Question about Canon EOS-1D Mark II N (Body Only) Digital Camera
Canon 1D has a bright streak across all images
My Canon EOS 1D MkII N suddenly started having a white flash across my images. The bright area looks like the end of a sword. The image is still visible behind the bright spot.
4 Suggested Answers
smilemaker
  • 790 Answers
SOURCE: Lines across the images
Hello!!!
Try hard resetting once!!! Switch off ur camera , remove the batteries and press the power button for few seconds. then put the batteries back and try powering on!!
Posted on Nov 04, 2008
  • 51 Answers
SOURCE: diagonal black line across the bottom right corner
Most likely the shutter blind is sticking and not getting out the way when you take a picture. It will need a service.
Posted on Nov 29, 2009
Obertelli
  • 3006 Answers
SOURCE: Hi, I`ve got Canon 1D
Your camera almost certainly has a shutter fault and must be professionally repaired.
Replacement and recalibration is a not a DIY job. Expect to need a new shutter assembly; it's not cheap but is still cheaper than another SLR.
If you're very lucky, the repairer may find a simple fault with the existing mechanism and offer to fix it but if you depend upon your camera for a living then be absolutely sure that it's as reliable a repair as replacing the shutter assembly. If the fault has existed for more than a couple of dozen of shots then there will already be adverse wear to other elements of the shutter assembly which may either cause it to fail again soon or will require it to be recalibrated.
I hope that my answer has been of assistance, please take a moment to rate my free answer.
Posted on Sep 30, 2010
Why are no photos being displayed on screen after shooting?
PDF]PDF QuickGuide to EOS Live View Features
https://www.learn.usa.canon.com/.../CDLC_EOSLiveView_Q...
Canon Inc.Canon EOS cameras when used in their Live View mode. ... directly onto the sensor, which in turn displays the image ... EOS 40D, 5D Mark II, EOS-1D Mark III, EOS-1Ds Mark III, ... Mark III do not offer movie options. ... to produce a fixed screenbrightness, or Exposure .... settings for the following camera menu options:.
Canon Knowledge Center - Changing the AF Mode to Use ...
https://support.usa.canon.com/kb/index?page=content&id=ART134415
Nov 4, 2015 - ID : 8201360200 _ EN _ 1. Solution ... While the Live View image isdisplayed, you can press the < AF?????????DRIVE &gt; button to select the AF mode on the setting screen displayed. 9. ... If focus is not achieved, the AF point will turn orange. .... Shooting movies with the default settings (EOS 5D Mark III)
Dec 25, 2015 | Canon EOS-1D Mark III Body Only Digital...
Canon 550 ex speedlight - flashes okay. Won't sink with 60d (tried different cameras at dealer - same problem) Camera is okay .
Bruce,
Try these steps:
1. Set camera to manual2. Set shutter to 1/60
3. Set aperture to F5.6
4. ASA/ISO 200
5. 550EX on hotshoe
6. Do not set on slave or master
7. Turn on flash
Display must shows, ETTL.
If that doesn't work, you have to use the flash on manual.
Some of this model will not work fully on ATG Canon EOS-1D C, ATG Canon EOS-1D X IR, Canon EOS-1D X/60D/T4i because this flash is over 20 years old.
Unless you would want it to be modified by me.
But that can be costly when you can get the 580EX II for less than $425.00 USD.
atdlee@netzero.com
Jan 01, 2013 | Canon Speedlite 550EX TTL Flash
My Canon 1D MkII suddenly started capturing images completely black. File sizes are smaller 2, the black images are only 2mb. Could it be possible the data is no longer getting recorded to the memory...
The first thought I had come to mind was the shutter has failed but, the Canon 1D MK II shutter is capable of 150,000 actuation. If you feel this is not possible then another thing you may want to look into is the memory card needing to be cleared of pictures and formatted in the camera, always format your memory cards in the camera. The Canon 1D MK II has two memory card slots it is possible to have one card undersized and it's run out of space, the camera will not automatically shift to the unused card it needs to be done manually through the small screen on the back.
This just happened to me while in a portrait shoot the battery died to the point it wouldn't even show the setting on the top LCD screen or the viewfinder. I replaced the battery and continued to shooting. The camera had been set on RAW but after the battery failure it began shooting RAW+ s jpg. If you had the camera set for jpg images and the battery failed as it did mine then it's entirely possible that the camera defaulted to small jpg files. Okay last suggestion and possible the most important. The Canon 1D MK II with original firmware installed is capable of working with a 4gig memory card Compact Flash or SD, if you have installed a larger card and just attempted to shoot with it without formatting, the camera will refuse to cooperate. If this is the case and you have installed a 8gig memory card(s) for example first try to format the card and if this failes then you need to go to the Canon site download the updated firmware for that camera and do an update. Everything will be good after you do this, when I did the update for mine there were seven updates one of which corrected the limitations on the memory card size. If the lens contacts are dirty and the camera is getting poor information from the lens you would I think receive a code 99 so not receiving any code of fault I'd say it's the card.
Cheers
Apr 18, 2011 | Canon EOS-1D Mark II Digital Camera
Hi, I`ve got Canon 1D mark II n with shutter problem. There is an overexposed streak that runs 3/4 across the image about an inch wide
Sep 29, 2010 | Canon EOS-1D Mark II Digital Camera
My Canon 40D LCD monitor when displaying a photo has just started displaying white sections of a picture as alternating black then white. The rest of the photo is fine just the white flashes. Any idea what...
It's possible that your Highlight Alert is enabled. Over-exposed areas of your image will blink to indicate blown-out whites. If you don't like this feature, go to the Menu, under the second blue tab (for playback), look for Highlight Alert and Disable it. When viewing the image on a computer, the blinking will not appear however. It's just to warn you that some parts of the image is so bright that all detail is lost. I enable mine so that I know this and is able to make adjustments on the ground.
Apr 11, 2010 | Canon EOS 40D Digital Camera
Canon EOS-1D won't save pix to CF card. G.
The E99 message usually ends up being a shutter box that needs to be replaced. The 1D shutter box should be good for 100,000 images or more, you can probably find the estimated lifespan on Google somewhere.
If you can"t save pics to the CF card then you might have a bent or broken pin on your CF card reader. Look down into the CF slot, does it look ok?
We are an online digital camera repair shop but we haven't done any 1D cameras before.
Thomas D,
Owner; Darntoothysam com
Oct 02, 2009 | Canon EOS-1D Mark II Digital Camera
Canon 1D shutter problem
may be shutter not opening fully some grit dust in it i had thia prob with my camera cleaned it and it was fine
Sep 15, 2009 | Canon EOS-1D Mark II Digital Camera
1D MkII Can't download photos on Mac from Smart Card
please use a card reader and transfer the photos using that. card reader will be handy for you all time. trust me.
they are very cheap too. so worth buying :)
May 31, 2009 | Canon EOS-1D Mark II Digital Camera
My Canon 40D can't handle bright yellow and reds. It blurs the detail and overly saturates the subject (flower close-ups) - so that the bright red poppy is overly saturated and lacks detail even though...
By the way are these RAW images? What type of lense are you actually using, check this
EOS-1Ds Mark III EOS-1D Mark III EOS-1D Mark II N
EOS-1Ds Mark II EOS-1D Mark II EOS-1Ds
EOS-1D EOS 5D EOS 40D
EOS 30D EOS DIGITAL REBEL XSi/EOS 450D EOS DIGITAL REBEL XTi/EOS 400D DIGITAL
Compatible Lenses
EF 14mm f/2.8L USM EF 28-70mm f/2.8L USM
EF 14mm f/2.8L II USM EF 28-135mm f/3.5-5.6 IS USM
EF 20mm f/2.8 USM EF 28-200mm f/3.5-5.6
EF 24mm f/1.4L USM EF 28-200mm f/3.5-5.6 USM
EF 28mm f/1.8 USM EF 28-300mm f/3.5-5.6L IS USM
EF 35mm f/1.4L USM EF 70-200mm f/2.8L USM
EF 50mm f/1.2L USM EF 70-200mm f/4L USM
EF 50mm f/1.4 USM EF 70-200mm f/2.8L IS USM
EF 85mm f/1.2L USM EF 70-200mm f/4L IS USM
EF 85mm f/1.2L II USM EF 100-400mm f/4.5-5.6L IS USM
EF 100mm f/2.8 Macro USM EF-S 60mm f/2.8 Macro USM
EF 135mm f/2L USM EF-S 10-22mm f/3.5-4.5 USM
EF 180mm f/3.5L Macro USM EF-S 17-55mm f/2.8 IS USM
EF 200mm f/2.8L USM EF-S 17-85mm f/4-5.6 USM
EF 200mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6
EF 16-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II
EF 16-35mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6 USM
EF 17-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II USM
EF 17-40mm f/4L USM EF-S 18-55mm f/3.5-5.6 IS
EF 24-70mm f/2.8L USM EF-S 55-250mm f/4-5.6 IS
EF 24-105mm f/4L IS USM -
Jun 30, 2008 | Canon Cameras
How do I figure out actuations on my camera?
Pre-PMA 2004: Canon today announced the impressively specified EOS-1D Mark II which features a new 8.2 megapixel CMOS sensor, it can shoot at just over eight frames per second and has a 40 frame JPEG image buffer (20 frames in RAW mode). This means that shooting at full resolution at full speed the camera is buffering 69 megapixels per second (or 100 MB/sec). Other changes include the addition of a USB port, an SD slot, the removal of the external white balance sensor as well as some subtle body styling changes.
Feb 25, 2008 | Canon EOS-1D Mark II Digital Camera
Canon EOS-1D Mark II N (Body Only) Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
