Question about LG DR787T DVD Recorder
DVD TRAY KEEPS ON OPENING AND CLOSING CONTINOUSLY
DVD TRAY KEEPS ON OPENING AND CLOSING CONTINUOUSLY UNTIL MANUALLY PLUGGING OUT THE POWER CHORD. THE PROBLEM IS THAT THE DVD RW WONT READ CAUSE OF THE OPENING CLOSING OF TRAY THE WHOLE TIME. I NEED TO SAVE SOME FOOTAGE RECORDED ON THE HDD...... IS THERE ANY WAY OF GETTING AROUND THIS PROBLEM
LG HDD/DVD RECORDER RH278
Hi, I have exactly the same thing. Happened before but went away when I got bored trying to fix it. This time I phoned LG support and they said take it back to Comet (they have bought out their servicing). End of conversation. Polite but firm.
Appalling support via their websites, appalling products. Never again.
Posted on Apr 24, 2010
Sony dav-dz555k home theatre system-dvd tray keeps opening and closing, wont read disc at all. have to manually push tray closed and change setting from dvd to something else to stop it.
You seem to be having a door sensor problem. When the CD tray closes a small switch under the loading tray shorts telling the microprocessor the door is closed and to stop the motor (either way when it opens or when it closes). A malfunction in this switch causes this symptom.
Mar 14, 2011 | Sony Audio Players & Recorders
My DVD tray on my Yamaha DV C6480 (it holds 5 DVDs) got stuck in the half open half closed position. It may have come off the track. I opened the case and reinstalled the DVD Tray. Now the tray...
This happens to us all the time. Here is the note I keep on how to fix it quickly:
When tray gets messed up, the drive wheel (with pegs that interlock with pegs on the tray) needs to be such that the tray slides in and out freely. Push tray all the way in. Turn on.
Hope that gives a hint.
Nov 04, 2010 | Yamaha DV-C6480 Multi-disc DVD Player
Display says BLOCKED and DVD tray wont open anyone any ideas
To open the DVD tray: -
1. Remove Power
2. Invert the player, and look for the slot (about 2.5cm long) near the front of the player under the tray.
3. Shine a light into this slot to locate a white plastic lever
4. Insert a plastic blade an slide the lever to the opposite side of its travel, and the tray will start to open
5. Turn the player the right way up and continue to open the tray and remove DVD
NOTE: Depending on what caused the blockage to be reported, they player may or may not revert to normal operation. If like mine there is an underlying fault, then once power is re-applied the fault will still be reported whenever the tray is closed. In this case the motors that operate the tray are inoperative, and I've no didea why. In fact that's what made me read this website. So I hope you have more luck than me.
Regards, D.
Feb 09, 2010 | Philips DVDR70 DVD Recorder
Non-opening dvd/rw
Well, it may have got jammed. so try this trick.....
If you look at the dvd/rw drive..on the side of the button of the drive...you will find a very tiny hole so take a paper pin and insert it in the tiny hole if the drive is opened great!!! otherwise get it replaced as the dvd/rw drives are not costly thesedays..
Sep 08, 2009 | Pioneer DVR-107D DVD±RW Burner
The power light blinks, reads open tray/close tray . . .
it sounds like your dvd drive is dead if its still under warranty you should just send it back to microsoft the only other thing you could do is buy a replacement dvd drive and put it in yourself but only do that if microsoft wont take it or you'll void your warranty
Aug 25, 2009 | Microsoft Xbox 360 Console
DVD tray won't open.
Opening a CD or DVD drive to retrieve a disc
  • Use Windows to open the drive door:
    1. Double-click the My Computer icon on the desktop (or click Start and My Computer in Microsoft Windows XP).
    2. Right-click the CD, CD-RW, or DVD drive , and then click Eject .
  • Restart the computer and press the EJECT button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD drive. Try shutting down or configuring any programs that write discs or monitor the CD drive.
  • If the door still will not open, do the following:
    1. Close all programs and shut down the computer.
    2. Unplug the PC from the power outlet and remove the battery.
    3. Locate the manual release hole in the front faceplate of the optical drive tray. This is a small hole under the door that is a little bigger than the diameter of a paper clip. The location of the manual eject hole will vary.
    4. Insert a straightened paperclip into the manual release hole until resistance is felt.
    5. Once the resistance is felt, keep pushing the paper clip until the drawer comes out about a quarter of an inch.
    6. Remove the paper clip and gently pull out the drawer until the disc is accessible.
    7. Remove the CD and turn on the computer.
May 21, 2009 | Daewoo DVG-3000N DVD Player
Pioneer DVD R/RW drive DVR-K17LA not reading
Normally no drivers are needed for CD drives other than the ones built into Windows. It might be a dirty lens that is causing the trouble. When the tray opens on a laptop CD drive the lens is exposed and can get touched or exposed to dirt. Try gently cleaning it with a cotton swab to brush off the lens. If the problem continues, the laser may have worn out and is too weak to read now. You can find replacement drives online, or use a USB plug-in external drive.
Apr 27, 2009 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
HP DVD 635 - auto tray open
no ghosts, you either have something jammed up inside of the drive which is keeping the door from closing properly all the way or the door itself is defective.
Either way you would be better off replacing the drive with a new dvd-rw cause the drive would be up to date and the problem with the opening door would go away.
Mar 21, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
LVW-5005
Unplugging the power chord to unit for sometime (around 20 - 30 minutes) and plug back the power chord .
After that press the eject button for 30 seconds at times this may work and you can get back the dvd from the player .
Oct 29, 2008 | Lite On LVW-5005 DVD Recorder
LG DR787T DVD Recorder Logo
879 people viewed this question
Computer Repairing
Computer Repairing
