Question about Samsung RS2630SH Side by Side Refrigerator
Problem my refrig is hot up top and where the slots to storage the vegetables are is like a freezer it freeze everything. and my milk spoils up top.
  • 75 Answers
Fault thermal fuse the new fuse is modified not to cause same problem again.
common fault:
Posted on Dec 23, 2007
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Freezeing milk and fruits
There is damper door between fridge and freezer section.Its not getting closed properly, this is mostly causing the problem.Click the link below for more troubleshooting:---
http://technoanswers.blogspot.com/2011/11/everything-freezing-in-vegetable-drawer.html ------- This should help.Thanks.Helpmech.
Oct 29, 2011 | Refrigerators
I have a KitchenAid refr. mod. KSRL25FRSS00 it is turned down to the lowest setting and still freezes things in vegetable box. (new control board?)
Is your milk or eggs freezing? All the cooling in the refrig and freezer spaces is done in the freezer. Sometimes, the control labeled freezer temp controls a vent between the freezer and ref space, allowing air into the ref side. the other control determines run time. try turning thefrz setting up to raise the ref temp.
Nov 15, 2010 | KitchenAid Refrigerators
Refrig. Won't keep food cold but the freezer works fine. Milk spoils after 3 days in the refrigerator. What's wrong? The thermastat was supposely changed?
If the thermostat has been replaced, then I would take a look at the dampers between the refrigerator and the freezer. Here is why....
All the cooling takes place in the freezer section of the unit, there are passageways with dampers that connect the freezer section to the refrigerator section. If these dampers get stuck in a certain position you will either have not enough cooling or to much cooling. This sounds like it is your issue. Hope this helps.
May 07, 2010 | Refrigerators
Freeezes vegetables milk etc. even with refrig turned up.  Tried turning up freezer by 2 pts. ..Then tried turning up refrigerator to 44..Still no luck.No one seem to repair Lg Refigerator.s  in...
Have you made sure that the door to the ice maker area is closed and tighly latched? If the door is not pushed closed so that you hear the latch snap shut, colder air from the ice room will leak past the gasket and result in freezing in the bins and / or on the bottom refrig shelf. Another possibly might be air leakage at the very back bottom of the refrigerator section, where the air tower comes out from the freezer section.
Oct 07, 2009 | LG LFX25960ST Stainless Steel French Door...
GE Profile Arctica Side-by-Side Refrig PSC23MGMB IS WAY TOO COLD!
it sounds as if the ice door is not closing properly. Check the little rubber door seal to see if it is sealing properly. If not try a hair dryer to soften it. Otherwise you have to buy a door kit.
Feb 01, 2009 | Refrigerators
Freeing food in refrigerator, even vegetables in vegetable tray
You have 2 dials in the refrigerator. One is the thermostat setting the cold temp in the freezer, the other is a damper that allows cold air from the freezer to the refrigerator. Set the thermostat to the middle then try closing down the damper, most say colder or warmer refrigerator. If the damper is closed and your refrigerator is still freezing, then I would guess that the thermostat is bad. A thermostat runs about 40 to 60 dollars wholesale. Retale should be about double.
Oct 20, 2008 | Samsung RS2534 Side by Side Refrigerator
Freezing in refrig and freezer.
call the tech back... the control board may be fauilty or install incorrectly.. the water leak is from a pluged drain hose or your ice maker leaking not from a control board...
Aug 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
140 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
