Question about GE DBXR463GB Gas Dryer
Hello Sir, I have GE DVLR223GGOWW Gas Dryer. It trips after running few minutes. What is the problem? PL reply
5 Suggested Answers
  • 1122 Answers
SOURCE: Dryer starts then a few minutes later stops and is really hot
is the inside drum turning?
Posted on Oct 26, 2008
Controlfrk
  • 304 Answers
SOURCE: no heat kenmore gas dryer
Gas valve coils can be replaced. All three come as a kit. There are three because 2 are piggyback on one valve.
Posted on Aug 23, 2009
  • 491 Answers
SOURCE: Gas Dryer tripping circuit breaker
YOU HAVE A CROSSED WIRE CHECK METAL CLIP IS NOT IN CONTACT WITH ANY EXSPOSED WIRES AND MAKE SURE IGNITER IS PROPER POISTION .
Posted on Oct 22, 2009
heatman101
  • 43501 Answers
SOURCE: Hello, I have a question. My Maytag Gas Dryer only
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 28, 2010
Ge adora dhdvh66ghobb stops heating after 8 minutes
bad thermostat possibly, which will do that
May 05, 2014 | GE DHDVH52GFWW Gas Dryer
Our dryer is a GE profile gas dryer. After a couple of loads drying it will stop after about 20 minutes and we will have to restart. What is the problem?
Possible that there is lint buildup on the motor and it is shutting down on overheat. Remove front of
dryer and vacuum out lint or blow it out,BUT PLEASE disconnect unit from wall outlet or trip breaker unless you want a very tight hairdo.
Feb 11, 2011 | GE Dryers
Have had a repair man out 3 times. Replaced igniter and gas regulator. Dryer will heat for a few minutes then stop heating. When I try to turn it back on, it will not turn on at all for about 10 minutes.
Are you saying the dryer will not start again after a few minutes? That is a motor [problem. Replace motor.
Are you saying dryer starts after a few minutes but will not heat? That is an air flow problem or a gas valve coil problem. Thoroughly clean EVERY single air passage in the dryer and vent tube. If that does not cure it, then replace gas valve coils if the igniter comes on and off.
Jul 02, 2010 | GE DCVH515GF Gas Dryer
2year old ge dryer trips breaker when it's turned on, but sometimes will run a complete cycle before it shuts off.
HELLO THERE
Electric dryers require the use of a 220 volt line. The dryer heating elements run off of 220 volts. An excessive draw of electricity, or a short in the wiring can blow a fuse or trip a breaker. This happens to protect sensitive components from damage, and to help prevent fires. Every other dryer component operates off of 110 volts, the timer, motor, etc. Usually when a fuse blows or a circuit trips, it's because there's to much draw on the power line.
It is very possible for one part of your dryer to work fine, and yet another to have a problem, such as a short circuit. A short circuit may be caused by the heating element, internal wiring, or the main power cord.
To troubleshoot this problem, unplug the dryer and check to see if the circuit breaker or fuse remains on when the dryer is unplugged. If they stay on, it's more than likely the problem is somewhere in the dryer.
If your fuse blows, or the circuit breaker trips when the dryer is unplugged, it's likely the problem is with the circuit breaker, fuse box, or house wiring; contact a professional electrician.
OK I hope this is very helpful for you
Best regards Michael
Dec 01, 2009 | GE DBSR453EBWW Electric Dryer
My GE gas dryer is gets warm but the clothes take hours to dry
Hello there, this could be quite a few things.
The most likely cause is something as simple as a clogged lint trap. I will assume that you have checked this out, but just in case check it one more time and use a flashlight to see if you can spot any lint trapped down a the bottom, below where the lint trap sits.
Secondly, during the summer if you live anywhere where it's humid it will be much much harder for your dryer to do it's job. I was perplexed by this same problem when we moved out here to Minnesota. I thought my dryer was broken for sure, the clothes were warm, the dryer was warm, but the clothes took literally a full day to dry, many many cycles. Is there a chance that this is what you are experiencing?
Lastly, and the most complicated of the bunch, could be a shorted element. If that's the case you could replace it yourself if you are comfortable taking apart the dryer. If it's a newer GE dryer though it's probably still under warranty and they will take care of it for you. I would check with GE in regards to the warranty status. Their phone number is 1-800-626-2005
If none of these things work, please reply (if you can reply within the next 20 minutes or so it will assure that I am the one who continues with the question) and in your reply please include the actual model number of the dryer if you could.
Jul 08, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile Gas Dryer - Heat goes on and off
The operating coils get hot and quit. They only cost 20 bucks. Read more about it here:
Gas dryer works then quits then works some more
Mar 31, 2009 | KitchenAid KGYS850LT Gas Dryer
Gas dryer tripping breaker when plugged in.
I have the same exact problem. Dryer works great....when empty. Put wet clothes in and 3 or 4 hours later they are as wet as when I started. I am going to kick the piece of junk to the curb and go get a GE dryer right now.....I suggest you do the same.
Oct 16, 2008 | Whirlpool LGR8648 Gas Dryer
GE DBXR463GB Gas Dryer Logo
56 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
