Question about Samsung L200 Digital Camera
Camera has problems turning on and off
Camera doesn't turn on. And when it does, sometimes the lense doesn't come out. If I'm luck enough to get this camera to come on, I'm have a problem turning it off. If it's on for 5 minutes. The whole camera gets hot. What can I do to fix this problem
SOURCE: Camera won't stay on
That has happened to me before. When I got my camera for the first time, I took all kinds of pictures. About a week later, it did the same thing yours did. So I got new batteries and I wouldn't work. So I went to the store where I bought it and had it exchanged for a new one. If you haven't scrached it or anything and kept the reciept, then go to where you bought it and have it exchanged.
Posted on Aug 28, 2007
byron21
  • 151 Answers
SOURCE: Camera turns itself off
or this problem try the following:
* Try removing the memory card and the battery
* Try using the camera w/o the memory card
* If problem still persist call the Tech Number
1800 SAMSUNG
Hope this will help
Thanks
Byron
Posted on Sep 25, 2009
  • 108 Answers
SOURCE: My samsung L730 lense is stuck
i have the same problem with these camera. to get it fixed just take out the battery wait for a few sec and put the battery back on, then switch the camera on. for the lens just gently move/force the lens to open, then turn off the camera wait for a few seconds then turn on the camera back on see what happens. and if still persist keep doing it till gets back to normal.
this sometimes happens to my camera from time to time i think it just its wear and tear.
one more problem with this camera is that it'll go blurr, just do the basic turn off or take out the battery wait a few sec and then turn it back on.
hope this will help u.
Posted on Feb 08, 2010
  • 11967 Answers
SOURCE: samsung didgital camera lense keeps will not
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 27, 2010
  • 411 Answers
SOURCE: my camera lense popped half way in. and won't turn on
take out the lens unit disaassemble the lens replace the broken/deformed parts service it assemble fix it to get proper functionning.
Posted on Apr 10, 2010
Will not work
Try to find out if there is something else obstructing the free movement of the lens barrel. And then try to find out if your battery (yes) are still ok. If they can't give enough power, the motor to drive the lens, can't work and the camera also "thinks" the lens got stuck.
Sometimes, a gear that is involved with moving the lens became broke. If that happens, only a repair shop can help.
Nov 24, 2013 | Kodak EasyShare C142 Digital Camera
Camera turns on, lense comes out and powers off. turn back on and lense retracts and powers off
When the camera turns on, and then turns off again it usually means that the batteries are too low to power the unit correctly. Replace your batteries and try turning it on again. This model camera uses a lot of power and drains batteries pretty easily. Rechargeables sometimes do not hold enough to power it correctly for very long.
If you replace the batteries and still have the same problem, try contacting Fuji direct for repair options. Without seeing the camera to troubleshoot it or have the ability to ask you questions and have you try troubleshooting actions based on those answers - there really isn't much else I can do for you.
Jul 17, 2011 | FUJIFILM FinePix AV100 Digital Camera
I have a Polaroid t1035. When turning the camera on and off the lens will not collapse and makes a clicking noise.
This is a common issue with retractable lenses. A grain of sand, accidentally pressing the On button when still in the bag etc.
In most cases the problem is of mechanical nature - meaning one of the gears is stuck. The small motor doesn't have enough power to push through it.
Depending on the model - there are sometimes tricks to get the lens going again. It involves manually helping the lens to come out. There's a risk of permanent mechanical damage.
Jun 30, 2011 | Cameras
Turn the power off and on again
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
When I turn the camera on, the lens keeps going in and out...
When you drop your camera two things may happen.
1- Some mechanical part of the lense mechanism may have been damaged or broken. You would have to open the lense and check for broken parts, damage parts disconected cable. It is not advisable for most people to open the lense and put it back together. You would most likely make it worse.
It usually cost more to fix it than, if you invest in new camera.
2- If some dirt somehow got on the side of the lense, they may cause your lense not to open 100% when you turn it on or retract 100% when you turn it off. I had the same problem with my sony cyber-shot DSC-w7 which is very much similiar to yours. Here is what I did and my camera is working fine ever since.
I cleaned around the lense.
While I turned the camera off, I pressed the lense in (up and down and turning motions) Not too hard for a few times untill the lense retracted over 90% of the normal.
I then push the lense a little harder so that the lense was 100% retracted.
After I turn it on and off a few times, the lense opened and closed as it does normally.
If you try this, it should get fixed if it is fixible.
If it was not fixed and you decided to buy a new one and you intend to trash it. Give it to someone like me who loves to open up and mess it up or sometime fix it.
Good LUCK !!!!!!!!!!!!!!!!!!!!!!!
Jun 16, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
I have a sony DSC-W170. It was dropped and now
I had exactly the same problem with my Sony Cyber_Shot. Here is what I did and the problem was fixed. I cleaned around the lense. While I turned the camera off, I pressed down the lense very softly (some up and down motion). After a couple of times, the lense retracted almost completely. Then I pressed a little harder until the lense retracted 100% as normal times. I turned it on everything was back to normal. If the lense does not have mechanical problem, you should be able to do what I did.
If there is no mechanical problem, most likly some dirt got on the sides of the lense while it was open. Try keep it very clean always.
Good luck;
Jun 15, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
S630 won't turn on
Openings the lense is the last thing you want to try. If you dropped your camera, you may have to. If you did not drop your camera, some dirt somhow got on the sides of the lense and they prevent your lense from closing or opening 100%
Try this first
turn it on and the same time pull the lense out. Your lense may not be open all the way out. OR
Clean the side (outside) of the lense. While turning your camera OFF, push on the lense in NOT too hard. Try that a few times, If the lense retracted 100% or near 100%, just push the lense in a little harder untill it is 100% retrected. Turn it on, It may work now.
Good luck!!!!!!!!!!
Good Luck!!!!!!!
Jun 11, 2009 | Samsung S630 Digital Camera
Sony cybershot 7.2 went to shut off camera and lense is still out no power to camera tried to recharge batt. w/no results
Try different batteries. I got the same problem with my cyber-shot. The battery was too low while lense was fully open. I recharged, but the lense would not close. When I turn it on, It would say turn off and on again. I did that for at least 20 times. I finally put another set of batteries and while I turned off the camera, I pressed the lense in very softly. After a couple of times the lense retracted fully. The camera has been working normally ever since.
It is also possible some dirt some how got on the sides of your lense. Try cleaning the sides of the lense.
If you had no luck so far, then your lense may have some mechanical problem. The lense need to be opened and cleaned and put back together.
good luck
Jun 09, 2009 | Sony Cyber-Shot DSC-P32 Digital Camera
In camera or video mode it says turn the power off and on again
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
If the lense does not retract, but goes up and down when you turn it on or off, Clean the sides of the lense and while turning the camera off push the lense in NOT too hard for a few times. If it retrected 100% or most of the way inn, push the in a little harder untill it is 100% retracted in. Now your camera should be back to normal. 2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damaged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
Apr 14, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
My L200 samsung camara is frozen and the lens are stuck out
I had the same problem - and wondered if if might be that the battery didn't have enough 'grunt' to close the lense - so I am charging it via the actual charger (rather than through the computer) and sure enough, I turned it on and then off, and the lense closed. The green light comes on when I plug the camera into the computer to download photos, and I thought this was therefore charging the battery, but maybe it doesn't charge it properly. Anyway, my lense is now closed and the battery is still charging (light is still red). Good luck.
Jan 06, 2009 | Samsung L200 Digital Camera
Samsung L200 Digital Camera Logo
19 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
