Question about Toshiba Satellite 1415-S105 Notebook
How do i connect to the internet via cable modem
  • 153 Answers
Use the network dialer provedide by the service provider or the setup cd
Posted on Oct 05, 2009
Wireless antenna or wireless router
Did your ISP Boingo supply you with a DSL or cable modem with a built-in wireless router? If only a DSL or cable modem is supplied and you wish to connect to the Internet by wireless then you need to connect a wireless router to this DSL or cable modem.
You can connect to the Internet using a LAN cable from your laptop to the DSL or cable modem.
If your laptop as a built-in wireless card you can to the Internet via the wireless router.
If you laptop does not have a built-in wireless card then you can install a PCMCIA wireless card into the card slot of your laptop to the Internet via a wireless connection.
Nov 01, 2012 | Toshiba Computers & Internet
I hooked up everything right modem to router, router to computer. but i still cant get internet to my computer. if i hook my modem directly to the compiter it works fine but not through the router
Some ISPs (Internet Service Providers) limit you to *ONE* unique computer connected through the cable-modem (or DSL-modem).
Turn the cable-modem off.
Turn the router off.
Connect the cable-modem to the router, via an Ethernet cable to the 'WAN' port on the router.
Turn the cable-modem on.
Turn the router on.
Connect, via an Ethernet cable, from one of the 'LAN' ports on the router to your computer.
Restart your computer.
You should be OK.
If not, telephone your ISP, and get them to trouble-shoot from "their" end towards your end.
Sep 20, 2010 | Linksys Wireless-G WRT54G Router
It won't connect with laptop
Here are a few simple things to check:
If your PC is connected via wireless:
- Make sure you didn't go out of signal range
If your PC is connected via wired cable:
- Make sure the cable is secured into your router
If both check out:
- Check the cable between your router and internet modem.
If all connections are solid:
- Try using a different cable from the PC to the router, and from the router to your internet modem. Cables can go bad, and a new one could be an easy fix.
If all else fails, you may have experienced an intermitted connection issue:
- Try unplugging your internet modem and router for 30 seconds, then plug in your internet modem first and after 60 seconds plug in your router.
- Try restarting your PC
If none of those work, contact your Internet Service Provider.
Jul 12, 2010 | D-Link DIR-615 Router
Cable modem is connected to the router but the router is not working wireless or when connected via Ethernet cable
You need to check first if the internet is working if you connect your computer directly to the modem. If there is internet on your modem, you need to reset and reconfigure the router. If there is no internet on the modem, you need to contact your internet provider.
Jun 08, 2010 | Linksys Wireless-G WRT54G Router
I know this is a stupid question...but does my laptop need to have an internal modem to connect to the internet
well according to the specs i saw it already has a wireless lan card, an ethernet card, and a old school phone modem jack, so you should be good. are you having issues connecting to the internet via wifi?
Nov 03, 2009 | Dell Latitude D600 Notebook
I lost the disk for the RCA DCM425 digital cable modem the cable company gave me. how can i get the modem to work on my new computer?
Hello Friend,
If you didn't change anything in modem side, that means the modem is still connected to internet. in this case you can connect the modem to your computer via the Ethernet cable. with this cable you will not need to install anything on your computer, just plug the Ethernet cable to the RJ45 port and start browsing internet.
The only case when you will need the drivers is when you want to connect the modem to your PC via USB cable.
Here is a link where you can find everything about your modem: quick guide, user manual, usb drivers ...
Best Regards,
Oct 30, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Computer cabled to Dynex enhanced G wireless will not connect
Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
Motorola SB5100 and linksys router connection
The only thing that you need to setup on your Linksys for it to work with cable is to make sure that DHCP is enabled on the router.  You will need to plug your router into the modem via the ethernet cable and then plug your neighbors pc into a link port on the router (the cable modem plugs into the internet port)  You will also need to follow the reboot procedure.  Power everything off.
1: Turn on the surfboard and wait about 1 minute for the surfboard to make a connection with your ISP (the link light should come on).
2:Turn on your router and wait for your router to sync up with the surfboard . 3: Turn on your computer. Whenever you plug anything into a cable modem, you must recycle power to the modem.  It "remembers" the last device that was plugged into it, so it's memory needs to be cleared.
Apr 24, 2009 | Arris SURFboard SBG900 Wireless Router...
Ethernet Card
Do a ipconfig at the command prompt and see if you are being assigned a ip from the modem. If not try rebooting the modem with the ethernet connected to modem and computer. then do ipconfig again to see if not getting internet ip, your card or modem eternet is bad. put in a new one and try again.
Jun 01, 2008 | HP PAVILION A6230N DESKTOP PC
Toshiba Satellite 1415-S105 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
