Question about Garden
Mower deck belt installation?
I'm looking for references/manuals on Mower deck belt installation.
  • 8,404 Answers
Any one in paarticular? Google the name of your tractor to find the manufacturers web site.
Posted on Oct 05, 2009
Belt is to long, is there a deck adjustment?
Jim, Double check to make sure you have correct belt for the deck and are installing it in the correct configuration as per manual or drawing on deck. Very few lawn tractors have deck belt adjustment, most do not, most deck belts have a spring loaded tensioner to take up the slack.
This could be some of your problem, the tensioner/idler pulley sometimes seize up and must be lubed up till they move freely, or your belt could be loose. Look in your manual or try google searching your make, model #, deck belt adjustment.
How to Change Riding Lawn Mower Deck Belt
Mower belt tensioner repair question to the Garage Gang
lawn mower deck belt routing Google Search
May 20, 2016 | Garden
I need a diagram on how to install the deck belt
I don't have,the make or model of the tractor,you are referring to. Hard to tell where to start in answering your question. Most mower decks have a belt installation decal,on the deck of the mower. Sorry,i couldn't be more helpful,not much to go on. There is something else you can do,if you have the Owner's Manual,there is a section,in the manual explaining,how to replace a mower belt and a section in there,that also explains,how to replace the tractor drive belt.Sincerely,Brad Locke
Oct 15, 2015 | Garden
I need a diagram to show me how to route new belts on the mower deck of a craftsman gt5000 42inch deck please
Just a quick note here. Look under the left,sometimes under the right foot rest,for belt installation. Usually for the mower deck,its on the deck itself. Most i have seen was a decal. The owner,s manual has the belt installation guide,also. B. Locke
Aug 14, 2015 | Craftsman Garden
Need diagram installation. A drive belt.
If you have a Craftsman, under the seat is the model number. Go Here to get the operators manual. The manual will have all the belt diagrams. Water Filters Lawn Garden Appliance Parts
Oct 14, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to replace drive belt on sears 247.28904
If you have an Owner's Manual,it will inform you,in the Manual how to go about removing and replacing a tractor drive belt. There is a decal under the left or right foot board,informing the operator how to install the belt correctly. This is a long belt.that runs from the pulley on the Transaxle to the upper pulley on the bottom of the motor. This could be a hard repair to do,if the mower deck is installed. I have removed and replaced this belt,by lowering the mower deck all the way down. I would recommend,that you remove the deck,much easier.to replace the drive belt. This is also is in the Owner's Manual.under," How to remove the mower deck". Hope this answer your question. Sincerely,Brad Locke DTD. 12/03/15
Aug 06, 2013 | Sears Craftsman Tractor Mister
My lt1000 craftsman riding mower belt broke. I bought a new one and can not seem to find the manual to see how to replace it. Can you show me a diagram please?
On your mower, lift up the seat and you will find a silver sticker with numbers on it. There is a 9 or 10 digit model number. It will look like 123.456789 Go to www.searspartsdirect.com and input your model number and perform a "model" search. I am assuming that the belt you are referring to is the deck belt. Go to the deck section and you will see a basic pattern of what shape the belt will have when installed. There are 2 kinds of pulleys on your deck...V-groove & flat side. The v-groove pulleys go on the inside of the belt, the flat side will go on the outside of the belt.
If the mower is more than 3 or 4 years, it is probably a good idea to replace the drive belt(s) also.
Good luck.
Oct 22, 2010 | Craftsman Replacement Belt for 42" Deck
Diagram for belt on mower deck of an old Roper
I think I have a diagram for this, what hp is the mower 12hp? what size cutting deck? I have an old roper 12hp which needs a new belt but don't know what size belt to buy?
My email is richy.furlong@hotmail.co.uk
Sep 24, 2009 | Garden
Owners manual
Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
Components of a typical riding lawn mower. (click to enlarge)
It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
To remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
To adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Apr 12, 2009 | Garden
Installing mower belt
The pulley at a wierd angle is the tension pulley. You may get the manual on line for free if you are lucky but not all mower manufacturers are that generous. What kind of mower do u have?
Mar 31, 2009 | Garden
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
