Question about Sanyo PLC-XT16 Multimedia Projector
Projector shows wrong color
My projector is showing blue when it's supposed to show red color. Any idea´s?
  • 70 Answers
Change your vga cable...
Posted on Oct 08, 2009
Sony VPL-P510 projector
there are 3 LCD panels in the projector.
red panel,green panel and blue panel
I seems that the red panel is failing
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 18, 2014 | Office Equipment & Supplies
It doesn't show red color. i tried to do factory reset. but still problem.
1.After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3 While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct.
Contact Dell if the colors are not displayed correctly.
Mar 01, 2011 | Dell 2400MP DLP Projector
I saw an answer up above regarding the green hue on the projector, is there anyway to remedy this problem? This is really annoying to me and I would like to fix the issue. Thanks,
Three LCD block in the Panasonic projector PT-L735 green,blue and red and two polarizer use with each LCD (as show in picture below) when polarizers faded due to age or any other reason then screen show the color. In your cause the green polarizers faded and need to be replaced good_help_9.png
Jan 08, 2011 | Panasonic PT L735U Multimedia Projector
The projector does not show the color red. It shows it as black or on a black background shows nothing at all. Can you help?
It could be 3 things--
1. You need a new cable
2. This is unlikely, but the red segment could be off the colorwheel, but if this was the case the wheel would be way out of balance and the projector would be vibrating like crazy.
3. The "color ramps" or colorwheel index in the hidden factory menu may need to be adjusted.
Sep 15, 2010 | InFocus LP70+ Multimedia Projector
My InFocus 4805 SP projector is showing just black and white
If you have any video at all and it's only Black and white there is a 99.99% chance that your Color Wheel has lost all of it's glass color filters.
You can confirm this by removing the lamp. then look straight into the projector where the lamp was and you should see the color wheel of colored glass segments (Red, Green and blue) I believe you won't see them because they came off of the wheel.
Also if you lift up the projector and turn it around in various angles and you will hear the small pieces of broken glass from the color wheel.
Unfortunately you will need to take it to an authorized service center for repair. Be prepared to spend upwards of $300 for the repair.
Cheers
Aug 23, 2009 | InFocus In Focus SP-LAMP-021 Replacement...
My NEC mt1075 projector is projecting a shade of blue all over. The entire screen is showing the correct image, but also with a shade of blue. I think something is wrong with the internal wiring. Is this a...
If you're using component video (red/green/blue rca cables) one of the colors may be disconnected, or the wires may be swapped into the wrong color input. If you are using a 15 pin VGA connector, one of the pins may not be getting good contact at the source or at the projector. Or if the VGA cable is split into 5-wire to make a long cable run, one of the five wires may be disconnected. Any of these problems will cause a global color shift while not affecting the color of the projector's on screen menus.
Jun 22, 2009 | NEC MT1075 Multimedia Projector
Pc connected vp6121 DLP projector shows only blue images
THE DRIVER FOR THE PROJECT OR THE INSTALLATIONAL SOFTWARE MAYBE USEFUL
Feb 12, 2009 | HP Digital Projector Vp6110 Multimedia...
Red color absent from projector picture
try to use another vga cable connector ther might be a cut on the red color signal try to move the connector form left to right until it gives you the red color if it does change your vga connector hope this help you on your problem thanks
Feb 04, 2009 | InFocus ScreenPlay 4805 Multimedia...
Colour problems with projector
In short If the reds show as red, The greens show as green & Blue shows as blue. I would say thats as good as it can project. It's hard to judge color without seeing it for ones self but usually DLP projectors that use a colorwheel do not have perfect color.
Feb 13, 2008 | Office Equipment & Supplies
Sanyo PLC-XT16 Multimedia Projector Logo
796 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
