Question about Jandy Laars LX Pool Heater / 250,000 BTU / Propane Gas
My LX heater will not start blower but I have 230 volt on black and white terminals. When on and off?
    Champion:
  • 246 Answers
Some turn to auto . make sure is on manual again raise the temp and wait
Posted on Oct 15, 2009
I have a 1/2 horsepower electric motor 230 volt 3 speed w/ capacitor HVAC fan assembly. how do I wire it to power by color coded wires?
Keeping in mind that some motors may be different
The most common wire colors on a 3 speed motor are as follows:
Red- Low speed
Blue- Medium speed
Black- High speed
Brown capacitor wires ( usually two of them connect to the two capacitor terminals doesn't matter which wire to which terminal)
White - Neutral wire on 115 volt systems or the other 115 volt side of a 230 volt system ( note on a 230 volt motor this wire may not be white). Remember this is the most common wiring but different motors may have different wiring.
Hope this helps.
Bob
Nov 30, 2014 | Heating & Cooling
I have a haldex 1hp 115/208-230 volt motor ac. i need to make sure i hook it up right for 230 power. the diagram just confuses me and im a mechanic. white wire, black wire, push button switch, and 7
the spade terminals in the wiring box are marked the chart tells where the color wire goes to what terminal for what voltage then l1 and l2 is the incoming power hookups
Sep 09, 2014 | Heating & Cooling
Proper wire hook up
black goes to L1 white goes to L2 make sure to look on side of motor to change from 220 volt to 110 volt either a knob or changing wires brown and white to different locations hope you didnt fry motor
Jul 26, 2013 | AO Smith 1.5 hp 3450rpm 48Y Frame 115/230...
My roper dryer had a 4 prong cord. i changed it over to 3 prong. now it will not start
Your dryer requires 120 for motor operation. It only needs 240 volts for heater operation. Since the motor is 120 volts it is on a different circuit than that of the heat. On your terminal block is a white wire in the middle, that is neutral and it is needed to drive the motor. On either side is a black wire and a red wire. The motor runs on the white and black circuit. The heater circuit runs on red and black.
The motor circuit has a fuse in it mounted on the blower wheel next to the control klixon. If it is open the motor will not operate just as the door was open, door switch is also on the motor circuit. The motor has to be operating for the heat to come on also because the heater wires go through the motors centrifugal switch.
Dec 31, 2012 | Roper Dryers
Laars LX 250 AGS Service error. Burners ignite the go out.
if connected 120 volt switch red and black wires its not rectification
Nov 17, 2012 | Jandy Laars Lt 250,000 Btu Heater
How do I wire blower moter
Black- high speed Red- low speed Blue- med. high Yellow- med. low White- neutral Usually black on "cool" terminal on board, red on "heat" terminal on board, and remaining 2 on the "park" terminals on board. White goes to the neutral terminals. Hope this helps!
Nov 14, 2012 | Goodman GMS90703BXA Heater
How to wire a t30 1 phase 230 volt in control box, they used white black green, are the white and black both line voltage for 230 volts? its a model 2475
yes white and black are both line voltage in.each wire will have 110 to 120 volts. Attach one wire to top of starter contactor left side the other to top of starter contactor right side. Attach green wire to ground.
Jun 01, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
My pool originally had a 2 speed AO Smith pump motor. Several years back it was replaced with an AO Smith single speed motor. I am replacing that motor with a new AO Smith single speed Centurion Switchless...
Is it going to run on 230V then? If so you would normally use red and black. The white wire should be a neutral and the ground wire is obviously ground.
Do you have a meter you can use to confirm the voltage between the wires? If you do you'll want to start with red and white since you seem to think black was not being used before. If the voltage reads 230 and the motor is set up for 230 then attach one wire to L1 and the other to L2...it will not matter which is connected where as long as one is on each terminal. Insulate the black and ground the ground lead to the motor ground screw.
If the voltage is not 230 between those two check between red and black. If that is the 230 then insulate white and put red and black to L1 and L2.
John
May 23, 2011 | AO Smith 2 hp 3450rpm 56C Frame 230 Volts...
How to connect the Dayton Capacitor Start Motor to 230 volts ?
In the **********, the screws will be market L1 & L2. There will also be a jumper that needs to be connected between the 2 terminals for 230V.
Aug 28, 2009 | Dayton Permanent Split Capacitor Motor Fan
Generator electrical
On a 230 volt std hook up here's the way it is supposed to work. From black to white you should get 115 volts. From Red to white you shoudl get 115 volts. From red to black you should get 230 volts.
Concentrate on getting the correct output from the generator with the load to the house disconnected
This should be 115v (black to white, 115 volts red to white and 230 volts red to black.
On the load side (ie, the house connected) what are you using? 115 volt lights, etc on one side of the
230 volts, and some other 115 volt loads on the other side.. Are there any 230 volt loads. It could be
that one side of the 230 volts (ie, a 115 volt side is drawing a lot more current than the 2nd 115 volt leg.
Get back with me on just what the loads are botth 115 volt and 230 volt . also what are the rating on the circuit breakers.
Loringh
Oct 28, 2008 | Electrical Supplies
Jandy Laars LX Pool Heater / 250,000 BTU / Propane Gas Logo
126 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
