Question about Frigidaire Washing Machines
My Frigidaire top-load washer won't drain or rinse.
  • stiegesqt Oct 06, 2009
    It turns out that my child had put a jar of baby food in the machine and it was keeping it from spinning.
  • 555 Answers
Sounds like the drain pump is broken or the drain hose is clogged.
Posted on Oct 05, 2009
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
It wont drain out the water and it doesnt rinse/spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 01, 2011 | Frigidaire ATF6000ES Front Load Washer
When doing a load of laundry the washer will stop at the rinse cycle and not drain or spin out the excess water
heatman101
Jan 03, 2011 | Frigidaire Affinity ATF6000F Front Load...
Frigidaire top load washer model number FWS6600ES0: during the wash and rinse cycles... whether it's filling or agitating on either... water seems to be draining causing the machine to stop and start...
If it has detected SUDs it may be trying to rid them. Is your drain hose at least 30 inchs above the floor? If is ain't then gravity may be causing the problem. Is the drain hose jammed tightly into the drain? This may cause a siphoning effect.
Oct 29, 2010 | Frigidaire FTF2140ES King Size Front-Load...
Frigidaire top load washer won't rinse
this can be two issues. One could be the control knob. there could be a malfunction here. secondly, you may have a faulty water valve assembly. the relay or solenoid may need to be replaced. i would start with the control knob.
Mar 13, 2009 | Washing Machines
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
