Question about Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer
Fridgaire leq7000ego won't heat flashes 3 lights
Fridgaire dryer leq7000ego won't heat flashes 3 lights
What does Dryer showing E68 code and will not dry LEQ7000EGO
Most likely your touch pad or control board is defective. Replacing the control board will fix the problem.
May 19, 2014 | Electrolux Dryers
Dryer wont heat up
Good Afternoon Friend,
I understand that you are having trouble with your Frigidaire Affinity dryer not heating up. There are some things that you are able to try. First check to make sure that the lint filter, the ducting, and the outside vent, are clear of lint and not constricted in any way. Second, reset your appliance by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. Once power has been restored, run any cycle. If you are still noticing that your dryer is not heating, I suggest contacting your local authorized technician for further assistance. They should be able to diagnose your dryer and determine why your appliance is not heating. Hope this is helpful.
-Best Regards-
WP
May 12, 2014 | Frigidaire Affinity ATF7000E Front Load...
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Frigidare dryer gleq215ee won't heat then shuts off after about 10 minutes. 4 lights on right flash. no error code comes on. I am pretty handy and can take apart and fix. would need to know what t
Hello John Sterns - First, try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective then typically this is something that a professional would need to diagnose. Since it is such a complex unit, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch.
Dec 09, 2012 | Frigidaire Electric Dryer
My dryer will run, but won't heat. After about 15-20 minutes, the dryer stops and all the indicator lights (drying, cool down, etc.) flash but no error code shows. I took off the front panel and...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Frigidaire GLGQ2152ES Gas Dryer
Fridgaire electric dryer does not get warm to dry clothes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 10, 2010 | Frigidaire GLER341A Electric Dryer
My Whirlpool Cabrio dryer takes forever to dry anything (3 hours for just a couple shirts!). There is a code AF flashing on the display window, but i have checked all the airflow issue places and nothing...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 31, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My dryier stopped working soem time ago for no apparent reason, recently when we trried again we got, orange flashing lights and a F 11 on the display screen, Anybody got any ideas what this means
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 03, 2010 | Siemens WTXD8300 Electric Dryer
Frigidaire dryer overheating
the other tstat is on front of blower housing..lift top remove screws at top of front panel from inside remove switch wires front lifts off ..be sure to ck vent first most dryers have thermal fuses that will blow if overheating does occur since yours seems to be working i would suspect vent first..if your concerned about dryer being hot to touch along top rear this is normal heating element is located just below console at rear
Nov 13, 2008 | Dryers
Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer Logo
89 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
