I cant get the hardrive out of a dimensions 2400 in a metal case
  • 153 Answers
  • 8,404 Answers
Should be real simple ... two electric connectors and 4 screws max ... slide it out of the bay.
tell me what you are having trouble with ...
I will try to help you
a
Posted on Oct 05, 2009
    Genius:
  • 1,043 Answers
Go to the following URL:
http://support.dell.com/support/edocs/systems/dim2400/en/index.htm
From that page you can download the Service Manual. Once the files are unpacked go to the directory that they were unpacked into. Look for a file called index.htm and double click on it. Your default web browser will load up the file for you. Find the entry called Removing and Installing Parts. Down on the lower third on that page you will find the instructions on how to remove and replace your hard drive. Make sure that you wear an anti-static wrist strap while working inside your computer so that you will not fry any parts inside.
How do I remove and replace a CPU cooling fan on my Dell Dimension 2400
Make sure u can open the casing well to expose the interior parts without causing any damage. Then by close look at the processor area , that is where the heat sink is located. Normally the dell dimension 2400 has a green channel shaped structure that acts as a passage for the air that enters in and out for cooling the heat sink. It has a locking parts that slides into the casing back by slight pressing to the back of the casing just behind the processor area, be so observant to notice the locking parts. then the fan is just fixed behind that green " channel like" and its fixed on the rear side of the casing, 25275582-o0cuhlgwrl13okm3u3q5444d-5-0.jpg
Nov 08, 2014 | Dell Dimension 2400 PC Desktop
Hardrive is unknown device in bios
The BIOS determines the maximum size hard disk the computer can support.
The max hard disk size for this model Dell is 80Gb.
To use your 250Gb hard drive, install this Hard drive into an USB hard drive case and use it as an external USB hard drive.
Mar 09, 2013 | Computers & Internet
I have a dell dimension 2400 and there is a noise. It's not coming from the poser supply or the cooling fan. It's coming from that large rectangular metal above the microprocessor. But I am not sure. The...
It may be from processor cooling fan fixed over heat sink ( ie large metal rectangular with fins).clean heat sink fins and fans.extreme case fan to be changed by service technicians
Feb 15, 2011 | Dell Dimension 2400 PC Desktop
What kind is motherbourd
The Dell Dimension 2400 motherboard is proprietary to the Dell Mitac Chassis. It should work in any Dell 2300/2350/2400/4600/4700 case. The main item is the Dell specific power/control panel connection. If you move the board take the control panel with it.
(Personally, it isn't worth the effort)
Jul 05, 2010 | Dell Dimension 2400 PC Desktop
Remove Dell Dimension 2400 Cover - I have been to the Dell site and read the documentation. But opening the cover seems to require two people - or three hands! Are there any tricks of the trade? Thanks!
This is a rather simple case face to remove.
Remove the side cover and place the unit on its side. hold the bottom of the face with 1 hand and pull gently while popping the 4 clips inside the case on the bottom end.
After you have done this there should be 1 on the side you can pop then there is a metal flexible peice at the top, pressing that down will relieve the top clip.
Place the case upright while holding the face out, after this the case will pop off to the opposite side of the case that the case opening is on.
Feb 11, 2010 | Dell Dimension 2400 PC Desktop
I cant get my dell dimension 2400 to detect my modem to access dial up internet it has windows service pack 3 (xp) please help
try this driver:
http://www.findmysoft.com/drivers/download-Dell-Dimension-2400-Intel-modem-driver.html
Oct 27, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 2400
The front side bus speed of the processor is the limiting factor of your RAM speed.
The Processor has a 400 Mhz FSB, hnece your RAM runs at 266.
For RAM to run at 333 (PC 2700), you'll need a 533 FSB Processor.
Jun 25, 2008 | Dell Dimension 2400 PC Desktop
E171Fpb driver on dimension 2400
installing windows again then the monitor driver should resolve the problem
Jun 25, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Computers & Internet Logo
David Payne
David Payne
