Question about Fuji FinePix A360 Digital Camera
Does not open or adjust zoom
This camera has had problems with in two months of buying it,,, it
Does not open or adjust zoom like it should some times will open the next time it dont open and it does not focus at all....Help
  • Mescom Dec 23, 2007
    Wal-Mart would not take back after 30 days....
    Yes need help, This camera does not auto focus and you cant even do it manully..also the lens does not open half the time...still brandnew what a loss of money.
  • Fuji Master
  • 4,738 Answers
First, the camera should still be under warranty, and Fuji should repair this for you for free. Consider the following IF AND ONLY IF Fuji does not help you:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
Every picture i take is not a good quality either it's blurry or the color is horrible - kind of yellowish - what kind of adjustment do i have to make
Well the blurry is caused by poor focus. Try not to zoom too much. Better to get closer to the subject if possible. Study your manual and adjust your diopter which loosely means adjust the viewfinder in and out whilst looking at a subject without using any zoom until the picture is clear. Then take you'll find it easier to focus when you do actually zoom. Sometimes there's a small sliding piece of plastic sticking out of the side of the lens. Otherwise it's a matter of turning the eyepiece to get the clarity. That's why I said check the manual. That will explain which method to use.
The yellowish colour is unusual. I would say check you have the White balance switch set to auto but lack of white balance is not usually a yellow picture. But check the white balance switch anyway and make sure it's in auto mode.
Ordinary light bulbs or some street lighting can give a yellow caste so check you have the inside outside button switched to the correct position, depending on where you are at the time of shooting.
Did you buy the camera used or new. Often people who have faulty cameras will sell them off cheap and run. Leaving the owner with the problems.
So to sum up. get closer to your subject rather than use zoom if you can. If you use a lot of zoom either use a tripod or place the camera on a firm surface or even hold the camera whilst you stop yourself from moving by leaning against a wall or tree etc.
Next remeber where you are and switch the indoor/outdoor switch accordingly
Apr 22, 2010 | JVC Everio GZ-MG130 Camcorder
I have a VPC E1090 Sanyo, I just purchased it within this month. When I try to zoom in, the camera states lens error ox2119. How can I fix it?
I have one of those. As noted to someone else, go to the menu and into the settings. One of the settings adjustment is "digital zoom". Press OK to enter into that digital zoom and then press the down arrow to highlight the "ON". Then you can get back out of everything by pressing MENU a couple of times.
Nov 21, 2009 | Cameras
8 month old tz5 doesn't want to focus any more. Camera says to switch off and then on again, but doesn't help. Anyone help..?
Hi!
It sounds like the focus is stuck. Could be sand, dirt or something like that. I repaired a TZ5 with this problem a couple of days ago. You should contact your local Panasonic service center or other local camera service center. This is a hardware problem, not software, so I'm afraid changing setting and stuff like that won't help.
I hope this helps!
Tom
Jul 29, 2009 | Panasonic DMC-TZ5 Digital Camera
Problem with my Olympus FE-230
When I turn my camera on, the lens goes in and out a few times. Once it's finally on and I look at the screen, everything is blurry. When I take the picture, it's blurry too. If I try to use the zoom to adjust, the lens starts going in and out all crazy and won't adjust right.
Jun 20, 2009 | Olympus FE-230 Digital Camera
Zooming in.
Your camera jumped out of gear. Open the front metal cover and disassemble all arm working with the main motor gear and try to reposition the red dot on the big gear with the small gear side by side. Presto now your camera is aligned. Place all arms back in order to your new alignment.you got your self a working camera. D: 3403 3404 mean error = some thing is block your lense and stopping the motored gear. For future referance don't drop the camera agian, next time it might be a expensive fix next time around.
Apr 26, 2008 | Olympus ? Stylus 500 Digital Camera
Fuji Finepix 3800
The date time problem ist he internal battery[ A watch type button inside the camera body]
has worn out- replacing it will be a workshop job.
The other problem seems like wear and tear on the switch any repair will be costly.
Just live with[out]it- or buy a new camera
Nov 20, 2007 | Fuji FinePix 2800 Zoom Digital Camera
Zoom error
Knocking the bottom of the lens end of the camera 3 times on a wood table, medium gentle, fixed a zoom error (where it would not focus in zoom)
The camera had been dropped whilst skiing holiday and this method fixed it. Very Happy!.
Nov 19, 2007 | Fuji FinePix Z2 Digital Camera
Zoom is stuck
Just check the DC power supply flowing to the Lens block control. Some times the SMD fuse blows off and power may not reach the lens block motor.
Dec 02, 2006 | Sony Handycam DCR-PC105 Mini DV Digital...
Fuji FinePix A360 Digital Camera Logo
69 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
