Question about Toto Drake ADA Compliant Toilet with Elongated Bowl
Our new Toto Drake toilet is experiencing some problems and we need to figure out if it's the toilet or a plug in the sewer pipe. After plunging a normal plug, you usually see some ****mixed with the water. Not in this case. I then dumped soapy hot water down the drain and it's still not flushing really. The water has emptied out, but it's now right yet. Any ideas? We have a 25 year old city sewer pipe but still a well system.
We invited Roto Rooter out and he had it snaked out in about 2 minutes flat! No more problems for now. I think we need to purchase one of those tools!
Posted on Oct 06, 2009
Toto toilet won't flush
Replace the assembly. This is common in areas with high mineral content in water. You will be glad you did. Delay too long, you may find your toilet running while you are at work .
Jan 25, 2013 | Toto Drake ADA Compliant Toilet with...
Love our new Toto Drake II double cyclone toilets with sani gloss finish. However the trip lever handles are already getting loose on both toilets... what would cause this-- and what is the...
dalbritton-
The handles are fixed to the tank body with a hex nut on the back (inside of the tank. They may not have been tightened properly from the factory. Tighten a bit with a wrench and you're good to go!
Regards,
DIYpro
Jun 08, 2011 | Toto Trip Lever For St774S Toilet Handles
My toliet is clogged and can't get the water to flush. i have plunged, empyt out the water, not sure what else to do...
sewer line is clogged get a pipe snake find the acess hole to ur sewer line outside and insert the pipe snake stick it all the way in and then go the other direction! this should clear it!
Nov 08, 2010 | Toto Promenade, 1.6 GPF, Elongated...
TOTO DRAKE flushes then the tank fills, stops, then slowley leaks and the water just runs on and on at a trickle pace down the overflow spout.
The rubber stopper that is inside the back of the tank is allowing water to get by do to:
(1.) Be wore out- must be replaced with a new one.
(2.) The chain that is connected to the flush handle needs to be adjusted. However, if it has not been messed with recently, then it will be the (1.)
Jim
Sep 13, 2010 | Toto Drake ADA Compliant Toilet with...
My Toto Drake toilet makes a noise like it is gasping for air when the tank is refilling with water. The water flow stops and starts while this noise is being made.
just simply clean the auto switch,the noosle where the water comes out when the floater goes down everytime the tank is empty with water.
Jan 11, 2010 | Toto Drake ADA Compliant Toilet with...
Tank fill valve sticks
Defective fill valve contact Toto for a free replacement part
Dec 07, 2009 | Toto Drake ADA Compliant Toilet with...
Flushes very slowly, not the "power" flush it used to do.
This type of problem is, for pretty obvious reasons, difficult to diagnose, especially when you can't interact with it. My guess is that you might actually have a blockage in your venting system. This system allows air in behind the water you are flushing to allow it to flow freely down the drain. If you have a blockage in it, the water has to pull air through the trap in the toilet, and that can lead to symptoms like the ones your describing. Are other drains in the bathroom running a little slower as well? Sometimes birds or squirels build nests in the top of vent pipes (which generally stick out of your roof) and end up blocking the air flow.
Sep 21, 2009 | Toto CST744S Two-Piece Elongated Toilet...
Toto toilet is running
You will have to use ToTo OEM replacement parts. If the water is going over the overflow pipe, the fill valve washer will need to be replaced. If the water is running into the bowl and not over the overflow, the flapper will need to be replaced.
Apr 05, 2009 | Toto Drake ADA Compliant Toilet with...
Toto Drake ADA: Usual rush of water on flushing doesn't happen
Problem solved.  Reason was a totally blocked waste line that resulted in toilet malfunction.  Toilet functions normally now with removal of blockage.
Dec 27, 2008 | Toto Drake ADA Compliant Toilet with...
Toto Drake ADA Compliant Toilet with Elongated Bowl Logo
203 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
