? 3:44 www.youtube.com/watch?v=io2aCjM0o8Y
Sep 30, 2011 - Uploaded by askanthonynow
After new bearings were placed into an idler pulley, it is being installed on the deck of the mower. This is the .
How to Replace the Deck Idler Pulley on a Troy-Bilt Pony ...? 8:04www.youtube.com/watch?v=HY9AuNe5DWAAug 13, 2013 - Uploaded by eReplacementParts.comThis tutorial will show you how to remove and install the idler(4.25") pulley on a Troy-Bilt Pony lawn tractor/riding mower. Helpful items include ...How to Fix the Idler Spring on a Zero-Turn Mower ' Home ...
no fire , sounds like your having a problem with one of the safety switches on mower deck ckt look under tractor but over mower deck for a loose or hanging wire bet it goes to a switch ?
there is a sealant called slime it is green in color at lowes or depot or walmart read directions and install
or you can buy a inner tube and fix it
tube size is based on tire size
check inside of the tire before the tube is used if you go that route to be sure there is nothing to puncture the tube.
you can buy string type plugs to plug a leak if it is in the tread
use windex or equivalent to search for a leak
if its leaking around the rim remove tire and completely clean the rust from the inner rim where the tires bead seats against the rim when inflated.
