I have a Dell All-In One Printer 810, purchsed in 2006. It won't come on. I have disconnected and reconnected, but still nothing. Any suggestions?
  • jereesman Oct 06, 2009
    Printer now working.
    Brigadier General:
  • 3,513 Answers
Hi
1. Disconnect and Reconnect AC power adapter or power cord to the device and electrical source 2. Disconnect the power cord and wait approximately 10 minutes 3. Press the ON/OFF button to power on the multifunction device 4. Disconnect and reconnect the electrical cord to ensure a secure connection 5. Try a different electrical source / outlet
Here is a snip of my notes on the same subject for an Epson printer:
Well, first things first I guess:
1.Try the printer in a different outlet (other side of room, or similar, not same power Jack)
1.If you have power here, your issue is likely the outlet, not the printer.
2.If the power cord has an "on" LED, check to see if it is lit up while plugged in.
1.If you have an LED with no light while it is plugged in, you are looking at a power adapter that is no longer working
3.If there is no "on" LED to check, your next best bet is to take your printer and power cord to a store that sells printers, and ask if you can "try" a new chord before buying it. (most stores will allow this to keep customers happy)
4.You may also want to check with the manufacturer if the chord is found to be bad, as some will send replacements free of charge.
5.The last option is that there is an issue inside the printer. This is not likely, though it is possible. Most printers have an external power adapter that keeps any power issue outside of the printer, (It would be a black box between the plug and printer.)
1.This can also be checked by "testing" a new chord at a store. New chord, still no power, internal issue.
Thanks for contacting Fixya.com
Posted on Oct 05, 2009
I got a new computer and it does not have the download for my Dell 810 on it. I no longer have the cd that came with the printer. Do you have a short cut to download so I can use the printer? Thanks
Just copy and paste.
Hope this helps.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=PRN_ALL_A810&os=WW1&osl=en&catid=&impid=
Sep 21, 2009 | Dell 810 All-In-One InkJet Printer
My windows 7 won't send anything to my dell 810 printer to be printed. The scanner part of it works but that's it. Why won't it send anything to be printed???
Uninstall the Windows 7 drivers, disconnect the printer, download and install the drivers from Dell's support site and reconnect the printer.
Apr 16, 2009 | Office Equipment & Supplies
Printer
try unplugging the power brick & cable asembly......also unplug the usb cable & then reconnect all the cables.....try reseating the cartridges & thn if nothing wrks......lift the printer about 3 inches & drop it....wat it will do is clear any obstructions.....
Jun 25, 2008 | Dell 810 All-In-One InkJet Printer
Dell 810 printer
If you have had the cartridge refilld just press the continue rtab on the window
May 12, 2008 | Dell 810 All-In-One InkJet Printer
Error Message "Communication Not Available
Please open the link and follow the instructions this will definately resolve the issue, and please respond with comments to impove better service and resolution
Communication Not Available" Error When Sending a Print Job
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=true&docid=2AA10ED87ADC4C0EE040A68F5B285B98&journalid=45AF3C8CB5A7BDF9E040A68F272874F0&l=en&s=gen
Regards
Feb 04, 2008 | Dell 810 All-In-One InkJet Printer
Dell 810 giving Incompatible Ink Cartridge error message
Hi try these steps
STEP: Disconnect and Reconnect the Printer Power Supply
Top of Form 1
Bottom of Form 1
Unplug the power cord from the wall socket.
Disconnect the power supply from the back of the printer.
Wait 15 seconds.
Reconnect the power supply to the back of the printer.
Plug the power cord back into the wall socket
STEP: Clean the Contacts and Wick the Ink Cartridge
Ensure the printer is powered on.
Lift the scanner unit.
Open the cartridge latches and remove the cartridges from the carrier
Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back.
Turn the cartridge so that you are looking at the contacts on the back side of the cartridge
Using a clean dry cloth, wipe the contacts so that no dust or other contaminants are visible
Clean the contact inside the printer with the dry cloth used to clean the cartridge contacts.
Replace the cartridges in the carrier and close the scanner unit.
STEP: Verify Each Cartridge Carrier Has an Ink Cartridge
Check to make sure the left cartridge carrier contains a black or photo ink cartridge.
Check to make sure the right carrier contains a color ink cartridge.
Remove each cartridge and examine it to make sure the protective tape has been removed from the contacts and the print head.
Replace each cartridge in the proper carrier.
Let me know the status.
Regards
Jan 07, 2008 | Dell 810 All-In-One InkJet Printer
Dell 810 not printing
Dear chibihamster, It seems that there is some loose connection in your printer. If you have a little knowledge in hardware, please open your printer carefully, check all the connected cable specially the printer head connector. The best way is that disconnect the printer head cable and reconnect it again. Do not do anything in your scanner circuit area, otherwise it will create you more problems. If this doesn't solve your problem, please contact the manufacturer. GOOD LUCK!!
Aug 31, 2007 | Dell 810 All-In-One InkJet Printer
New installation 810, printer works A1, scanner won't work
Uninstall and reinstall the software. Normally the software installed on the computer controls the scanner functions for the all in one dell stuff. Check dells site also for any updates that might correct this issue.
Jul 08, 2007 | Dell 810 All-In-One InkJet Printer
13 people viewed this question
k24674
jasbo
jasbo
