Question about Samsung L83T Digital Camera
Battery cover will not lock closed - Samsung L83T Digital Camera
Broke battery cover
And now you can't use the camera? the cover must be closed complete. There is a switch, to check if the cover is closed. this is checked, to prevent damage to the memory card. When the camera is powered down while accessing the memory, the already saved pictures can become damaged.
You better contact an authorised service centre, for a repair of the camera.
Mar 23, 2014 | GE Power PRO Series X2600 16.1-Megapixel...
Sony Cybershot DSC-S600 won't stay on
Have you tryed rechargeable batterys on the camera, generally they are higher quality and should work better.
Jun 20, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
I can't keep the battery door cover closed on my Nikon coolpix digital camera L.22
I see this message at least 3 times, so it must be important.
Looks like a mechanical problem. But not having the camera in my own hands I have to do some educated guesses.
Could be something broke off. Could be a small chip of plastic or a very small piece of metal. Difficult to repair it yourself. But you also could look if there is something in the battery compartment that should not be there. Could be just a little bit of debris, that is lifting the battery, (not if the battery is behind the lock) or debris in the door, so you can't close the battery compartment complete, and it can't be locked.
If you can't find anything and it looks as if the battery compartment closes correct, and still you only can't lock the door, please visit your dealer or the Nikon service centre closest to you.
Nov 19, 2013 | Nikon COOLPIX Cameras
Powershot sx20 battery cap lock got broken now the cap will no longer close
Use electrical tape for holding the door or you need to visit service center for replacing the complete door.
Aug 07, 2012 | Canon PowerShot SX20 IS Digital Camera
How do i replace the battery in the garmin streetpilot c330
Follow these steps : 1. Determine that you do have a Garmin GPS with a replaceable battery. Find the information by checking the manual or with a close inspection of the back and sides of the GPS unit. GPS units that have a battery that can be replaced by the owner will have a battery cover lock on the back or side; it looks like a small sliding piece of plastic with slots or ridges.
2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
May 16, 2011 | GPS
How do i remove the battery out of my garmin 1300
  • 2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
  • 3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
  • 4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
  • 5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
  • Mar 01, 2011 | Garmin nuvi 1300 Car GPS Receiver
    I have put fresh batteries in my Canon Power Shot S1 camera and it still will not come on? Can you help me?
    Contact failures may have occurred between the camera and the batteries.
    Confirming that the [Memory Card / Battery Cover] is securely closed
    If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.
    Close the [Memory Card / Battery Cover] securely, and then turn the power on.
    Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.
    If your camera uses four AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries.
    1. Be sure that the camera power is off.
    2. Slide the battery cover lock in the direction of the arrow, and push the battery cover slightly forward. Then open the cover.
    batts_step1.gif 3. Insert the batteries as shown.
    batts_step2.gif 4. Close the battery cover.
    batts_step3.gif * For the PowerShot S2 IS, PowerShot S3 IS, and PowerShot S5 IS the batteries are inserted in a slightly different order, please refer to the decal inside the battery door for the correct order.
    Installing batteries in cameras with 2 batteries. If your camera uses two AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries. Please see the various examples to find which type matches your camera.
    Example 1:
    2. Slide the battery/memory card cover lock in the direction of the arrow (1.gif), and press down while opening the cover (2.gif).
    3. Insert the batteries as shown and close the battery / memory card cover.
    Example 2:
    2. Slide the battery cover lock in the direction of the arrow, and open the cover.
    * For the PowerShot A300 and PowerShot A310 the battery polarity is reversed.
    Dec 05, 2010 | Canon Cameras
    Battery cover not closing
    worngly he inserted take it to service centre
    Jun 20, 2009 | Canon PowerShot A630 Digital Camera
    Kodak easyshare z730
    Possible causes and how to handle them
    1. The camera is not on
    Turn on the camera. (Operation procedure varies between camera models. Please refer to the camera user guide supplied with your camera.)
    2. The rechargeable battery is not fully charged.
    Make sure the rechargeable battery is fully charged. If the battery has not been used for an extended period of time, or if it is being used for the first time, it may not be fully charged. In cases like this, fully charge the battery and then discharge it completely in the camera several times to bring the battery back to its normal performance.
    The rechargeable battery's capacity diminishes the longer the battery is used. When the battery consumption becomes quicker, the battery life may be at its end. Replace the battery with a new one.
    3. The battery terminals are dirty.
    When camera does not operate with a brand-new alkaline battery (for cameras that use AA-size batteries) or with a fully charged rechargeable battery, the terminals may be dirty.
    Polish the terminals with a dry cloth and make sure the terminals are clean. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and power may not be fully supplied to the camera.
    Also, polish the battery charger terminals with a dry cloth before charging the battery. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and the battery may not be fully charged.
    4. The batteries are not installed correctly (for cameras that use AA-size batteries)
    For cameras that use AA-size batteries, multiple batteries are used in one camera. Make sure the direction of each battery matches the direction indicated on the camera. If any of the batteries are improperly inserted, the camera will not operate.
    5. The battery cover or CF card (SD card) slot cover is not securely closed
    Most cameras have a lock mechanism on the battery cover. The camera will not turn on if the battery cover is not locked or securely closed, or if the CF card (SD card) slot cover is not securely closed. Make sure these covers are securely closed.
    May 19, 2008 | Cameras
    Battery cover for cds6300
    the molded plastic clips ,when cover is closed and pushed in to lock are broken from camera body both pieces. How and where can it be repair.
    Oct 21, 2007 | RCA CDS6300 Digital Camera
    Samsung L83T Digital Camera Logo
    Top Samsung Cameras Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Computer Links
    Are you a Samsung Camera Expert? Answer questions, earn points and help others
