Question about Cameras
I recently dropped my Samsung es55 digital camera and now the lense will not retract and no image is displayed on the screen. I am also unable to take pictures. However when I go to view pictures on the camera the screen works perfectly. How can this be fixed?
advance
  • 107 Answers
SOURCE: broken camera
It is likely that your lens assembly was knocked out of alignment when you dropped the camera. When things do not line up inside the lens the whole unit cannot move in and out. This malfunction requires disassembly to fix, so you will have to get it to a professional for repair. There are providers online who can repair your camera, and also check with your manufacturer to see if they can service the camera at a reasonable rate. David Millier Advance Camera Repair
Posted on Mar 06, 2007
t00nz
  • 4738 Answers
SOURCE: Canon PowerShot S2 IS Digital... E18 Problem
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 18, 2008
GULSHANclt
  • 408 Answers
SOURCE: Dropped Sony Ciber-shot when lense
sir,
open your camera,beside the cam part u can see the small gearbox, un screw this part and disconnect it from the base, then slowly turn the lense assy to both side carefully, dont give force. if the lense assy becom loose, fix the gear unit give a 3volt to the motor bring the cam to retracted position,then fix whole unit, it will work properly
thanx,
gulshanclt
Posted on Sep 03, 2008
  • 919 Answers
SOURCE: zoom lense wont retract
The problem you are describing is a problem with something in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $73.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on Apr 03, 2009
byron21
  • 151 Answers
SOURCE: dropped my cano a520 with lense out and now I get
E18 error is common error if the lens is broken already
bring your camera to the nearest repair center
Posted on Aug 21, 2009
Samsug es55 camera
you have to turn on the screen in the menu usually under display
Oct 19, 2012 | Samsung Digital Cameras Digimax ES55, i8,...
Shutter lense is stuck out, want retract. Display went black. want retract and display is black.
Hi, It sounds like the lens is stuck, possibly from dropping? Either way if lighting tapping it doesn't work then unfortunately there's no way it can be fixed.
Aug 29, 2011 | HP CB350 Digital Camera
Someone sat on my es-55 samsung camera, when i put it on an ink blot picture appears on the screen, this might be the lcd screen , the lens is okay as it still slides out.How do i fix it?
Hi
Does the 'ink blot' appear on any pictures you are taking or just on the Samsung ES55 LCD screen?
If it just appears on the LCD screen it's probably been damaged when it was sat on, and the only option would be to replace the LCD screen by contacting a Samsung service agent in your region.
If the 'ink-blot' image is appearing on the pictures you are taking then check the lens is clean - be careful not to extert to much pressure on the lens when it is retracted.
if the lens seems clean, as a last suggestion change memory card, or totally reformat the card that is in the camera - if the card has become corrupt the images may not be displaying correctly.
I hope one of these few suggestions sorts your problem.
Regards
David
Jan 17, 2011 | Samsung Cameras
Hi,When I start my camera ES55, there is a note saying "card error"..does this mean I have to buy a new one? I am unable to use the camera or get prints made from the card.
Yes, this means the card is faulty, a friend and myself have experienced this same phenomenon with the es55 and apacer 8 gig sdhc class 10, works fine and then nothing, no response from samsung yet!!
Jan 07, 2011 | Samsung Digimax S630 Digital Camera
Samsung S760 digital camera.Lense does not not retract and there is no display on screen.Camera does not respond when any function button is pushed..Installed new batteries.Green indicator flashes when...
You may have gotten a light debris in the lens. Just the littlest amount will cause the lens to jam. Try a can of compressed air and blowing it out.
Jul 23, 2010 | Samsung S760 Digital Camera
I have a sony DSC-W170. It was dropped and now
I had exactly the same problem with my Sony Cyber_Shot. Here is what I did and the problem was fixed. I cleaned around the lense. While I turned the camera off, I pressed down the lense very softly (some up and down motion). After a couple of times, the lense retracted almost completely. Then I pressed a little harder until the lense retracted 100% as normal times. I turned it on everything was back to normal. If the lense does not have mechanical problem, you should be able to do what I did.
If there is no mechanical problem, most likly some dirt got on the sides of the lense while it was open. Try keep it very clean always.
Good luck;
Jun 15, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
S630 won't turn on
Openings the lense is the last thing you want to try. If you dropped your camera, you may have to. If you did not drop your camera, some dirt somhow got on the sides of the lense and they prevent your lense from closing or opening 100%
Try this first
turn it on and the same time pull the lense out. Your lense may not be open all the way out. OR
Clean the side (outside) of the lense. While turning your camera OFF, push on the lense in NOT too hard. Try that a few times, If the lense retracted 100% or near 100%, just push the lense in a little harder untill it is 100% retrected. Turn it on, It may work now.
Good luck!!!!!!!!!!
Good Luck!!!!!!!
Jun 11, 2009 | Samsung S630 Digital Camera
Fuji finepix a600
If the camera was on when it was dropped you probably jamed the lense coil. The lense coil is what helps the camera smoothly pull in the lense and back out. Now, just to specify, what exactly are you having a problem with? Will the actual lense not go back into the camera when you turn it off; or can you not get your camera off zoom?
Let me know~
Olivia
Oct 30, 2008 | Fuji FinePix A600 Digital Camera
Jammed lense
Same, one day i was just taking a photo and the lens jammed.
I took the camera from the place i bought it and asked for it to be repaired ( warranty repair) it took them 3 months to repair it. Now when i got it back the SD card won't fit in. l am demanding for a new camera.
Best get it repaired. Thanx Devin
Mar 04, 2008 | Samsung Digimax S500 Digital Camera
Cameras Logo
286 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
