Question about Dryers
My dryer works and seems to be heating up but the clothes won't dry, even if I put just one thing in there. However, the utility room seems much hotter than it used to, almost like the heat is going out instead of in.
  • Dryers Master
  • 8,404 Answers
You have a clog in your exhaust somewhere. You must find it and clear it out to prevent serious trouble.
Pull the machine from the wall, remove the exhaust hose and start vacuuming both directions. Do the hose as well ... if the exhaust hose is plastic, replace it with a flexible metal one. Dontf orget the outside vent. When you are sure you cleaned all of it, reassemble and try again. Let me know what happens.
a
Posted on Oct 05, 2009
KitchenAid kdte104dss0 is not drying properly. No steam comes out of side vent. Not sure if there should be steam coming out? It seems to dry somewhat but not completely.
is there any heat coming out of the dryer? If the heating system is not working the dryer will only blow room temp. air and will not dry the cloths.
Aug 02, 2015 | Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
WON'T DRY CLOTHS..NO HOT AIR
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'';';
Jun 27, 2011 | GE Dryers
Put the cloths in the dryer like usuall and waited for peep to let me know its dry. but when i heard the peep assumed the cloths will be dry, the cloths were just like i got out of the washer, wet. it is...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 02, 2011 | LG DLGX8388 Gas Dryer
The sensor doesn't seem to work?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 22, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer not drying clothing.
heatman101
May 24, 2010 | GE Profile Harmony DPGT750EC Electric...
It seems like the burners are not all lighting. Maytag Epic Z gas
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Dryer doesnt dry clothes
I suspect you have a blocked air vent. A blocked vent will definitely extend your drying time. You may even find yourself having to run a load twice to get it fully dried. One way to confirm this is to disconnect the vent hose from the back of your dryer and dry one load with the machine venting directly into your laundry room. If that load dries quickly then you know the problem is a blocked vent. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Jun 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Urotech EWC177 Combo
Same problem here and mines brand new. Seems the dryer consists of only a heating element. There's no circulation of dry air. You may as well hang your clothes inside a steam room.
Mar 10, 2008 | EuroTech EWC177 Front Load Washer / Dryer
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Open Questions:
Dryers Logo
26 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
