Question about EliteGroup P4VMM2 Motherboard
Keyboard scramble I have an intermittent error when keying text in MS Word or Outlook, using a Logitech cordless access duo keyboard. All keys produce unexpected results. It usually occurs after having hit the Ctrl key. e.g. after using Ctrl← to backspace the cursor. The error for each key is consistent. querty appears as ?,.pyf To date, the only way I have discovered to correct the problem is to exit Word/Outlook and re-enter.
  • temirach Dec 23, 2007
    Speed and value of the response was fantastic!
    Beauty!!
    Scholar:
  • 103 Answers
You have different keyboard layouts installed.
Standard: qwerty, asdfgh
Dvorak: ‘,.pyf, adeuid
To prevent the keyboard from unexpectedly switching up on you, open your control panel, select Regional and Language Options.
In the Regional and Language Options dialog box, click the languages tab, select the details button at the top of the dialog box.
In the Text services and languages dialog box, under installed services: select the Keyboard United States-Dvorak service and then click the remove button, click ok, click ok.
Posted on Dec 23, 2007
Have a logitech Spanish keyboard which key/s will print from screen
The first key right to the F12 key,
If that doesn't work why don't u use a snap program like picpick where you can program the key to use to make a printscreen or just a section snap
http://www.picpick.org/en/
Oct 17, 2014 | Logitech Cordless Comfort Duo PS/2...
Where is the Scroll Lock function on Logitech Wave cordless keyboard ?
It should be to the right of the F12 key. Usually the top row of keys.
Dec 01, 2010 | Logitech Wireless Access Duo Optical...
Have cordless keyboard EX-100. Keys will not respond. The calculator and mute keys works all other do not. Have fresh batteries and reset connection button many times. My cordless mouse is okay.
You either need to push fn button (upper left on keyboard) or you need to check that the logitech keyboard software (itouch and a few other names i can;t recal) is running or installed. On mine if the software has glitched out, a quick reload of it and it works fine. This software is what is telling your computer what the special keys mean. If this isn;t running it will only be able to understand the standard type of key signals.
Sep 23, 2010 | Logitech Wireless Access Duo Optical...
Cordless Keybaord - Some keys not functioning
Could be interference from a wireless device using the same frequency. Locate any other wireless keyboard/mice from the vacinity and try it again. Also, push the connect button on the bottom of the keyboard and see if that helps. Also make sure the base station of the keyboard is close enough to the keyboard/mouse.
Jun 25, 2010 | Logitech Wireless Access Duo Optical...
I AM USING LOGITECH CORDLESS KEYBOARD WITH WINDOWS 7 W/VISTA EVERYTIME I HIT A KEY DOUBLE LETTERS COME UP CAN YOU HELP ME THANKS JOHN
Not sure what to say other than:
1) Driver is installed twice
2) Keyboard keys are not effectively debounced in which case you would need to replace the keyboard
To find out if the driver is installed twice, open up the explorer, right click on My Computer and click on properties. Go to device manager and then go down the list and click on Keyboard. there should only be one driver inside. if you find two and they are identical, delete one.
Good luck
Jan 26, 2010 | Logitech Wireless Access Duo Optical...
Getting full use of the keyboard
you may need to configure it. to do this, go to control panel, select "printers and other hardware, then click on "keyboards" and find your model.
Mar 28, 2009 | Logitech Wireless Access Duo Optical...
Mixed up multimedia keys
Take out the batteries, replace them, and hold the 'connect' button for 15 secs. Works a charm; the whole keyboard is reset.
Tim
Jan 31, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
Hotkey problems
I had the same problem but finally found a solution hidden in the depths of Logitech. It's quoted below. I had to do it a couple of times before it worked, and it seems that you need to reconnect the mouse at the same time. I didn't the first time and then the keyboard refused to work. (Finger trouble?) :-(
Cheers,
Magani
The following is from :-
http://logitech-en-ap.custhelp.com/cgi-bin/logitech_en_ap.cfg/php/enduser/std_adp.php?p_faqid=28&p_created=1083786523&p_sid=hwmEUpij&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTkwLDE5MCZwX3Byb2RzPTg0NCZwX2NhdHM9JnBfcHY9MS44NDQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1teCBkdW8gaXRvdWNo&p_li=&p_topview=1
This article applies to the following products:
Cordless Access Duo
Cordless Acess Duo Optical
Cordless access keyboard
Cordless Elite Duo
Cordless MX Duo
Cordless Navigator Duo
You may be able to reset the keyboard and resolve the problem by clearing the keyboard capacitors. To do this, remove the batteries from the keyboard and type continuously on as many keys as possible for one to two minutes. This action should simulate touch-typing; you should not press and hold only some keys down.
After you clear the capacitors, replace the batteries and synchronize the keyboard using the following procedure:
  1. Make sure the batteries are in correctly. A diagram on the device itself or in the Getting Started Guide should tell you the correct polarity for the batteries.
  2. Press the connect button on the receiver.
  3. Press the connect button on the bottom or right hand edge of the keyboard.
    NOTE: If you are using a Cordless Desktop System, you must do this procedure for both the mouse and the keyboard.
The "Connect" button on the mouse is quite small and usually requires a pencil tip or other small object to push it. Remember, ALL Logitech cordless devices will have a synchronization button. If you have the "Cordless Mouse" with Model Number (M/N) M-RN67, the button will be located in a small hole on the lower portion of the back of the mouse. You will need a paper clip to access the button.
Jul 03, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Progaming function keys
Normal 0 Go to Control Panel.
1. Click on Keyboard.
2. When the Keyboard Properties come up, CLICK on Key Settings.
3. Then set up the keys by selecting the Key to be changed.
Hope this will help some. Bud
May 20, 2008 | Logitech Cordless Desktop EX110
EliteGroup P4VMM2 Motherboard Logo
183 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
