Question about Whirlpool Duet GHW9150P Front Load Washer
GHW9150P Whirlpool washers. Are they worth repairing?
    President:
  • 1,653 Answers
It largely depends on what is actually wrong with it in the first place and how old it is. You might as well get a repair quote from a service engineer and then decide but if the repair means that you need a new controller or motor then it may not be worth it. The only problem is that you maybe asked to pay for the initial call and assessment so this might count it out anyway.
Posted on Oct 05, 2009
It has gotten very loud and makes banging noise in spin cycle, now I have found hard plastic strips after wash and smells like burnt rubber.
Hello. Most likely the transmission has gone bad resulting in dislodging of the tub causing the plastic and the burnt rubber. This is probably not worth repairing unless it is under warranty and less than 3 years old. This is the perfect time to get an energy star washer which has a government rebate of 75 dollars. Joe
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
White part surrounding metal basket is broken
Are we talking about the off white plastic Tub.? If the the tub is broken this is a very extensive and expensive repair. I would also be concerned about what caused the tub to brake.you could very well have a drum (basket) support or rear bearing issue.If that's the case the parts and the large amount of labor to repair might not be worth the effort
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
GHW9150P fills on its own
Best off to call a certified repair company such as Sears.
Mar 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I remove small clothing items from behind the tub? Whirlpool Duet GHW9150P Front
This is not an easy task and may be worth getting job done by engineer. Often whole inside machine needs to be removed to gain access. Also this would make this very expensive repair.
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer is making a clunking soundwhile rotating
probably a broken spin tub support. it is recommended to call a proffessional for this repair. all though most times it is not worth fixing. usually caused by using too much detergent
Nov 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bearing bad?
Very hard. You have to remove the tub...parts are expensive and usually not worth the head ache. But if you are up to it there is a owners manual inside the machine to aid in the repair, codes, and other problems you may encounter.
Oct 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I was told the bearing is shot on the Whirlpool Duet Washer and it is not worth repairing, the machine is only 6 year old, any advice?
a 6 year old washer should not be scrapped unless it is made in china, replacing a 5$ bearing is worth fixing. even if you need to buy a drum unit.
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet Electric Dryer has 2 programs that do not work
its the control board circuit short problem.get it repaired its worth reparing.
Mar 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Help with bearing
i do hope that you have been using he detergent if not it will take the bearing out, if you have then the bearing just went bad i would call whirlpool at 800-874-4698 they may be able to offer assistance if you dont have an extended contract on the washer
May 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
61 people viewed this question
Dan Webster
Dan Webster
Sal De
