Question about GE Refrigerators
My GE Refregerator Model GSS25UFPA dispenses ice but no water. The water selenoid input is ok. The cooling coil behind the crisper basket is not frozen. The same lever turns on the ice and water and no problem with ice. This leaves the possibility of a frozen line inside the door. What is the easiest way to gain access to the water line inside the freezer door on the freezer side.
2 Suggested Answers
SOURCE: My water dispenser in my GE refrigerator does not
We have an Electrolux Wave Touch with the same problem.
1 yr later, 3 new fridges, 1 new freezer door and no solution.
Yes, the line is clearly frozen inside the door.
Disconnect waterline at bottom of freezer door and activate solenoid - then you know for sure.
Posted on Oct 06, 2009
KBFS20ECWH - On delivery, large coil of white tubing behind the two crispers. What is this?
it is most likely the water line. If you are not hooking it up to water, you can remove it.
May 18, 2015 | KitchenAid KBFS20ECWH Architect II...
The food in the refrigerator drawers (crisper and meat) are freezing and the waterline froze. What is causing this and is it worth repairing?
I have Ge GSS25XSQA SS side by side and the food in the refrigerator drawers (crisper and meat) are freezing. Also the ice dispenser is frozen closed. The water dispenser still works.
Want can I do to fix it. Would dirty coils have anything to do with this?
Terry
Nov 10, 2010 | GE GSS25SGPSS Side by Side Refrigerator
My water dispenser in my GE refrigerator does not dispense water. The same lever that dispenses water also dispenses water. I have checked the ice and water selenoids and they are working. The cooling coil...
Oct 05, 2009 | GE Refrigerators
On my Kenmore model 106.74254400 refrigerator the water dispenser quit working. I push the button dispenser but nothing happens. The ice maker is working fine. Could it be the water dispenser switch?
It could be the switch. It also could be the resevoir is frozen behind the crispers. It could be the water valve has a bad coil. It could be a plugged filter if you have one in the line. Was the frig recently extra cold just before the problem? Check the resevoir first.
Eric
Jun 29, 2009 | Refrigerators
In door water dispenser isn't dispensing water.
you did not say which brand, how old, or the model. But if your refrigerator is cooling properly..check the water resevoir behind the crisper drawers. It may be frozen up. I have seen this many times. You also have to check both soleniods on the water valve ( supply ) and the filter valve, if yours has a filter valve. I can't tell without model and make etc.
May 04, 2009 | GE GSH25KGRWW Side by Side Refrigerator
The water dispencer dribbles the water out.
The water hose coil is to chill the drinking water coming out of the dispenser. If the water drips out it could be a bad solenoid valve since the water dispenser requires power to dispenser water. If the Ice maker is working fine then check the dispenser water solenoid valve.
Dec 27, 2008 | Frigidaire FRS23H5AS Side by Side...
GE Fridge Not Dispensing water
First place to start is in the fridge. Look behind the crisper drawers for the water tank. It may have frozen at the outlet line. Try thawing it out with a hair dryer or a heat gun, being careful of course not to melt anything.
Dec 13, 2008 | Refrigerators
Water line
That coil is the line to the water dispenser, and its purpose is to chill the water before dispensing it. The coil of tubing is better than a tank because it chills quickly, takes less space and doesn't hold stagnant water. It shouldn't have any effect on the icemaker.
Jul 26, 2008 | GALAXY Microsystems 25.4 cu. ft....
Freezer/water not coming out
An Ice/thick frost build up on the back wall of the freezer if a side by side .The tank will be behind the crisper drawers you will see it frozen block of ice verses water in it you can tap it to see if the water moves.. Your water inlet valve on the disp. side maybe bad as well. Is the refrig section cooling ok??
Feb 11, 2008 | GE GSS20IEM Side by Side Refrigerator
No water from dispenser
I could not locate any white tank where the water comes to/from. There is only a clear plastic water line behind the crisper drawers, that is coiled up and goes up to the water filter at the top on one end, and down through the bottom of the fridge on the other. The coiled line seemed like perhaps it was frozen, so I took a hair dryer to that but it didn't help. I also tried removing the cardboard cover in the bottom back of the fridge, to see if perhaps the white tank was back there, but it was only
more line, which goes towards the front of the fridge, where it goes up into the corner of the door.
Jan 05, 2008 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
