Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
The green light on the front comes on, stays on for only a short while and then goes off, then comes on, then goes off, ect. This is for Model D52W20B
5 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: d52w20b
Look on Deflection board see if capacitor 150 is open on top 2200uf 16 if so replace it and the two near by it 220uf 35volts other wise order new deflection board cost verys 125.00
Caps are Green with gold writing on them.
Posted on Sep 17, 2008
Slinteriors
  • 8617 Answers
SOURCE: model d52w20b the green light comes on flashes 3
Replace the CP150, CP120 and CP114 capacitors. You can get the RCA repair Kit by that same name from www.tvrepairworld.com which also has the CD with instructions.
Posted on Jan 14, 2010
Testimonial: "if i can figure out what those are and replace them then thank you it was very helpful"
Slinteriors
  • 8617 Answers
SOURCE: My Tv wont stay on
Replace the deflection board. You can get a replacement deflection board from www.tvrepairworld.com
Posted on Jun 20, 2010
  • 453 Answers
SOURCE: RCA model# D52W20B When I turn on the power the
yes u may have a problem with the power supply , bad capacitor on the power supply 2200uf at 25volts , thats the only cap with this value , it's right on the power supply
Posted on Dec 08, 2010
I am having problems with Lionel Fastrack layout. When I put electrics to the layout the green light comes on and I think all is ok. However as and when I start to increase the power the red light A.
remove all the cars and engine from tracks and try it, if green stays on add one car back to track at a time and try it , when light turns red , the last car added is the problem
Mar 20, 2016 | Crafts & Hobbies
Lenovo 9227ac1 comes on then goes black light on front stays green
When it have this kind of error is a problem of the power-board.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Mar 22, 2014 | Lenovo 17" Thinkvision L171 9227-Ac1 Lcd -...
We have a 2007 Sony Bravia 46" KDL-46VL130. There is not sound or picture. When we power it on the green light comes on blinking once and then the red light blinking once and then the green light stays on....
Does the front light stays green ? Or goes back to red ? The back-light going on/off maybe the problem, but it shoul return with a red blinking led (4 times ?) and if so it can be a power inverter problem.
Oct 09, 2013 | Sony Bravia KDL-46VL130 TV
When I push the on button the green light comes on for second or two then goes out.(will not stay turned on long enough to even get a picture on the screen.Mitsibishi Model # WS-55315
This set has a self check feature--if set has been unplugged it clears the error buffer--plug in and try to turn on set.
When green light comes on and then goes off ON THE FRONT OF THE SET press and hold BOTH the menu and input(device) buttons at same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat the code for a total of five times.
Let me know what error code you find and I will explain it.
May 27, 2012 | Mitsubishi Televison & Video
TV comes on stays on for a short time than goes black with loss of sound green flashing light untill TV comes back on. takes maybe 2 min.
Jul 11, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Location of ABS wheel sensor 96 Astro Dayvan 2WD
most sensors are located at the wheel hub, you should see the reluctor gear mounted on the drive axles in the front, you may need to remove the wheel and rotor to get to it! is it all wheel drive or just front wheel drive, if front wheel drive you should follow the wire that goes to each wheel in the rear, if all wheel drive it may only have one sensor in the transphercase to monitor driveline speed.
you really should have some one scan the abs and find out the code/s and diagnose it, just cuase the light comes on doesent mean its the wheel speed sensor, it could be the abs module ect ect..., check the fluid level and make shure its not low and or dirty.
Sep 30, 2009 | 1995 Chevrolet G20
While watching tv it just turned off, we turned it back on but no pictures but there is volume. also to turn it back on we see red light and green light together flashing then it turns off. i just replaced...
MY TV TURNS OFF AFTER WE TURN IT ON IT GOES BACK OFF A FEW TIMES AND THEN STAYS ON. AND WHEN I COME HOME FROM WORK IT STARTS ALL OVER AGAIN, THAT HAPPENED FOR 2 WKS NOW IT JUST GOES OFF YOU ONLY SEE THE GREEN LIGHT ON THE FRONT COME ON(POWER LIGHT) AND IT GOES RIGHT BACK OFF IT WILL NOT STAY ON
Sep 18, 2009 | Toshiba Televison & Video
Hp pavilion 513n tries to start up then turns off
This is a case where something that is getting switched on during start-up is causing the power supply to fail... probably due to a short. How ever I believe the short is in the power supply
This is an older HP model ( I have a 530N) with teh same problem. I bought a new power supply and installed it.
Aug 14, 2009 | Computers & Internet
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
Power on won't stay on
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ΒΌ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB
Sep 07, 2007 | Mitsubishi WS-65807 65" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
88 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
