Question about Maytag Dryers
Loud Squealing at first and then goes away. Is this dryer belt driven? Maybe just need to replace the belt or tighten it.
    President:
  • 2,976 Answers
All dryers are belt driven. You're one of the lucky ones that got a warning that the belt is failing. Usually, it just snaps.
Posted on Oct 05, 2009
Squealing noise when first starting up a 1500cc kawasaki
Belt dressing on drive sounds like clutching system. Maybe talk to service.
Oct 23, 2014 | 1999 kawasaki VN 1500 Vulcan Classic
Sqeals terribly, stops squealing occasionally, but is very loud and high pitched.
Squealing comes from the belt. I replaced my belt and it went away. Good luck in trying it.
Apr 18, 2010 | Dryers
Car vibration - maybe it has to do with the AC?
it is the a/c bearing clutch. it needs to be replaced
Apr 15, 2010 | 2002 GMC Yukon XL
Vehicle A/C makes a continuace loud squealing noise
check your belt tension. Tighten it up and the noise should go away. if not, replace the belt and tension it accordingly.
Jun 02, 2009 | 1999 Pontiac Grand Prix
Help! Air conditioner causes squeal soon after turned on
The ac is belt driven, If one of the belts are loose it will make a squealing noise. Turning on the air puts more strain on the belts. If this is the case all you would have to do is tighten the belt or belts. This would probably take a service tech just a few minutes. Probably under $100.00 dollars..........
May 10, 2009 | 2001 Toyota Avalon
Craftsman Tiller makes loud, shrill, squealing noise when tilling
Noise comes and goes sound like metal on metal not a belt squealing
Apr 03, 2009 | Craftsman Garden
Maytag atlantis dryer squeals very loudly when running
you have answered your own question! The belt will have become loose due to age/stretching. You hear cars making the same squealing noise when thgey rev up. Its a real squeal/screech. It may possibly be the drum rubbing on the chassis due to beariing failure, but doubtful.
So on some machines the motor is on adjustable brackets that let you move the motor away from the drum pully by loosening the bolts/nuts and then re-tighten. Don't leaver the motor down and then lock off the nut/bolt as this will make the belt too tight, and cause the belt to fail or the bearing to fail over time Take the back cover off the machine and all will be revealed.
best of luck it's a simple fix if your diagnosis is correct
Nov 13, 2008 | Dryers
Dryer Noise
You need to have you belt replaced. Over time the belt will strech.
this causes the dryer to still spin but the belt will sometimes loose the grasp of the drum and cause the belt to spin only.
This happens because over time with heavy loads of towles and jeans pull down on the drum as it is being loaded. Than when in cycle the jeans will drop from the top to the bottom pulling aginst it even more..
Aug 14, 2008 | Dryers
Dryers Logo
83 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
