Question about Cameras
Hi,when i went on holliday the lens got stuck half way.I was unable to retract the lens shut, when i switched it off.When I got home the repair was to much,so I decided to open my hitachi hdc-831e camera up and found a small cog that allows the lens to open,had a tooth broken, which preventedthe lens from retracting.Can you tell me where i can buy this little part.ps I can send photo of part to you.thanks Kevin
  • 13433 Answers
SOURCE: Kodak EasyShare M853 Digital Camera lens error 122,1,0,0
Best to send in for service.
free estimate
http://www.advancecamera.com/repair/
Posted on Jul 25, 2008
SOURCE: Canon Powershot SD1000 Lens Will Not Retract
This is a huge recurring problem with Canon cameras. check out this website-give it a minute to load. You will see literally thousands of people with the same experience.
http://e18.bitnet.cx/comments.php?full=1
Posted on Aug 22, 2008
  • 4 Answers
SOURCE: Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Posted on Aug 27, 2008
PAPA-RAZI
  • 37 Answers
SOURCE: coolpix lens opens retracts opens then closes again and lens error appears
Hello
When you turn the camera on the lens comes out and has parameters when extending to focus, if the lens does not open fully it sees a problem and then closes.
there are tiny plastic gears inside and may have chipped or a piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
Posted on Sep 02, 2008
  • 102366 Answers
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
My lens will shut half way, then turns off automatically. Once I turn the camera on. I Cannot take pictures. Any advice will help. Thank you
Hi Natalie:
Lens stuck, is common defective that need new lens unit replacement or just repairable.
Causes of a Lens Error: There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Frankly, however, it's unlikely that a lens error will qualify for the warranty.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 15, 2011 | Samsung Digimax S800 Digital Camera
My Lens will only close half way.
Hi Natalie:
Lens is stuck half out and when I hit power, it says to "turn off and back on again" but nothing changes
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Jan 26, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Lens error
Dec 17, 2009 | Canon IXUS 80 IS Digital Camera
The lens is stuck 1/2 way out and I am unable to access the menu and have taken the batteries out and even replaced them.
Oct 30, 2009 | Nikon COOLPIX L18 Digital Camera
Sony cybershot DSC-W170 lens malfunction
sounds like you have dust, sand of some type stuck in the retracting lense. Ive found someone to tell me to take out my batterys and SD card, then tap the bottom of the camera on a table top. Replace the batteries and power up. Doing this, I was told it loosens up the debri for the lense to retract to close and to open again.
Aug 24, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
My digital Sony camera fell down Lens got stuck
    As in short answer you have to replace the optical lens assymbly.Because due to heavy jurk its motor called sledge motor stsrt malfunctioning and it can not be changed component level. For this please contact any SONY SERVICE CENTRE nearby to you.
Hope you will understand.
Thanks for using FIXYA!
Apr 28, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Konica Minolta Z6 camera lens won't retract or zoom out
I have the same problem. The lenses does not retract when turned off or function with the zoom control when turned on. Has anyone found a fix?
Dec 27, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Lens error
There is a possibility that a bit of grit or debris has got stuck in the retraction mechanism or the lens has been knocked out of alignment.
The camera will have switches inside to tell it when the lens is retracted or extended and if it doesn't make contact within the expected time then it will give this error.
If the there is no warrantee or you dont mind voiding it then I would suggest carefully disassembling the camera and turning the retraction motor by hand to see where the problem is.
Please comment again if you discover anything.
Good luck
Oct 19, 2007 | Nikon Coolpix 5200 Digital Camera
Cameras Logo
19 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
