Question about Epson Stylus CX4800 All-In-One InkJet Printer
Wont install I ran the installation disk and halfway through it tells me DAT file do not exist! and only the scanner part hooked up not the printer....it said its combatible with Vista so whats wrong here?
  • Epson Master
  • 1,113 Answers
TRy ddownloading latest drivers from Epson web LINK
Posted on Dec 23, 2007
There is no recovery partition.
I can only be these causes.
1: hdd bad.
2: it's telling you the truth, the restore partition is corrupted,
takes way more than simple file names, there.
3: someone used microsoft disks or others, an attempted to install other OS, and wreck this partition structures and files.
the cure is same, HP media kit. (posted 100000 time at hp,)
https://support.hp.com/us-en/document/bph07143
May 19, 2017 | HEWLETT-PACKARD G72250US Laptop
Tip
Fixing Corrupt Registry
If your registry has gotten corrupted, and re-installing Windows95 over your existing version does not fix the problem,
there is a hidden, read-only, system file on the root of your boot drive called SYSTEM.1ST.
This is the initial system registry created when you first installed Windows95.
To use this file:
Go to your Windows directory
Un-Attrib your current SYSTEM.DAT file (attrib -r -s -h system.dat)
Copy your current SYSTEM.DAT to something like SYSTEM.BAD file (just in case)
Move to your root directory
Un-Attrib the SYSTEM.1ST file
Copy SYSTEM.1ST to \WINDOWS\SYSTEM.DAT
Re-start your system
You will need to install your 32-bit apps and any other programs or changes that modified your system registry
but you will not need to go through a new again. Your 16-bit apps should not need to be re-installed since they do
not modify the registry. You will also retain your current desktop configuration.
on Apr 27, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
When i start my hp scanner then 1 warning show. the warning is " where is the file of hpf2vw10.dat " so what can i do ? pl. help me.
Uninstall the scanner drivers and install them again from the cd given or downloaded from online.
The dat file is missing due to corruption or a bad install.
Dont worry. This should solve the problem. Cheers!
Aug 16, 2010 | Computers & Internet
I want ot install ansys 11 on my compuer can u
install normaly ansys. then launch the "setup licence" it will look for a licence file in a folder named "Licencing".
The licence file you can get it from a folder named "magnitude" where you can find aansys.dat file. you open it with notepad and then change the name of your computer and an adress. you will get these information from executing "WinHostId".
when finshing this changement, you execute "keygen" this will ran a licence.dat file. You copy it and you paste it in the licencing file. and wait for the end of installation.
this is not all :) you have to go to the environmental variables and create a new one:
ANSYSLMD_LICENSE_FILE = 1055@host
where host is the name of your computer
click ok and enjoy Ansys
Mar 01, 2010 | Computers & Internet
Dear Sir/Madam, I have just bought a new computer and I have an existing Lexmak 4300 Printer and Scanner, so far I have managed to install the Printer and it works O K but I don,t know how to Install the...
if you have a oem install disk uninstall the present installation disconnect from the web disable you anti virus and reinstall. if your down loading from the web save the files to your desk top. disconnect from the web disable your anti virus and run the install from your desktop. scanner drivers are often thought to be viruses by antivirus programs and will prevent them from being installed
Nov 25, 2009 | Lexmark P4350 All-In-One InkJet Printer
Error 2753 HP3055
My Scenario:
OS: MS Windows XP SP3 [Version 5.1.2600]
Printer: HP LaserJet 3390 (AiO) (Firmware datecode: 20070331)
Printer Connection: Connected via Ethernet with a static IP address
HP Driver Version: v4.0 (hp_LJ3050-3052-3055-3390-3392_Full_Solution_AMWE.exe)
Ran into same error that everyone else is experiencing. (see below)
Now Launching=X:\hpzmsi01.exe -m dot4msi -l XXX -f X:\DIVins??.DAT
Error message received: The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2753.
X:\HPZBDI32.msi failed with return code 1603
MSIInstall() failed with 1603
Exit code=1603
After debugging HP's installation scripts for 2 days, here is the cause & solution I identified to this specific install error. Once I got passed this error, everything installed without error and all functionality was working properly (including scanning!).
BACKGROUND:
Microsoft Installer (MSI) error 1603 is simply a generic "A fatal error occurred during installation" -- see http://msdn.microsoft.com/en-us/library/aa368542(VS.85).aspx. This is basically MSI telling you that something very bad has happened during the installation. In order to get more details, you can turn on MSI debug logging by following this MS Knowledge Base article (http://support.microsoft.com/kb/223300).
The MSI error code 2753 is the code for "The File '<file name>' is not marked for installation.". This error can be triggered by many scenarios, but usually, it has to do with the actual installation script not properly checking for the existence/non-existence of an installation file and then not marking it for either installation/removal. I know this sounds confusing, and it is. If your curious about all the possible causes, just Google for "msi 2753 not marked for installation" and you'll see lots of results which you can peruse for your own enjoyment.
In order to identify what was causing these 2 errors, I enabled debugging for MSI via the aforementioned MS KB article
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
If all goes well, the install should now run without any issues.
Hope this helps since many people (including myself) have spent a lot of time (and HP Support chats) trying to find a workaround for this issue.
If you find this solution helped you out, please feel free to make a small donation to my PayPal ;)
Jun 26, 2008 | HP LaserJet 3055 All-In-One Printer
System wont turn on...says there is a problem with windows
Just install windows over or repair it. Could be simple file corrupt
KJ
Apr 17, 2008 | Computers & Internet
Can't install printer drivers for Vista
It complicate the data , If you have cd for r220 delete data in computer you must back first before you deleting that file , reintall r220 CD again , reintall epson support , then ok.
Dec 27, 2007 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus CX4800 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
