoro lento) e pulito tutto, ri-ingrassate. problema scomparso. Attualmente ho le teste ammollo in una miscela di alcool, detersivo liquido e acqua per sbloccare le teste di nuovo.
Jan 19, 2011 | Canon Office Equipment & Supplies
Ho cambiato le cartucce alla mia stampante mp 630,mi riconosce solo il giallo e il magenta,ho fatto una 20 di volte la pulizia ma niente
Ciao.
Assicurati d'aver rimosso il nastro adesivo dalle cartucce.
Controlla i contatti dentro l'alloggiamento delle cartuccie. Eventuamente pulisci i contatti con alcol e cotone idrofilo.
Fai un test usando altre cartucce. Cartucce difettose sono un problema abbastanza comune.
Se questo non risolve il problema, e la stampane non riconosce NESSUNA cartuccia, neanche le originali. Allora qualcuno dei contatti dietro la testina e' probabilmente rotto.
Questo tipo di guasto non e' comune, di solito sono cartucce difettose, sensore nell'alloggiamento sporco, o problemi software.
Controlla anche il software stampante, reinstallalo rimuovendo prima la stampante dal pannello di controllo. Assicurati d'aver seguito la procedura di rimpiazzo usando il software Canon. Il semplice scambio di cartucce puo dare adito a problemi.
Jul 01, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Da qualche tempo la macchina perde tutta l'acqua, ho già usato il decalcificatore, ma non succede nulla. L'acqua finisce al di fuori della macchina, non nella cassettina. Trovo tutta la superficie,...
Il post e' vecchio, ma spero sia utile per altre persone con lo stesso problema.
Dopo aver cercato in lungo e in largo un modo per fermare le perdite d'acqua che oramai erano esasperanti, ho trovato la causa di tutto:
Dietro al blocco estraibile della macchina, si intravede un ulteriore sportellino innestato a pressione.
Aprendolo, ho notato che nel tempro di era totalmente intasato di polvere di caffe'.
Dopo una buona pulizia, la macchina e' tornata a funzionare senza buttare un solo goccio di acqua fuori dal vassoio di raccolta!
Buon caffe' a tutti!
Dec 06, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Does not print A3+ computer keeps feeding it out, prints all other types of documents.
HPDeskhet 1280.
Normally it is a A3 Model printer.
Check for the Printer Set up.
It should be 102 x 127 MM page size should be.
Both catridges - Black Hp51645A and HP C6578d Color should be properly installed in the printer and take a sample print out in A3 after setting the page size.
Still problem persists, will have to call the local printer engineer to set right the issue.
Have a Nice Day
Jul 16, 2009 | HP DeskJet 1280 InkJet Printer
Problema di bloccaggio HP C5180, errore inchiostro 0xc18a0107
Reset the product:
5. Wait 60 seconds.
Jun 15, 2009 | HP Photosmart C5180 All-In-One InkJet...
Mfc-210c
Se le cartucce sono rigenerate puo essere normali, certe brother non riconoscono carticce rigenerate.
controlla se hai rimosso il nastrino di plastica sulle cartucce.
Rimuovi cartucce e riprova l'installazione.
Avvia l'opzione per la sostituzione delle cartucce presente sotto menu avvio nelle opzioni brother.
Stacca prese corrente pc e stampante e stacca stampante usb per 5 minuti, riconnetti e riavvia (hard reset).
Se chai fatto tutto quello qui sopra ed hai ancora il problema, allora c'e' un guasto.
Saluti
Jul 09, 2008 | Brother MFC 210C All-In-One InkJet Printer
Not Printing.....
Dovrebbero essere le testine di stampa intasate dall'inchiostro essiccato (succede soprattutto con cartucce non originali). Prova a smontare le testine, e tenerle a bagno per una nottata in un solvente specifico (io ho usato del semplice acetone ed ha funzionato). Quindi imbevi nell'acetone un capello (non è molto elegante, ma funziona) e cerca piano piano di inserirlo nei micro fori presenti sulle punte che forano le cartucce di stampa fino a che non risulteranno pulite. Quindi rimonta il tutto ed in bocca al lupo.
Max
Dec 19, 2007 | Epson Stylus CX3200 All-In-One InkJet...
HP Photosmart 3210 Printer Logo
216 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
