Question about Xerox Phaser 7700 Laser Printer
My xerox phaser 7700DN is printing yellow streaks on one side of each page that comes out. I have had this problem in the past, and changing the toner, the print cartridge, or simply cleaning the accumulator belt helps, but this time nothing is removing the streaks.
    Scholar:
  • Xerox Expert
  • 123 Answers
This is a faily common problem with the Phaser 7700. The yellow developer needs to be replaced. Parts at: http://www.lpscomputer.com/p-3063-1-116-1115-00-developer-housing.aspx The manual can be downloaded from: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
Posted on Apr 26, 2010
Xerox Phaser 7400, lines on solid colours
Are the streaks evident when printing actual images? I was told by an experienced Xerox service tech that those solid-fill test pages can be misleading -- mine does the same but prints photos beautifully. I suggest printing some full page photos, check for the streaks. You've already done just about all you can.
Jun 19, 2014 | Xerox Phaser 7400DN Laser Printer
Xerox 8500 phaser prints brown tint
Most likely the cyan ink is burnt. If the ink sticks are left unused (printing more black than color, this will happen.
Print the test pages for PQ troubleshooting from the control panel and examine each print. Cyan will probably have very dark streaks down the page, magenta should look normal, and yellow also will have dark stripes. You need to replace this burnt ink, and the only way is to print. From within paint (or similar accessory in other OS) Create a full page of cyan, and print about 100 - 200 pages, or until the cyan starts to clear up. Yes it is a waste, but much cheaper than a print head, Do this for yellow as well.
Apr 15, 2014 | Xerox Phaser 8560DN Laser Printer
When printing 2 sided sheets our machine puts dark gray streaks on the paper after printing more than 6 pages. The streaks continually get larger until they cover most of the page.
When you are printing 2 sided sheets the reason you are getting streaks, is your first sided not dry yet. I know it is a laser printer, even laser you have waite a bit.
Dec 03, 2009 | Xerox Phaser 7700 Laser Printer
Yellow streaks on phaser 7700 prints
You have a bad yellow developer housing and it will need to be replaced. The manual can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
The parts can be ordered here: http://www.lpscomputer.com/p-3063-1-116-1115-00-developer-housing.aspx
Jul 05, 2009 | Xerox Phaser 7300DT Laser Printer
Xerox phaser 7700 paper feed transparency errors
There is a Transparency sensor (called the OHP) which is part of the Registration Transport 116-1164-00
Clean it first. Or replace the whole assembly
Whit
Item, Inc.
Mar 24, 2009 | Xerox Phaser 7700DN Laser Printer
Dark streaks
Dark streaks are an indication of "burned" or overheated ink. This will occur when the printer sets for a long period of time and nothing is printed. The problem will usually disappear after 50 pages or so, unless the printhead is damaged.
If the print remains dark, the printhead will need replaced.
(Very expensive)
(Dark print can also be caused by using Non-Xerox ink)
Sep 10, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Streaking
You can go into the trouble shooting menu and do the "eliminate Light stripes" procedure a few times.
Then you can do Jet substitution from the same menu.
If that does not work then most likely you need a new print head.
If you have used non xerox ink sticks that is your most likely cause of the problem. cheaper is not always better
May 28, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 7700DN color printer
I would be willing to be it's one of two things.
Most common is a jammed gear on the imaging units. Remove all imaging units CMKY. The turn on machine. If the noise is gone, start replacing imaging unit one at a time tile noise reappears. Replace defective imaging unit.
If that doesn't work remove the accumulator belt from the right side of the machine and then turn machine on, see if noise is gone. If so replace accumulator belt.
May 16, 2008 | Xerox Phaser 7700DN Laser Printer
Xerox Phaser 7700DN: Yellow prints blotchy
The problem is the developer needs replacement it got contaminated.
Mar 01, 2007 | Xerox Phaser 7700DN Laser Printer
Xerox Phaser 7700 Laser Printer Logo
687 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
