Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Does not operate. Confirmed power to unit, reset
Does not operate. Confirmed power to unit, reset botton 'in', not jammed.
  • 115 Answers
Motor may be burnt out and need replaced
Posted on Dec 04, 2009
Hl410100
Check the mains power to the motor switch and there after to the motor which will confirm if the switch or starter is faulty. if this is single phase check for fault on the capacitor which can be confirmed with a capacitor connected in parallel.finally check if the piston or flywheel is jammed , if so the unit must be reset with a overhauling. check for oil within that can cause high friction to jam the drive.
Mar 11, 2012 | Campbell Hausfeld Air Tools & Compressors
The in-sink erator did not start , i reset the red botton , it is humming and the electric lights dims but the machine does not start
If this is a unit you have used within the last few days, it may be jammed. You will need to turn off the power to the unit; then examine it to locate & remove the obstructing item. If it is not easily seen and removed, you may need to remove the disposer unit from the sink and examine it more closely.
Sep 27, 2010 | Emerson Home
# 3 and H Flashing ... will not do anything else ?
TO RESET THE MACINE PRESS THE ORANGE BOTTON (C),PRESS THE BOTTON UNDER THE AUTO DENSITY LIGHT,RETURN TO THE FIRST ORANGE BOTTON THEN THE AUTO DENSITY BOTTON, YOU HAVE TO BE FAST WHEN PRESSING THE BOTTONS, ALL THE LIGHT ON THE DISPLAY WILL GO OFF THEN PRESS 14 AND PRESS THE GREEN PRINT BOTTON,THE MACHINE WILL RESET AND START TO WORK, BUT IF THE PROBLEM COUNTNUE CHANGE THE FUSER UNIT.
Sep 10, 2010 | Sharp AL-1000 Copier
Air condition wont turn on
Do you have enough power to unit? Check plug for any loose wires on unit, with unit unplugged of course.
Jul 07, 2010 | Fedders A6Y18F7BCOM Air Conditioner
How can i reboot pc when F11 is not working
I'm pretty you may need to rephrase your questions. as a pc can be hard rebooted by pressing the power botton or in some case by pressing a reset botton found in all models.
I'm not sure why you need to use f11.
please elaborate by adding your computer model and operating system installed.
Mar 23, 2010 | Microsoft Windows XP Professional for PC
My canon mp145 shows paper jam..there's no paper in it..how to reset it?
there may be dust or some small piece of paper stuck. Try blowing in air in there to see if anything gets loose/out
Dec 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Savin copier 9400d error code 542
I believe that code has to do with the fixing unit. Try to reset it, press the yellow clear botton once then the #"s 1-0-7 then the red stop botton. The display should change.... turn the copier off then back on.. It should reset the code for you.... Just a question dose it have a finisher on it? If it dose have you tried to unplug the finisher with the power off then turn it back on...Is the code gone..if so you have a problem with the finisher... I work on to many different brands.... Good Luck
Jan 31, 2009 | Office Equipment & Supplies
Error code h5-01
Yes H5-01 is when it jams in the fuser 5 times in a row, check the fuser section for a jam, the paper jams up in there and does't trigger any sensors, once you have confirmed that its clear reset with sim code 14
May 31, 2008 | Sharp AR-BC260 Color Copier
BizHubC253 error code c3821
This error also occurs after a paper jam or a steep power change. If error continues after doors were properly closed and the printer was turned off and on again, it'd be necessary to reset the printer and release it from trouble status.
Turn off the main switch (1/0 botton) but keep the control panel on. Wait 10 seconds. Press and hold Utility Counter botton on the Control Panel while turning on the main switch. Hold it until a white screen with a black dot over the upper rigth corner appears, then release it. Wait for a "trouble reset" botton on the control panel and then manually click on it. You'll see an arrow pointing to an "OK". Now turn off again the main switch, wait 10 seconds, and turn it on. Error must be gone.
May 03, 2008 | Konica Minolta bizhub C250 All-In-One...
Hard reset
just press once power button and reset button ok
Jan 24, 2008 | i-mate JAM Pocket PC
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
288 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
