I have a laptop by gateway of course and i need to figure out where the cmos would be and how to take apart my laptop to reach it so that i can reset my bios cause i just bought this laptop and its asking for a bios password
  • Chip
    Chip May 11, 2010
    We would need to know your complete model number to be able to help you out with that request....all laptops are not made the same.
  • Computers & ... Master
  • 7,993 Answers
It is very unlikely that removing the CMOS battery will erase this security feature, designed to prevent unauthorized use. At least this is what my Toshiba Laptop manual says: Take it to a certified Gateway Service Center.
Hope it helps.
Posted on Oct 05, 2009
Gateway Solo 9550 bios unlock password master
There isn't one, either take the laptop apart and remove the CMOS battery for 10 seconds or download and burn hiren 15 to a CD and use one of the CMOS password wipers.
Jul 12, 2012 | Gateway Solo 9550 Notebook
CMOS battery gateway t-1625
Remove the keyboard and the media button panel.
Remove all the screws from the underside of the laptop.
Remove the access panels.
Remove the hard drive.
There are three screws that holds the chassis together here (inside the hard drive bay). You won't be able to completely open the chassis but now you can use a flat blade (I used a small flat head screw driver) and pry the top and bottom pieces apart.
As I mentioned, you won't be able to completely take the two chassis pieces apart but you will now have enough clearance to access the CMOS battery to the right of the headphone jack (looking at the bottom).
I used a small flat head to pop the battery out. I then used long tweezers to place the new 1220 battery on the battery tray and reached around from the hard drive bay and popped it in with my index finger.
Put everything back together in the order you took it apart.
Apr 05, 2012 | Gateway T-1625 Notebook
Reset bios password on a gateway laptop
Sir
Insert your orgenal cd insert and Flash now
OR
open your laptop then Remove CMOS battery then shorting CMOS socket two connections.Then setting laptop
Oct 08, 2011 | Gateway Computers & Internet
I forgot my gateway model ML6230 bios password, i need a new password for it (reset the password).
A method you can try if you don't have a password reset software is by removing the CMOS battery. Remove the CMOS battery then turn the computer on. The system BIOS will be reset and password will be removed. Then you can put the battery back in. Click on this link for the Gateway ML6230 Notebook PC Manual. Check page 36 for CMOS battery removal instructions.
http://support.gateway.com/s/Mobile/Q106/Oasis/8511725_Service.pdf
Mar 21, 2011 | Gateway ML6230 Notebook
Bios password forgotten, how can I reset password?
To reset the BIOS password read the information from this link.
In case of your Gateway laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Jan 30, 2011 | Gateway M285-E Notebook
How to I reset the bios password,on my LT2021u?
If you know the bios password, then change it in the bios menu,if you don''t know the bios password, then clearing the cmos battery should work. You will need to disemble your netbook apart until you can get to the motherboard, there you should see a baterry of a nickel size and take it out and back it, resemble your netbook and you should be good to go.
Here is a link that may help you out too. http://www.askvg.com/how-to-reset-remove-bypass-a-bios-or-cmos-password/
Jan 30, 2011 | Gateway LT2021u Netbook
Need to reset the bios password
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Jan 25, 2011 | Gateway T-6815 RTL Notebook
There is a password on the cemos i need to clean it because it can't boot on the cd rom GATEWAY 450ROG
you need to reset cmos, cmos reset located inside the laptop this can be in different places from laptop to laptop. watch the video
Dec 18, 2010 | Gateway 450ROG Notebook
My customer has a gateway p-171x notebook that has a bios setup password he does not know-how can I reset that? I have taken out the battery and it disn't work. It is a Phoenix bios
Sadly, many Gateways models must be returned to the manufacturer to have these passwords reset.
Try A Phoenix Backdoor BIOS Password The reported Phoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, and PHOENIX. Try one of these passwords and see if they will unlock it.
If that doesn't work, there could be a jumper located under the keyboard if your model has one.
The last thing to try would be to open the unit and remove the CMOS lithium battery to clear it. This is of course a last resort and is not for the weak at heart. You may void the warranty if there is one by doing this, so be careful.
If I think of anything else, I'll let you know. Please reply with the fix if one of these works.
Mike Vail
Oct 05, 2009 | Gateway P-171X FX Edition PC Notebook
Where to find the CMOS battery
take out the keyboard from the bottom side with a flat screw driver under it there´s a few screws take it out lift the cover and there is the battery.
Oct 27, 2006 | ASI CL51-15 Notebook
Computers & Internet Logo
David Payne
David Payne
