Question about Bogen Imaging 3251 (Legs Only) Tripod
I can not get the retractable legs to go back in, they seem to be stuck. How would I go about fixing them?
How do I fix a stuck retractable seat belt?
You can't it is not designed that way. The seatbelt mechanism is damaged and needs to be replaced.
Feb 21, 2016 | 1999 Chevrolet Blazer
How to level a samsung dishwasher?
Usually the front legs can be adjusted by just turning them. The 1 back leg (Samsungs use a tripod foot support system), is adjusted through a remote screw-type leveler that is located in the center (left-to-right) of the base, just behind the toe-kick panel.
May 30, 2014 | Samsung Dishwashers
When i t turn on my Nikon coolpix L810 i keep getting a message to"turn off the camera, remove the lens cap and then turn back on." it seems like the lens starts to expand and then retracts as if it's...
I'm afraid that you are right about the lens being stuck.
The camera has several checks to make sure the lens can zoom freely in and out. If the camera detects there is a blockage of some kind, the lens will retract and switches of the camera to prevent more damage.
I'm afraid there is nothing you could do to fix it, other than bringing it to a repair shop and have them take a look at it.
Jan 02, 2014 | Nikon COOLPIX L810
I have a 1973 whirlpool washer. I am trying to adjust the back legs on it. It appears to have a spring loaded bar between each of the back legs. The back legs are not adjustable and look to be self...
Disconnect ac/cord,hoses and drain pipe, lay machine down on front side. Inspect the self-leveling bar ***'y and spray liberally with WD-40 if rusty and/or stuck.
Feb 22, 2011 | Whirlpool Washing Machines
I have a Manfrotto 685B monopod that I have had for about a year. Recently I noticed that it has gotten very hard to extend or retract the leg sections of pod. I looks like there is a wax substance on top...
If it was second-hand or pre-owned, the previous owner may have applied some form of lubricant to it. From a look at the images on the Net, it appears that the upper sections are adjusted by twist grips. If this is so, just unscrew them and separate the leg sections carefully, after which they can be cleaned. There may be a bevelled collar within, to grip the section - be careful with it.
The bottom section seems to have a standard lever lock. There should be a couple of screws holding this to the middle section - loosen these, then slide the leg portion out and clean it as well. When re-assembling this part DO NOT over tighten the screws - just enough to prevent the locking collar from moving.
Apr 08, 2017 | Bogen Communication Bogen / Manfrotto 685B...
Glove box is stuck
The lid "locks" into place by two retractable nibs on the outer sides of the glove box that are supposed to retract back into the lid housing when you lift up on the release lever.
If you can get a flat piece of metal like a slim jim down the sides of the glove box lid, you should be able to push the nib back into the housing, thus releasing the lock hold of the lid.
I just had to do this today when my Hyundai Tiburon glove box closed and refused to open agian.
It seems like the latch has a tendency to malfunction after a while and no longer is able to active the retraction of the nibs on each side.
Mine was retracting only on one side, so I could see that it was kind of "trying" to release but was still locked in place.
I hope this helps some
Jan 18, 2009 | 2003 Hyundai Tiburon
Honda Ridgeline rear seat leg problem
honda now offers metal 9zinc) cable retractors for the rear seat legs thet are supposeed to retract automatically wher you forld the seaat up. About $8.00 each. You will need tow of them. one for each seat. atahe original ones were plastic so at least these are a better solution. The dealer printed out the instructions on how to repair this problem and the part numbers you will need to do so. Ask your local Honda dealer service tech for a copy of the Honda bullitin that was sent out about March 2011 on this issue. This bulliten is very helpfull. Mcgrath Honda in Elgin Ill. gave me a copy of it.
Jan 11, 2009 | 2007 Honda Ridgeline
Konica Minolta Z6 camera lens won't retract or zoom out
I have the same problem. The lenses does not retract when turned off or function with the zoom control when turned on. Has anyone found a fix?
Dec 27, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Whirlpool dishwasher installation
FOUND IT!!!!!
There is a white plastic screw in front of the dishwasher to estend the back leg!!!!!
Whirpool people are crazy!!!!
Max
Aug 17, 2008 | Dishwashers
Bogen Imaging 3251 (Legs Only) Tripod Logo
Top Bogen Imaging Photography Experts
Tony
Are you a Bogen Imaging Photography Expert? Answer questions, earn points and help others
