Question about HVLP 2.5mm Hvlp Spray Gun-auto Paint Primer-metal Flake
I tried to adjust the regulator and the back just screwed off of the body - any ideas on how to prevent that?
  • Paul Dalton
    Paul Dalton May 11, 2010
    sorry type of gun
  • Paul Dalton
    What type of gone is it
  • 285 Answers
Possibly you were trying to adjust the regulator without having air flowing through it. You must squeeze the trigger on the gun and have air constantly flowing through it otherwise the regulator knob is very hard to turn against the pressure inside it. To set an accurate pressure, squeeze gun trigger (while connected to air hose) to get air flowing... then twist regulator knob out (or in the "-" direction) until air flow reads 0 on the regulator gauge. Then start twisting regulator knob the other way until you reach the desired pressure on the regulator gauge. Also make sure the regulator is attached with air flowing the correct way through it. There should be an arrow somewhere on the regulator body which should be pointing toward your spray gun.
Posted on May 06, 2010
1996 cherokee Country Wagon
Hi Debra: I sugges to check this procedure...
Fig. 1: TBI fuel pressure regulator
  1. Remove the throttle body assembly from the vehicle as outlined in this section.
WARNING To prevent spring pressure release, hold the regulator housing against the throttle body while removing the mounting screws.
  1. Remove the three retaining screws that hold the pressure regulator to the fuel body.
  2. Disassemble the pressure regulator assembly. Note the location of the components for reassembly. Discard the gasket.
To install:
  1. Install a new gasket and the regulator assembly. Tighten the three retaining screws.
  2. Install the throttle body assembly as outlined in this section.
WARNING The pressure regulator diaphragm MUST be installed with the vent hole aligned with the vent holes in the throttle body and regulator housing!
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 21, 2011 | Jeep Cars & Trucks
How to replace fuel pressure regulator on 1997 jeep grand cherokee
Hi Cassandra:
Check this procedure to removal and installing Fuel Pressure Regulator...
To install:
Dec 13, 2011 | 1997 Jeep Grand Cherokee
If i put a little gas in the carberator and fight with my blazer it will start and stay started, but if i leave it for awhile, it will turn over but not start. i cant figure out if it is electric or...
Get a fuel pressure gauge and connect it to the rail for the fuel injectors to read pressure.
If the pressure is too low, it might be a bad fuel pressure regulator or pump:
Fuel Pressure Regulator Removal & Installation 2.2L Engine To Remove:
  1. Relieve the pressure in the fuel system.
  2. Disconnect the negative battery cable.
  3. Disconnect the vacuum hose from the fuel pressure regulator.
  4. Remove the pressure regulator mounting screw.
  5. Remove the fuel pressure regulator assembly with O-ring. Inspect filter screen for contamination. If contaminated, remove and discard.
Fuel pressure regulator removal/installation (2.2L SFI engine) gm-05-22-619.gif
To Install:
  1. Apply clean engine oil to the new pressure regulator O-ring and install the O-ring on the regulator.
  2. Install the regulator on the fuel rail. Apply thread-locker to the mounting screw.
    • Tighten the screw to 106 lb in (12Nm).
  3. Connect the negative battery cable.
  4. Use the following procedure to pressurize the fuel system and check for leaks;
  5. Turn the ignition ON for 2 seconds.
  6. Turn the ignition OFF for 10 seconds.
  7. Turn the ignition switch back ON to run the fuel pump again and pressurize the fuel system.
  8. Check the fuel rail assembly for fuel leaks.
4.3L Engine RPO L35 To Remove:
4.3L (RPO L35) Fuel meter body assembly gm_trk_sil15_02-04_43_fuel_metr_body_assy.gif
  1. Before servicing the vehicle, refer to the Cautions and Warnings in the beginning of this section
  2. Remove or disconnect the following:
    • Upper intake manifold (See: Upper Intake Manifold)
    • Fuel pressure regulator retainer clip (M) and discard the clip
    • Regulator (N) from the housing by twisting and pulling the fuel pressure regulator (N) and using a shop towel to catch any spilled fuel
    • Regulator seal O-ring (R) and discard the O-ring seal
    • Regulator filter (Q) and discard the filter
    • Regulator seal O-ring (P) and discard the O-ring seal
    • Backup ring (O) and discard the ring
  3. Cover the fuel pressure regulator housing to prevent contamination from entering the fuel system
To Install:
  1. Lubricate the NEW O-ring seals with clean engine oil
  2. Assemble the following new parts to the fuel pressure regulator:
    • Backup ring (O)
  3. Install or connect the following:
    • Fuel pressure regulator with the vacuum tube pointing down
    • Upper manifold
  4. Test drive the vehicle to confirm the repairs
RPO LU3 To Remove:
4.3L (RPO LU3) Fuel meter body assembly gm_trk_sil15_02-04_43_rpolu3_fuel_metr_body_assy.gif
    • Fuel pressure regulator retainer clip (E)
    • Regulator (F) from the housing by twisting and pulling the fuel pressure regulator (F) while using a shop towel to catch any spilled fuel
    • Regulator seal O-ring (J) and discard the O-ring seal
    • Regulator filter (I) and discard the filter
    • Regulator seal O-ring (H) and discard the seal
    • Backup ring (G) and discard the backup ring
To Install:
  1. Lubricate the NEW O-ring seals with clean engine oil.
    • Backup ring (G)
    • Fuel pressure regulator (F) with the vacuum tube pointing down
Nov 04, 2010 | 2002 Chevrolet Blazer
Where is the fuel pressure regulator located on a 1996 jeep grand cherokee, laredo, straight 6 cyl.?
it's under the throttle body
Fig. Fig. 1: TBI fuel pressure regulator
To install:
Oct 11, 2010 | Jeep Grand Cherokee Cars & Trucks
Makita MAC5200 Compressor. Leaks air around the regulator screw in adjustable black knob only when I turn up the regulator pressure to allow air to flow through to the quick connects. I've taken the...
There are two types of regulators used. One has a rubber diaphram sealed at perimeter with body and a piston type. Most likely you have the piston type. Remove body containing piston/ spring mech. Examine piston lip seal. Lip will face toward body of reg. and must fit snugly into cylinder. Make sure cylinder is smooth and is well lubed.
If seal/piston fits loose remove seal and wrap some teflon tape in groove and re-install lip seal /test for snug fit. Notice small metal actuator extending from center of reg. , if it is circular (about 1/8 dia) then there should be an oring of the same size mated/fit into the piston. If this oring is missing it will leak as you describe. Lastly, there should be a gasket or oring sealing outer shell to body. If you have diaphragm type look for holes, tear or shrink too small. Parts are at www.toolpartsdirect.com or Lowes in the plumbing department good place for orings and silicone lube. Good luck
Sep 27, 2010 | Makita MAC5200 Electric Powered Air...
Locating fuel pressure regulator
To Install:
To Install:
    • Backup ring (O)
    • Upper manifold
RPO LU3 To Remove:
To Install:
    • Backup ring (G)
Aug 05, 2010 | 2001 Chevrolet Blazer
Shifting problems/Tiagra STI Flightdeck
It sounds like the limit screws on your derailleur body are out of adjustment. They are usually small phillips head screws on the body of the front and rear derailleur that limit the travel of the derailleur body on the rear so that the chain cannot get shifted into the spokes or off the smallest cog into the frame. On the front they prevent the chain from shifting off the inside or outside cogs. There are good articles under front and rear derailleur adjustments at this site:http://www.parktool.com/repair/byregion.asp?catid=53 I hope this helps.
Aug 11, 2009 | Cycling
Regulator doesn't allow gas to flow to grill . Grill cannot heat hot enough to grill steaks. Gas flows too slowly.
Shut off the gas at the tank and disconnect everything.
Unscrew the plastic cap on the regulator. Inside is a flat screw top that has a single slot or an X-shaped slot. This is the pressure adjustment. It controls the diaphragm that regulates gas flow.
Note where it's set. Use a Sharpie to mark the adjuster on its edge (place a dot there), and make a corresponding mark on the threads next to it.
Next, use a large screwdriver or a coin to spin the adjuster counterclockwise three or four times. Pay attention to the number of turns. Now, screw it back in (clockwise) the exact same number of turns, stopping at the index mark you made.
Next, turn the adjuster two turns clockwise, followed by two turns counterclockwise. The idea is to end up where it was originally set. This action unsticks the regulator's valve seat. Done.
Put the cap back on, hook it all up, open the tank valve, and make fire.
Oongawa!
-Peegoo
Jun 23, 2009 | Thermos Stainless Steel Gas Grill
Adjusting front derailer
Typically adjusting the front derailleur is a matter of adjusting the two adjusting screws on the derailleur. So turn the bike upside down. It should sit on its seat and handle bars. Find the two adjusting screws one will prevent the derailleur from traveling too far out preventing the chain from coming off. The other screw prevents the derailleur from traveling too far in keeping the chain from falling off that way. Now once you have found the screws slowly start turning the pedals like it was being ridden. Move the derailleur out as far as it will go if you see the chain is about to come off adjust the screw. Do same for inside screw. Now move the back derailleur all the way in and retest front derailleur, repeater with rear derailleur all the was out. Hope that helps. Oh, the back derailleur adjusts same way.
Feb 27, 2009 | Shimano Brake Cables Atb Mountain Bike...
HVLP 2.5mm Hvlp Spray Gun-auto Paint Primer-metal Flake Logo
195 people viewed this question
Top HVLP Air Tools & Compressors Experts
john h
russ davis
Steve P
Steve P
Are you a HVLP Air Tool and Compressor Expert? Answer questions, earn points and help others
