Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Compressor gone I just a someone from Sears here who said my refridgerator's compressor needs replacing. Is this something one can do on his own. The estimate was $700+ Kenmore Coldspot 70209990 9yrs old
  • steve
    steve May 11, 2010
    Not without over $500 worth of special equipment and a lot of knowledge.
  • 555 Answers
Sorry, is not way you can do it by yourself. The compressor needs to be replaced by a certified technician (It holds gases at high pressures). I don't think will be a good idea to replace the compressor on a 9yrs old refrigerator. On the internet is a lot of complains about Sears technician "fixing" fridges with bad compressors. It's more likely it will break again.
Will be better to invest $700 on a new fridge.
Good luck !
Posted on Oct 05, 2009
    Novelist:
  • 157 Answers
Replacing a refrigerator compressor is best left to a professional because of the special equipment and tools that are required. If the refrigerator is 9 years old you might be better off to try to replace it with a newer more energy efficient model that may even qualify for a tax credit that will help offset some of the cost and also you'll save on your electric bill.
  • 80 Answers
A qualified technician with type 1 certification by the EPA can only perform this repair.
Why won't my refridgerator or freezer get cold? I replaced timer/defrost.and defrost heater.
You need to replace the compressor relay. Power off the fridge untill you replace it otherwise compressor will be burnt out
Sep 06, 2014 | Jenn-Air Refrigerators
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
My Samsung refridgerators bottom freezer is not working. The top is staying at temp. The model # is RB1855SW. The compresser is working and the blower is working, but not blowing cold air. Any suggestion?...
If the compressor is working and the blower is working then there is only one thing that it could be. The refridgerant need to be recharged, which unfortunately can only be done by a service tech. If it does end up being something wrong with the compressor samsung usaullay backs their compressors for 5 years you will just need your original receipt.
Jan 02, 2010 | Samsung Refrigerators
There is a loud noise coming from the back of the refridgerator
There is a fan at the back which could be hitting something. You would hear the noise nearly continuously. There is a compressor motor at the back. If you hear the noise just when the compressor starts and stops That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
You may have a motherboard on the back which can make noise. You'll need to roll the unit out from the wall to see where the noise is coming from and remove part of the cardboard backing to get access to the compressor and fan.
Oct 05, 2009 | Refrigerators
The unit only blows warm air. it just stopped kicking on the condenser/compressor to make that radiator cold and blow cold air. any help?
The compressor is not starting either because:
1. The compressor has gone bad
2. The system is low or out of refridgerant. There may be a slow leak, when there is no refridgerant in the system the compressor will not start.
Fix:
Re-charge the system with appropriate refridgerant, if the system has a charge already or holds a charge when you charge it then the compressor should start.
If not the compressor could be bad, sometimes you can get a hard start kit instead of replacing compressor. If the system does not hold a charge then you have to find and repair the leak before anything else...
Good luck. Please give good rating, it meens a lot to me....Feel free to contact me again...
Aug 01, 2009 | Dometic Rooftop RV Air Conditioner
Frigidaire model FRT21H7AS Not cooling, compressor makes noise
HI, The relay has gone bad and needs replaced. Probably not the compressor. Fairly common problem with these new fridges.
Let me know if I can assist you further.
Vic
May 18, 2009 | Frigidaire FRT21H7AS Top Freezer...
Refridgerator
IF THE BUZZING SOUND IS ONLY THERE WHEN THE MOTOR IS RUNNING THAT COULD MEAN ONLY ONE THING.YOUR PISTON IN SIDE THE COMPRESSOR IS NOISEY THE ONLY WAY TO SOLVE THAT IS TO REPLACE THE COMPRESSOR.BEST YOU HAVE A TECH TO ADVICE YOU FUTHER.GOODLUCK.MOHAMED
Jul 21, 2008 | Whirlpool ED2FHEXN Side by Side...
Kenmore Fridge 4 yrs old side by side model not cooling
Hi. Your refrigerator is under 5 years and the compressor is still under full warranty. Call Sears and get it fixed parts and labor included. There should be no charge to you whatsoever. Make sure they understand that on the phone when you set up the appointment. You would be better off having a different technician from Sears come out to your house, as the one that came was not honest with you. Good luck, Mack
Jan 06, 2008 | Refrigerators
Refridgerator
You need to check if the compressor still working, replacement of burned wire is needed.Qualified technician is needed for this job.
Refridgerator does not cool
It has a bad relay on the compressor. Looks like your model is a 50552 Kenmore. If so the part # you need is a 8201799 (start device) cost is $45.96 and you can get it at http://www3.sears.com/ or any local appliance parts house. It is # 16 on this diagram http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0165000&brandID=0582&modelDesc=SIDE-BY-SIDE%20REFRIGERATOR&modelNumber=10650552000&documentID=P0070128&documentTypeID=PLDM&documentClassCode=PM&titleType=UNIT&titleID=00011&
Nov 07, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
208 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
