Question about RTO Farmtrac 8075 Cab And Air Tractor
Farmtrac 665 gass gauge goes to full and stays when turned on. in accurate reading problem. checked connections , all seem fine.
CMV9
  • 594 Answers
SOURCE: gas gauge reading empty even when tank is full
Usually if the gas gage does not work yes it is true it may be the sensor if it is electronicly controlled. the sncor will more than likley be in the tank. here is how to remove your gas tank.
  1. Before servicing the vehicle, refer to the precautions section.
  2. Relieve fuel system pressure.
  3. Drain the fuel tank.
  4. Remove or disconnect the following:
    • Negative battery cable
    • Fuel filler and vent hoses
    • Fuel tank skid plate
    • Fuel tank wiring connectors
    • Fuel supply and return lines
    • Fuel tank
    • Fuel pump assembly
      7924bg17.gif Fuel pump assembly mounting
To install:
  1. Install or connect the following:
    • Fuel tank. Tighten the bolts to 27 ft. lbs. (36 Nm).
  2. Start the engine and check for leaks.
Posted on Apr 16, 2009
  • 468 Answers
SOURCE: 2000 Buick Century gas gauge reads full all the time
You're either looking at a short in the wire that goes to the fuel sender, or a bad fuel sender. If it was just a broken wire, it would read empty instead. The fuel sender is a permanent part of the fuel pump, so that has to be replaced as a unit.
Posted on Oct 20, 2009
  • 60 Answers
SOURCE: daewoo racer 1995, petrol gauge
the easiest fix is to change the sending unit
Posted on Oct 22, 2009
alicantecoli
  • 22156 Answers
SOURCE: Gas gauge goes pass the full mark when
new sender unit required
Posted on Nov 18, 2009
  • 462 Answers
SOURCE: fuel gauge faulty / gives weird levels of fuel
The fuel level sensor is bad. The tank will have to be taken down to replace the level sensor. There is little fingers on the resistor that wear down and loose contact causing the gage to read incorrectly.
Posted on Dec 12, 2009
When i turn the key to on position it clicks several times motor starts but gauges don't work right
this may seem wild , but it sounds as if the instrument panel is not properly seated in the connector . pulling the panel is not difficult 4 screws in the dash panel and 4 screws in the instrument panel and pull straight out . clean the contacts completely with electrical contact cleaner and push the panel back in place . put all screws in tightly
Feb 28, 2014 | GMC 1999 Suburban 1500 SL
My gas hand is going a little crazy, it will go to full and stay a while then move to empty, and I just put a new fuel pump and sender in it, what should I do now ?
I can only think of two possibilities:
1) The Ground Wire (goes from the sending unit in the fuel tank to the frame of the car) is not getting a good connection or
2) The fuel gauge in the dashboard is bad.
If your description means that the change in the gas gauge is random then check the ground wire. If you have a volt-ohm meter, try checking the resistance from the wire where it attaches to the sending unit, negative side. Remove wire from sending unit first. Make sure negative wire on V_O meter is connected to frame of car. Reading should be almost zero. Anything else and the wire you are testing does not have a good connection.
If your description means that you turn the car on and the gas gauge is reading full for awhile and then goes to empty, the gas gauge is bad.
Sep 29, 2012 | 2002 Pontiac Bonneville
My fuel gauge floats from full to empty when I stop at a light! And its stays on empty until I drive for about five minute why is that? I can't get an accurate fuel reading!!
I have the same vehicle and my car actually was full of gas, registered empty & left me on the side of the road..It was the sensor in the fuel line that had to be replaced.
Feb 03, 2012 | 2003 Buick Rendezvous
Just changed oil two weeks ago three days after i noticed losing oil pressure pulledover and filter loosed up dumping all my oil tightend it added oil until below full worked fine til last nite oil...
would check filtre make sure it is the right one ,also make sure you have not left old o ring on engine filtre head .after that would have oil pressure checked with a manual gauge make sure it is normal
Sep 18, 2011 | 2003 Chevrolet Tahoe
THE FUEL GAUGE STAYS PAST FULL DOESN'T MOVE .97 BLAZER REPLACED ENTIRE FUEL PUMP AND CHECK PUMP WIRES IF MELTED /FAULTY .THE I REPLACED THE ENTIRE GAUGE CLUSTER. FUEL GAUGE WHEN TURNED ON IT ALSO WENT...
USSUALLY WHEN GAGE GOES WAY OVERFULL IT'S A BAD GROUND
QUICK CHECK USE BOOSTER CABLE ONE END ON TANK OTHER END ON BATTERY NEGATIVE IF GAGE GOES OK MAKE UP SHORT WIRE FROM FRAME TO TANK SEEM LIP
AND ATTACH MAKE SURE METAL IS CLEAN
Apr 19, 2011 | 1997 Chevrolet Blazer
Fuel gauge faulty / gives weird levels of fuel
Dec 12, 2009 | 1999 Chevrolet Malibu
Air conditioner blows hot air . gauge shows full .
It needs to be re-gassed. Take the car to an Auto Mechanic to get the Air-Conditioning re-gassed. They might also need to check it for leaks to make sure the gas stays in.
Jul 26, 2009 | 1994 Mitsubishi Diamante
Gauges come back on....
electrical problem. take the truck to the dealer and have the computer checked / reprogrammed. unfortunately, your average mechanic cannot reprogram the computer. have you noticed any other problem that would point in the direction of an electrical problem (lights, radio, lighter, etc.)?
Sep 23, 2008 | 2000 Chevrolet S-10
1989 Saab 900 low level fuel light
You don;t say whether the fuel gauge is reading accurately, or whether it's always on empty. If the gauge is always showing empty, it's most likely a problem with the sending unit in the fuel tank. Check the resistance across the two terminals of the sending unit.
On a C900, the fuel sender level unit is separate from the fuel pump and located on the right side top of the tank, accessible by removing the trunk floor lift up panel (the pump is located on the left side top of the tank.
Possible problems are: electrical line off or broken, float not working (it's fairly delicate); or gauge not working.
Test the resistance of the sending unit with the lines disconnected, the resistance should be 2.6 to 3.8 ohms full tank, 63.3 to 67.5 ohms empty tank; and test for voltage across the top of the sender unit, if no voltage, that's likely the problem!
If the gauge is otherwise reading accurately (showing 'full' for a full tank, etc) then the problem is likely a gauge malfunction and can be simply replaced.
Saabreur
Jul 10, 2008 | 1989 Saab 900 4 Door
RTO Farmtrac 8075 Cab And Air Tractor Logo
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
